查看: 5788|回复: 3
Proteus仿真TFT320240 带LPC213X源程序
ID:14102 发表于 2017-5-3 15:41 | 显示全部楼层 |阅读模式
一个TFT320 240液晶的proteus仿真图纸,供学习参考!
LPC213X源程序:
  1. #include        <LPC21XX.h>
  2. #include        "picture.h"
  3. #define                RS                8
  4. #define                RW                9
  5. #define                EN                10
  6. void delay( unsigned int x )
  7. {
  8.         while ( x-- )
  9.         {
  10.
  11.         }
  12. }
  13. void PortInit( void )
  14. {
  15.         PINSEL0                &=                0xffc00000;
  16.         IO0DIR                |=                0x7ff;
  17.         IO0SET                |=                0xff;
  18.         IO0SET                |=                (1<<RS);
  19.         IO0SET                |=                (1<<RW);
  20.         IO0CLR                |=                (1<<EN);
  21. }
  22. void TFTWriteCmd( unsigned char Command )
  23. {
  24.         IO0SET        |=        Command;
  25.         IO0CLR        |=        ~Command;
  26.
  27.         IO0CLR        |=        (1<<RS);
  28.         IO0CLR        |=        (1<<RW);
  29.         IO0SET        |=        (1<<EN);
  30.         delay( 10 );
  31.         IO0CLR        |=        (1<<EN);
  32. //        IO0SET        |=        (1<<RW);
  33. }
  34. void TFTWriteData( unsigned char Data )
  35. {
  36.         IO0SET        |=        Data;
  37.         IO0CLR        |=        ~Data;
  38.
  39.         IO0SET        |=        (1<<RS);
  40.         IO0CLR        |=        (1<<RW);
  41.         IO0SET        |=        (1<<EN);
  42.         delay( 10 );
  43.         IO0CLR        |=        (1<<EN);
  44. //        IO0SET        |=        (1<<RW);
  45. }
  46. void TFTInit( void )
  47. {
  48.         unsigned int i;
  49.         unsigned short temp;
  50.         TFTWriteCmd( 0x00 );
  51.         TFTWriteCmd( 0x00 );
  52.         TFTWriteCmd( 0x00 );
  53.         TFTWriteCmd( 0x00 );
  54.         for ( i = 0; i < 320*240; i++ )
  55.         {
  56.
  57.                 temp        =        girl[i];
  58.
  59.                 TFTWriteData( temp%256 );
  60.                 TFTWriteData( temp/256 );
  61.         }
  62. }
  63. int main( void )
  64. {
  65.         PortInit();
  66.         TFTInit();
  67.         while ( 1 )
  68.         {
  69.
  70.         }
  71. }
下载:
Proteus仿真TFT320240.zip (539.13 KB, 下载次数: 41)
ID:348319 发表于 2019-1-28 15:29 | 显示全部楼层
多谢分享
ID:105039 发表于 2024-12-24 15:09 | 显示全部楼层
很经典的仿真程序
ID:1143234 发表于 2025-1-20 15:27 | 显示全部楼层
大神有没有LPC2138芯片包?
