查看: 8019|回复: 2
PI3USB14引脚图,真值表,管脚功能与电路图 USB快速切换开关芯片资料
ID:207311 发表于 2017-6-3 10:25 | 显示全部楼层 |阅读模式
PI3USB14是一个4路高带宽 USB快速切换开关
Features
•    Near-Zero propagation delay
•    5Ω switches connect inputs to outputs
•  High signal passing bandwidth (300MHz)
•  Beyond Rail-to-Rail switching
•  5V I/O tolerant with 3.3V supply
•  2.5V and 3.3V supply voltage operation
•  Hot insertion capable
•  Industrial operating temperature: -40ºC to +85ºC
•  2KV ESD Protection (human body model)
•  Latch-up performance >250mA per JESD17
•    Packaging (Pb-free & Green available):
– 16-pin 150-mil wide plastic QSOP (Q)
– 16-pin 173-mil wide plastic TSSOP (L)
– 20-contact TQFN (ZH)
PI3USB14引脚图:
PI3USB14结构图
PI3USB14真值表:
PI3USB14管脚功能:
PI3USB14应用电路:
PI3USB14芯片的pdf资料下载地址:
PI3USB14_datasheet.pdf (475.3 KB, 下载次数: 8)
ID:1 发表于 2017-6-3 20:19 | 显示全部楼层
好资料,51黑有你更精彩!!!
好资料,51黑有你更精彩!!!
