查看: 2979|回复: 0
II2C总线芯片 24c0x读写程序
ID:189450 发表于 2017-4-17 21:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include"intrins.h" //  _nop_();
sbit scl=P2^1;
sbit sda=P2^0;
bit write=0;
uint num,num1;
uchar ge,shi;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay_ms(uint Z)
        uint x,y;
        for(x=Z;x>0;x--)
          for(y=110;y>0;y--);
/*****ÅäÖÃIICD¾Æ¬**********/
void delay()
        _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void start()//¿aê¼
        sda=1;
        delay();
        scl=1;
        delay();
        sda=0;
        delay();
void stop()
        sda=0;
        delay();
        scl=1;
        delay();
        sda=1;
        delay();
void respons()
        uchar i;
        scl=1;
        delay();
        while((sda==1)&&(i<250))
                i++;
        scl=0;
        delay();
void init()
        sda=1;
        delay();
        scl=1;
        delay();
void write_byte(uchar date)
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay();
                sda=CY;
                delay();
                scl=1;
                delay();
        scl=0;
        delay();
        sda=1;
        delay();
uchar read_byte()
        uchar i,k;
        scl=0;
        delay();
        sda=1;
        delay();
        for(i=0;i<8;i++)
                scl=1;
                delay();
        k=(k<<1)|sda;///////
                scl=0;
                delay();
        return k;
void write_add(uchar address,uchar date)
        start();
        write_byte(0xa0);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
uchar read_add(uchar address)
        uchar date;
        start();
        write_byte(0xa0);
        respons();
        respons();
        start();
        write_byte(0xa1);
        respons();
        date=read_byte();
        stop();
        return date;
/************êyÂë1üÏÔê¾oˉêy*********************/
void display(uchar shi,uchar ge)
        P1=0xdf;
        P0=table[shi];
        delay_ms(5);
        P1=0xef;
        P0=table[ge];
        delay_ms(5);
/*********Ö÷oˉêy************************/
        init();
        num1=read_add(2);
        if(num1>100)
                num1=0;
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        ET0=1;
        EA=1;
        TR0=1;
                display(num1/10,num1%10);
                if(write==1)
                        write=0;
                        write_add(2,num1);
/*******ÖD¶Ïoˉêy*****************************/
void time0() interrupt 1
        num++;
        if(num==20)
                num=0;
                num1++;
                write=1;
                if(num1==100)
                        num1=0;
I2C总线.zip
44.41 KB, 下载次数: 11, 下载积分: 黑币 -5
