查看: 2403|回复: 0
基于51单片机的测液滴控速 源程序
ID:207760 发表于 2017-6-4 19:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
uchar num=0,n=0;
int juli=0;
uint sudu=0,s=0,d=0;
sbit lcden=P1^5;  //使能端
sbit lcdrs=P1^6;        //液晶数据命令选择端1
sbit beep=P1^3;
//uchar code table[]={"0123456789"};
void int0_init(void);                //函数声明
*        外部中断0初始化子函数
*                                        下降沿触发,开启INT0中断,开总中断
void delayms(int x)
   int i,j;
   for(i=0;i<x;i++)
      for(j=0;j<110;j++);                                                         //1ms延时
void delayus(int t)
   while(t--);        //1us延时
        //液晶
void write_com(uchar com)
   lcdrs=0;
   P2=com;
   delayms(5);
   lcden=1;
   delayms(5);
   lcden=0;
void write_data(uchar date)
   lcdrs=1;
   P2=date;
   delayms(5);
   lcden=1;
   delayms(5);
   lcden=0;
void init()
   write_com(0x38);
   write_com(0x0c);
   write_com(0x06);
   write_com(0x01);
        IT0 = 1;                //下降沿触发
        EX0 = 1;                //开启INT0中断
        EA = 1;                        //开启总中断
void display()
        write_com(0x80);
        write_data('V');
        write_data('=');
//        write_data(0x30+sudu/10000);
        write_data(0x30+sudu%10000/1000);
        write_data(0x30+sudu%10000%1000/100);
        write_data(0x30+sudu%10000%1000%100/10);
        write_data(0x30+sudu%10);
        write_data('c');
        write_data('m');
        write_data('/');
        write_data('s');
        write_com(0x80+0x40);
        write_data('S');
    write_data('=');
        write_data(0x30+juli/10000);
        write_data(0x30+juli%10000/1000);
        write_data(0x30+juli%1000/100);
        write_data(0x30+juli%1000%100/10);
        write_data(0x30+juli%10);
        write_data('c');
    write_data('m');
//        write_data(' ');
//        write_data(0x30+i/1000);
//        write_data(0x30+i%1000/100);
//        write_data(0x30+i%1000%100/10);
//        write_data(0x30+i%10);
//主函数
void main(void)
    TMOD=0X01;
        EA=1;
        ET0=1;
    TH0=0xb8;
           TL0=0x00;
        TR0=0;
        int0_init();                //外部中断0初始化
        init();
             display();
                 if(sudu>220)  {beep=0;}
                   if(sudu<220)  {beep=1;}
        }                        //原地踏步
*        中断响应子函数
*                                        响应外部中断0,LED翻转,中断标志位自动清零
void int0_process() interrupt 0
         n++;
         d++;
         juli=2*d;
         TR0=1;
         IE0=0;
void time0() interrupt 1
    TH0=0xb8;//装初值
        TL0=0x00;//装初值
        num++;
        if(num==25)
          num=0;
          sudu=2*n;
          n=0;
