查看: 5778|回复: 2
普中科技LCD1602 亲测可用
ID:183197 发表于 2017-4-8 13:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#define unit unsigned int
uchar code table[]="I LOVE FREEDOM";
uchar code table2[]="I HAVE TO WORK";
uchar num;
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P2^5;
void delay(unit z)
unit x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date)
lcdrs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
lcden=0;
lcdrw=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x80);
init();
  write_com(0x80+0x10);
for(num=0;num<14;num++)
write_data(table[num]);
delay(20);
write_com(0x80+0x53);
write_data(table2[num]);
delay(20);
for(num=0;num<16;num++)
write_com(0x18);
delay(200);
while(1);
ID:248449 发表于 2017-11-11 19:36 | 只看该作者
第二行显示少个k
ID:445158 发表于 2018-12-12 20:05 | 只看该作者
只适用与八位总线
