查看: 3709|回复: 0
lcd1602显示(时钟)可调分钟和小时 带单片机源代码与proteus
lcd显示基础代码,用来显示时钟,可调分钟和小时。
仿真原理图如下(proteus仿真工程文件可到本帖附件中下载):
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. uchar msec=0,sec=0,min=0,hr=0;
  6. sbit RS=P2^0;
  7. sbit RW=P2^1;
  8. sbit E =P2^2;
  9. uchar code dis[]  = {"  Welcome  to   "};
  10. //延时子程序
  11. void delay(uchar ms)
  12. {
  13.         uchar i;
  14.         while(ms--)
  15.         {
  16.                 for(i=0;i<250;i++);
  17.         }
  18. }
  19. //测试LCD忙状态
  20. bit lcd_bz()
  21. {
  22.         bit result;
  23.         E  = 0;
  24.         RS = 0;
  25.         RW = 1;
  26.         P0 = 0xFF;
  27.         E  = 1;
  28.         delay(1);
  29.         result = (bit)(P1&0x80);
  30.         E  = 0;
  31.         return result;
  32. }
  33. //写指令
  34. void lcd_wcmd(uchar cmd)
  35. {
  36.         E  = 0;
  37.         RS = 0;
  38.         delay(1);
  39.         RW = 0;
  40.         delay(1);
  41.         P0 = cmd;
  42.         delay(1);
  43.         E  = 1;
  44.         delay(1);
  45.         E  = 0;
  46. }
  47. //设定显示位置
  48. lcd_pos(uchar pos)
  49. {
  50.         lcd_wcmd(pos|0x80);
  51. }
  52. //写入字符
  53. void lcd_wdat(uchar dat)
  54. {
  55.         E  = 0;
  56.         RS = 1;
  57.         delay(1);
  58.         RW = 0;
  59.         delay(1);
  60.         P0 = dat;
  61.         delay(1);
  62.         E  = 1;
  63.         delay(1);
  64.         E  = 0;
  65. }
  66. //LCD初始化
  67. lcd_init()
  68. {
  69.         lcd_wcmd(0x38);// 模式设置
  70.         delay(1);
  71.         lcd_wcmd(0x0C);// 显示设置
  72.         delay(1);
  73.         lcd_wcmd(0x06);// 显示模式
  74.         delay(1);
  75.         lcd_wcmd(0x01);// 清屏
  76.         delay(1);
  77. }
  78. lcd_time(uchar t)
  79. {
  80.         lcd_wdat(t/10+48);
  81.         lcd_wdat(t%10+48);
  82. }
  83. //主程序
  84. void main(void)
  85. {
  86.         uchar n;
  87.         lcd_init();                //初始化
  88.         IE   = 0x87;
  89.         IP   = 0x05;
  90.         TH0  = (65536-50000)/256;
  91.         TL0         = (65536-50000)%256;
  92.         TMOD = 0x01;
  93.         TCON = 0x15;
  94.         delay(5);
  95.         lcd_pos(0x00);           //第一行显示
  96.         n = 0;
  97.         while(dis[n]!='\0')
  98.         {
  99.                 lcd_wdat(dis[n]);
  100.                 n++;
  101.         }
  102.         while(1)
  103.         {
  104.                 lcd_pos(0x44);
  105.                 lcd_time(hr);
  106.                 lcd_wdat(':');
  107.                 lcd_time(min);
  108.                 lcd_wdat(':');
  109.                 lcd_time(sec);
  110.         }
  111. }
  112. //外部中断0实现分钟加1
  113. void mplus() interrupt 0
  114. {
  115.         min++;
  116.         if(min==60)
  117.                 min = 0;
  118. }
  119. //外部中断1实现小时加1
  120. void hplus() interrupt 2
  121. {
  122.         hr++;
  123.         if(hr==24)
  124.                 hr = 0;
  125. }
  126. //定时中断计时
  127. void jishi() interrupt 1
  128. {
  129.         TH0  = (65536-50000)/256;
  130.         TL0         = (65536-50000)%256;
  131.         msec++;
  132.         if(msec==20)
  133. ……………………
  134. …………限于本文篇幅 余下代码请从51黑下载附件…………
lcd显示时钟.rar (59.63 KB, 下载次数: 33)
