查看: 3101|回复: 0
MCU STM8 定时器寄存器参考代码
ID:200377 发表于 2017-5-13 18:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void time2_init(void)
        TIM2_IER = 0x00; // 禁止中断
        TIM2_CNTRH = 0; //计数器初值设置
        TIM2_CNTRL = 0;
        #if(MAIN_CLOCK_SEL == MCU_CLOCK_8M)
        TIM2_PSCR = 0x03; //计数器时钟= 主时钟/ 8  =  8M / 8 = 1M(1us每周期)
        #else
        TIM2_PSCR = 0x02; //计数器时钟= 主时钟/ 4  =  4M / 4 = 1M(1us每周期)
        #endif
#if (ENABLE_IR_SEND)
        TIM2_ARRH = 0xFF;// 65535us
        TIM2_ARRL = 0xFF;
#else
        TIM2_ARRH = 0x03;//0xFF; // 65535us
        TIM2_ARRL = 0xE8;//0xFF;
#endif
        TIM2_EGR = 0x01;
#if (!ENABLE_IR_SEND)
        TIM2_IER  = 0x01;
#endif
        TIM2_CR1  = 0x01;
@far @interrupt void time2_irq_handler(void)
        TIM2_SR1 &= 0xFE;
