查看: 2113|回复: 0
按键程序
ID:203988 发表于 2017-5-23 18:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delayms(uint);
uchar numt0,num;
void display(uchar numdis)
        uchar shi,ge;
        shi=numdis/10;
        ge=numdis%10;
        dula=1;
        P0=table[shi];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delayms(5);
        dula=1;
        P0=table[ge];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfd;
        wela=0;
        delayms(5);
void delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
void init()
        TMOD=0x01;
        TH0=(65536-45872)/256;
        TL0=(65536-45872)%256;
        EA=1;
        ET0=1;
void keyscan()
        if(key1==0)
                delayms(10);
                if(key1==0)
                        num++;
                        if(num==60)
                                num=0;
                        while(!key1);
        if(key2==0)
                delayms(10);
                if(key2==0)
                        if(num==0)
                                num=60;
                                num--;
                                while(!key2);
        if(key3==0)
                delayms(10);
                if(key3==0)
                        num=0;
                        while(!key3);
        if(key4==0)
                delayms(10);
                if(key4==0)
                        while(!key4);
                        TR0=~TR0;
        init();
                keyscan();
                display(num);
void T0_time() interrupt 1
        numt0++;
        if(numt0==20)
                numt0=0;
                num++;
                if(num==60)
                        num=0;
