查看: 11943|回复: 4
电子密码锁设计(原理图+程序)
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. void key_scan();
  5. ucharcount0,count1,count3,num,n=0,temp,a,j,count4;
  6. uchar mima[8];                                                       //初始密码存储区
  7. uchar tab_key[50];                                                //输入密码存储区
  8. uchar code table[]={
  9. 0x3f,0x06,0x5b,0x4f,
  10. 0x66,0x6d,0x7d,0x07,
  11. 0x7f,0x6f,0x77,0x7c,
  12. 0x39,0x5e,0x79,0x71};
  13. bit enterflag;                                                       //确认键按下与否的标志
  14. bit mimaflag;                                                        //密码正确与否的标志
  15. bit xiugaiflag;                                                       //修改密码标志
  16. bit enter1flag;                                               //修改密码确认键标志
  17. sbit red=P3^7;
  18. sbit bell=P3^6;
  19. sbit rs=P2^0;
  20. sbitrw=P2^1;
  21. sbit lcden=P2^2;
  22. sbit scl=P3^4;
  23. sbit sda=P3^5;
  24. uchar code table1[]="input thepassco";
  25. uchar code table2[]="de:     --------";
  26. uchar code table3[]="*";
  27. uchar code table4[]="right   (^_^)  ";
  28. uchar code table5[]="first  error!!!!";
  29. uchar code table6[]="seconderror!!!!";
  30. uchar code table7[]="third error see";
  31. uchar code table8[]="u tomorrow(^_^)";
  32. uchar code table9[]="define thepassc";
  33. uchar code table10[]="ode:    --------";
  34. uchar code table11[]="code   is   new";
  35. //******************************键盘消抖函数*******************************
  36. void delay1()
  37. { ;; }
  38. void delay2(uchar x)
  39. {
  40.        uchar a,b;
  41.        for(a=x;a>0;a--)
  42.         for(b=100;b>0;b--);
  43. }
  44.
  45. void delay(uint z)
  46. {
  47.        uint x,y;
  48.        for(x=z;x>0;x--)
  49.                 for(y=110;y>0;y--);
  50. }
  51. //****************************e^2room的初始化*******************************
  52. void start()  //开始信号
  53. {
  54.        sda=1;
  55.        delay1();
  56.        scl=1;
  57.        delay1();
  58.        sda=0;
  59.        delay1();
  60. }
  61. void stop()   //停止
  62. {
  63.        sda=0;
  64.        delay1();
  65.        scl=1;
  66.        delay1();
  67.        sda=1;
  68.        delay1();
  69. }
  70. //****************************应答信号*************************************
  71. void respond()
  72. {
  73.        uchar i;
  74.        scl=1;
  75.        delay1();
  76.        while((sda==1)&&(i<250))i++;
  77.        scl=0;
  78.        delay1();
  79. }
  80. //*****************************写字节操作函数**********************************
  81. void write_byte(uchar date)
  82. {
  83.        uchar i,temp;
  84.        temp=date;
  85.        for(i=0;i<8;i++)
  86.        {
  87.                 temp=temp<<1;                        //保持最高位,左移到进位CY
  88.                 scl=0;
  89.            delay1();
  90.                 sda=CY;
  91.                 delay1();
  92.                 scl=1;
  93.                 delay1();
  94.        }
  95.        scl=0;
  96.        delay1();
  97.        sda=1;//总线释放
  98.        delay1();
  99. }
  100. //*******************************读字节操作函数*****************************
  101. uchar read_byte()
  102. {
  103.        uchar i,k;
  104.        scl=0;
  105.        delay1();
  106.        sda=1;
  107.        delay1();
  108.        for(i=0;i<8;i++)
  109.        {
  110.                 scl=1;
  111.                 delay1();
  112.                 k=(k<<1)|sda;    //或运算,放到最低位
  113.                 scl=0;
  114.                 delay1();
  115.        }
  116.        return k;
  117. }
  118. //**********************************写地址函数******************************
  119. void write_add(uchar address,uchar date)
  120. {
  121.        start();
  122.        write_byte(0xa0);
  123.        respond();
  124.        write_byte(address);
  125.        respond();
  126.        write_byte(date);
  127.        respond();
  128.        stop();
  129. }
  130. //*******************************读地址函数*************************************
  131. uchar read_add(uchar address)
  132. {
  133.        uchar date;
  134.        start();
  135.        write_byte(0xa0);
  136.        respond();
  137.        write_byte(address);
  138.        respond();
  139.        start();
  140.        write_byte(0xa1);
  141.        respond();
  142.        date=read_byte();
  143.        stop();
  144.        return date;
  145. }
  146. //****************************LCD1602的初始化*******************************
  147. void write_com(uchar com)
  148. {
  149.        rs=0;
  150.        lcden=0;
  151.        P0=com;
  152.        delay(5);
  153.        lcden=1;
  154.        delay(5);
  155.        lcden=0;
  156. }
  157. void write_date(uchar date)
  158. {
  159.        rs=1;
  160.        lcden=0;
  161.        P0=date;
  162.        delay(5);
  163.        lcden=1;
  164.        delay(5);
  165.        lcden=0;
  166. }
  167. //***************************************密码比较函数********************************
  168. bit mimacmp()
  169. {
  170.        bit flag;
  171.        uchar i;
  172.        for(i=0;i<8;i++)
  173.                 {
  174.                         if(mima[ i]==tab_key[ i])
  175. [ i][ i]
  176.                                 flag=1;
  177.                         else
  178.                                 {
  179.                                 flag=0;
  180.                                 i=8;
  181.                                 }
  182.                 }
  183.        return(flag);                                                        //返回flag
  184. }
  185. ////**********************************LCD显示函数开始**************************************
  186. void lcd_display()
  187. {
  188. uchar i=0;
  189. write_com(0x80+0x40+8);
  190. for(i=0;i<n;i++)
  191. {
  192. write_date(table3[0]);
  193. }
  194. }
  195. //****************************************键盘功能分配函数群开始****************************
  196. //** 0 ** 1 **2 ** 3**
  197. //** 4** 5** 6 **7 **
  198. //**8** 9** 确认(A)  **无效(B)
  199. //**取消(C)**修改密码键(D)**确认修改键(E)**无效(F)
  200. void key_manage1()
  201. {
  202. tab_key[n]=0;
  203. n++;
  204. if(xiugaiflag==1)
  205. {
  206. mima[count4]=0;
  207. count4++;
  208. }
  209. }
  210. void key_manage2()
  211. {
  212. tab_key[n]=1;
  213. n++;
  214. if(xiugaiflag==1)
  215. {
  216. mima[count4]=1;
  217. count4++;
  218. }
  219. }
  220. void key_manage3()
  221. {
  222. tab_key[n]=2;
  223. n++;
  224. if(xiugaiflag==1)
  225. {
  226. mima[count4]=2;
  227. count4++;
  228. }
  229. }
  230. void key_manage4()
  231. {
  232. tab_key[n]=3;
  233. n++;
  234. if(xiugaiflag==1)
  235. {
  236. mima[count4]=3;
  237. count4++;
  238. }
  239. }
  240. void key_manage5()
  241. {
  242. tab_key[n]=4;
  243. n++;
  244. if(xiugaiflag==1)
  245. {
  246. mima[count4]=4;
  247. count4++;
  248. }
  249. }
  250. void key_manage6()
  251. {
  252. tab_key[n]=5;
  253. n++;
  254. if(xiugaiflag==1)
  255. {
  256. mima[count4]=5;
  257. count4++;
  258. }
  259. }
  260. void key_manage7()
  261. {
  262. tab_key[n]=6;
  263. n++;
  264. if(xiugaiflag==1)
  265. {
  266. mima[count4]=6;
  267. count4++;
  268. }
  269. }
  270. void key_manage8()
  271. {
  272. tab_key[n]=7;
  273. n++;
  274. if(xiugaiflag==1)
  275. {
  276. mima[count4]=7;
  277. count4++;
  278. }
  279. }
  280. void key_manage9()
  281. {
  282. tab_key[n]=8;
  283. n++;
  284. if(xiugaiflag==1)
  285. {
  286. mima[count4]=8;
  287. count4++;
  288. }
  289. }
  290. void key_manage10()
  291. {
  292. tab_key[n]=9;
  293. n++;
  294. if(xiugaiflag==1)
  295. {
  296. mima[count4]=9;
  297. count4++;
  298. }
  299. }
  300. //**********************************确认键**************************************************************
  301. void key_manage11()
  302. {
  303.        enterflag=1;                                        //确认键按下
  304.        if(n==8)                                           //只有输入8个密码后按确认才做比较
  305.                 mimaflag=mimacmp();
  306.        else
  307.                 mimaflag=0;
  308.         if(enterflag==1)
  309.                 {
  310.                         enterflag=0;
  311.                         n=0;
  312.                         //用FFFFFFFF清除已经输入的密码
  313.                        for(count3=0;count3<8;count3++)
  314.                         {
  315.                                 delay(5);
  316.                                tab_key[count3]=0x0f;
  317.                         }
  318.
  319.                         TR1=1;        //打开计数器1
  320.                         count1=0;        //定时器1由50MS累计到1S所用的计数器
  321.                         if(mimaflag==1)
  322.                         {
  323.                                 a=0;
  324.
  325.                                 write_com(0x01);
  326.                                write_com(0x80);
  327.                                for(count3=0;count3<16;count3++)
  328.                                 {
  329.                                        write_date(table4[count3]);       //密码正确,显示RIGHT,绿灯亮
  330.                                        delay(5);
  331.                                 }
  332.                         }
  333.
  334.                     else
  335.                         {
  336.                                  n=0;
  337.                                  red=0;
  338.                             bell=0;
  339.                                 a++;
  340.                                 if(a==1)
  341.                                 {
  342.                                        for(count3=0;count3<8;count3++) //ffffffff清除密码
  343.                                         {
  344.                                                delay(5);
  345.                                                tab_key[count3]=0x0f;
  346.                                         }
  347.                                        write_com(0x01);
  348.                                        write_com(0x80);
  349.                                        for(count3=0;count3<16;count3++)
  350.                                         {
  351.                                                write_date(table5[count3]);       //密码错误,显示 first error,红灯亮
  352.                                                delay(5);
  353.                                         }
  354.                                                TR1=1;
  355.                                 }
  356.                                 if(a==2)
  357.                                 {
  358.                                        for(count3=0;count3<8;count3++) //ffffffff清除密码
  359.                                         {
  360.                                                delay(5);
  361.                                                tab_key[count3]=0x0f;
  362.                                         }
  363.                                                write_com(0x01);
  364.                                                write_com(0x80);
  365.                                                for(count3=0;count3<16;count3++)
  366.                                                {
  367.                                                        write_date(table6[count3]);       //密码错误,显示SECOND ERROR,红灯亮
  368.                                                        delay(5);
  369.                                                }
  370.                                                         TR1=1;
  371.                                 }
  372.
  373.                                   if(a==3)
  374.                                         {
  375.                                                for(count3=0;count3<8;count3++) //ffffffff清除密码
  376.                                                {
  377.                                                        delay(5);
  378.                                                        tab_key[count3]=0x0f;
  379.                                                }
  380.                                                write_com(0x01);
  381.                                                write_com(0x80);
  382.                                                for(count3=0;count3<16;count3++)
  383.                                                {
  384.                                                        write_date(table7[count3]);       //密码错误,显示third error see,红灯亮
  385.                                                        delay(5);
  386.                                                }
  387.                                                write_com(0x80+0x40);
  388.                                                for(count3=0;count3<16;count3++)
  389.                                                {
  390.                                                        write_date(table8[count3]);//密码错误,显示 UTOMORROW ,红灯亮
  391.                                                        delay(5);
  392.                                                }
  393.                                                        TR1=0;
  394.
  395.                                         }
  396.
  397.                 }
  398.        }
  399. }
  400. void key_manage12()
  401. {
  402. tab_key[n]=11;
  403. n++;                                                 //密码计数清零
  404. }
  405. //****************************************************取消键********************************************
  406. void key_manage13()
  407. {
  408. n=0;                                                  //密码计数清零
  409. write_com(0x80);                                               //指针所指位置
  410. for(count3=0;count3<16;count3++)
  411. {
  412.        write_date(table1[count3]);                //第一行显示INPUTTHE PASSPORD:
  413.        delay(5);
  414. }
  415. write_com(0x80+0x40);
  416. for(count3=0;count3<16;count3++)
  417. {
  418.        write_date(table2[count3]);       //开机显示--------
  419.        delay(5);
  420.        tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已经输入的密码
  421. }
  422. }
  423. //*******************************************修改密码键**********************************
  424. void key_manage14()
  425. {
  426.        uchar aa=0;
  427.        n=0;
  428.        xiugaiflag=1;
  429.        write_com(0x01);
  430.        write_com(0x80);
  431. for(count3=0;count3<16;count3++)
  432. {
  433.        write_date(table9[count3]);       //显示define the password
  434.        delay(5);
  435.        tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已经输入的密码
  436. }
  437.        write_com(0x80+0x40);
  438. for(count3=0;count3<16;count3++)
  439. {
  440.        write_date(table10[count3]);       //显示--------
  441.        delay(5);
  442. }
  443. TR0=1;
  444. }
  445. //******************************************修改密码键的确认键********************************
  446. void key_manage15()
  447. {
  448. n=0;
  449. enter1flag=1;
  450. if(enter1flag==1)
  451. {
  452.        enter1flag=0;
  453.        count4=0;
  454.        for(count3=0;count3<16;count3++)
  455.        {
  456.        tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已经输入的密码
  457.         }
  458.        write_com(0x01);
  459.        write_com(0x80);
  460.        for(count3=0;count3<16;count3++)
  461.        {
  462.                 write_date(table11[count3]);
  463.                 delay(100);
  464.        }
  465.        TR1=1;
  466.        count1=0;
  467. }
  468. }
  469. void key_manage16()
  470. {
  471. tab_key[n]=15;
  472. n++;
  473. }
  474. //****************************************定时器1的50MS,共延时1秒*****************************
  475. void time_1() interrupt 3
  476. {
  477.        TH1=(65536-50000)/256;
  478.        TL1=(65536-50000)%256;
  479.        if(count1<20)
  480.        {
  481.                 count1++;
  482.        }
  483.        else                                                        //计时到1S
  484.        {
  485.                 TR1=0;
  486.                 count1=0;
  487.                 mimaflag=0;
  488.                 red=1;
  489.                 bell=1;
  490.                 //显示FFFFFFFF
  491.                 write_com(0x01);
  492.                 write_com(0x80);
  493.                for(count3=0;count3<16;count3++)
  494.                         {
  495.                                 write_date(table1[count3]);        //显示INPUT THE PASSCODE
  496.                                 delay(5);
  497.                         }
  498.                 write_com(0x80+0x40);
  499.                for(count3=0;count3<16;count3++)
  500.                         {
  501.                                write_date(table2[count3]);       //开机显示FFFFFFFF
  502.                                 delay(5);
  503.                         }
  504.        }
  505. }
  506. //***********************************************定时0**********************************************
  507. void time_0() interrupt 1
  508. {
  509.        TH0=(65536-50000)/256;
  510.        TL0=(65536-50000)%256;
  511. if(count4<8)
  512. {
  513.        key_scan();
  514. }
  515. else
  516. {
  517.        TR0=0;
  518.        count4=0;
  519. }
  520. }
  521. //初始化函数
  522. void init()
  523. {
  524.        uchar i;
  525.        lcden=0;
  526.        write_com(0x38);                                        //打开显示模式设置
  527.        write_com(0x0c);                                        //打开显示,光标等等设置未零
  528.        write_com(0x06);                                        //当读或写一个字符后地址指针加一,且光标加一,当写一个字符后整频显示左移,
  529.        write_com(0x01);                                        //清零指令
  530.        write_com(0x80);                                        //指针所指位置
  531.        //定时器初始化
  532.        TMOD=0x11;                                                       //T0,T1工作方式1
  533.         TH0=(65536-2000)/256;
  534.        TL0=(65536-2000)%256;                                //T0初始化2MS
  535.        TH1=(65536-50000)/256;
  536.        TL1=(65536-50000)%256;                                //T1初始化50MS
  537.        TR1=0;
  538.        ET1=1;
  539.        EA=1;
  540.        TR0=0;
  541.        ET0=1;
  542.        count0=0;                                                       //初始没有密码输入,故为零
  543.        enterflag=0;                                               //没有确认键按下
  544.        mimaflag=0;                                                       //密码正确与否键先置零
  545.
  546.        red=1;                                                               //红灯不亮
  547. //************密码存入EPROM中**********************************
  548.        sda=1;
  549.        delay(5);
  550.        scl=1;
  551.        delay(5);
  552.        for(i=0;i<8;i++)
  553.        {
  554.                 write_add(i,8);
  555.                 delay2(100);
  556.        }
  557.        for(i=0;i<8;i++)
  558.        {
  559.                 mima[ i]=read_add(i);
  560. [ i]
  561.                 delay(5);
  562.        }
  563. }
  564. void main()
  565. {       rw=0;
  566.        init();
  567.        write_com(0x80);                                               //指针所指位置
  568.        for(count3=0;count3<16;count3++)
  569.        {
  570.                write_date(table1[count3]);                //第一行显示INPUTTHE PASSPORD:
  571.                 delay(5);
  572.        }
  573.        write_com(0x80+0x40);
  574.        for(count3=0;count3<16;count3++)
  575.        {
  576.                write_date(table2[count3]);                //开机显示FFFFFFFF
  577.                 delay(5);
  578.        }
  579.        while(1)
  580.        {
  581.                 key_scan();                                                     //调用键盘扫描函数
  582.                 lcd_display();
  583.        }
  584.
  585. }
  586. //**************************************************键盘扫描函数开始********************************
  587. void key_scan()
  588. {
  589. //**********扫描第一行*********
  590. P1=0xfe;
  591. temp=P1;
  592. temp=temp&0xf0;
  593. if(temp!=0xf0)
  594. {
  595. delay(100);
  596. if(temp!=0xf0)
  597. {
  598. temp=P1;
  599. switch(temp)
  600. {
  601. case 0xee:
  602. key_manage1();
  603. break;
  604. case 0xde:
  605. key_manage2();
  606. break;
  607. case 0xbe:
  608. key_manage3();
  609. break;
  610. case 0x7e:
  611. key_manage4();
  612. break;
  613. }
  614. while(temp!=0xf0)
  615. {
  616. temp=P1;
  617. temp=temp&0xf0;
  618. }
  619. }
  620. }
  621. //**************************************************扫描第二行***********************************
  622. P1=0xfd;
  623. temp=P1;
  624. temp=temp&0xf0;
  625. if(temp!=0xf0)
  626. {
  627. delay(100);
  628. if(temp!=0xf0)
  629. {
  630. temp=P1;
  631. switch(temp)
  632. {
  633. case 0xed:
  634. key_manage5();
  635. break;
  636. case 0xdd:
  637. key_manage6();
  638. break;
  639. case 0xbd:
  640. key_manage7();
  641. break;
  642. case 0x7d:
  643. key_manage8();
  644. break;
  645. }
  646. while(temp!=0xf0)
  647. {
  648. temp=P1;
  649. temp=temp&0xf0;
  650. }
  651. }
  652. }
  653. //*********************************************扫描第三行***********************************
  654. P1=0xfb;
  655. temp=P1;
  656. temp=temp&0xf0;
  657. if(temp!=0xf0)
  658. {
  659. delay(100);
  660. if(temp!=0xf0)
  661. {
  662. temp=P1;
  663. switch(temp)
  664. {
  665. case 0xeb:
  666. key_manage9();
  667. break;
  668. case 0xdb:
  669. key_manage10();
  670. break;
  671. case 0xbb:
  672. key_manage11();
  673. break;
  674. case 0x7b:
  675. key_manage12();
  676. break;
  677. }
  678. while(temp!=0xf0)
  679. {
  680. temp=P1;
  681. temp=temp&0xf0;
  682. }
  683. }
  684. }
  685. //***************************************************扫描第四行****************************************
  686. P1=0xf7;
  687. temp=P1;
  688. temp=temp&0xf0;
  689. if(temp!=0xf0)
  690. {
  691. delay(100);
  692. if(temp!=0xf0)
  693. {
  694. temp=P1;
  695. switch(temp)
  696. {
  697. case 0xe7:
  698. key_manage13();
  699. break;
  700. case 0xd7:
  701. key_manage14();
  702. break;
  703. case 0xb7:
  704. key_manage15();
  705. break;
  706. case 0x77:
  707. key_manage16();
  708. break;
  709. }
  710. while(temp!=0xf0)
  711. {
  712. temp=P1;
  713. temp=temp&0xf0;
  714. }
  715. }
  716. }
  717. }
  718. #include<reg52.h>
  719. #define uint unsigned int
  720. #define uchar unsigned char
  721. void key_scan();
  722. ucharcount0,count1,count3,num,n=0,temp,a,j,count4;
  723. uchar mima[8];                                                       //初始密码存储区
  724. uchar tab_key[50];                                                //输入密码存储区
  725. uchar code table[]={
  726. 0x3f,0x06,0x5b,0x4f,
  727. 0x66,0x6d,0x7d,0x07,
  728. 0x7f,0x6f,0x77,0x7c,
  729. 0x39,0x5e,0x79,0x71};
  730. bit enterflag;                                                       //确认键按下与否的标志
  731. bit mimaflag;                                                        //密码正确与否的标志
  732. bit xiugaiflag;                                                       //修改密码标志
  733. bit enter1flag;                                               //修改密码确认键标志
  734. sbit red=P3^7;
  735. sbit bell=P3^6;
  736. sbit rs=P2^0;
  737. sbitrw=P2^1;
  738. sbit lcden=P2^2;
  739. sbit scl=P3^4;
  740. sbit sda=P3^5;
  741. uchar code table1[]="input thepassco";
  742. uchar code table2[]="de:     --------";
  743. uchar code table3[]="*";
  744. uchar code table4[]="right   (^_^)  ";
  745. uchar code table5[]="first  error!!!!";
  746. uchar code table6[]="seconderror!!!!";
  747. uchar code table7[]="third error see";
  748. uchar code table8[]="u tomorrow(^_^)";
  749. uchar code table9[]="define thepassc";
  750. uchar code table10[]="ode:    --------";
  751. uchar code table11[]="code   is   new";
  752. //******************************键盘消抖函数*******************************
  753. void delay1()
  754. { ;; }
  755. void delay2(uchar x)
  756. {
  757.        uchar a,b;
  758.        for(a=x;a>0;a--)
  759.         for(b=100;b>0;b--);
  760. }
  761. void delay(uint z)
  762. {
  763.        uint x,y;
  764.        for(x=z;x>0;x--)
  765.                 for(y=110;y>0;y--);
  766. }
  767. //****************************e^2room的初始化*******************************
  768. void start()  //开始信号
  769. {
  770.        sda=1;
  771.        delay1();
  772.        scl=1;
  773.        delay1();
  774.        sda=0;
  775.        delay1();
  776. }
  777. void stop()   //停止
  778. {
  779.        sda=0;
  780.        delay1();
  781.        scl=1;
  782.        delay1();
  783.        sda=1;
  784.        delay1();
  785. }
  786. //****************************应答信号*************************************
  787. void respond()
  788. {
  789.        uchar i;
  790.        scl=1;
  791.        delay1();
  792.        while((sda==1)&&(i<250))i++;
  793.        scl=0;
  794.        delay1();
  795. }
  796. //*****************************写字节操作函数**********************************
  797. void write_byte(uchar date)
  798. {
  799.        uchar i,temp;
  800.        temp=date;
  801.        for(i=0;i<8;i++)
  802.        {
  803.                 temp=temp<<1;                        //保持最高位,左移到进位CY
  804.                 scl=0;
  805.            delay1();
  806.                 sda=CY;
  807.                 delay1();
  808.                 scl=1;
  809.                 delay1();
  810.        }
  811.        scl=0;
  812.        delay1();
  813.        sda=1;//总线释放
  814.        delay1();
  815. }
  816. //*******************************读字节操作函数*****************************
  817. uchar read_byte()
  818. {
  819.        uchar i,k;
  820.        scl=0;
  821.        delay1();
  822.        sda=1;
  823.        delay1();
  824.        for(i=0;i<8;i++)
  825.        {
  826.                 scl=1;
  827.                 delay1();
  828.                 k=(k<<1)|sda;    //或运算,放到最低位
  829.                 scl=0;
  830.                 delay1();
  831.        }
  832.        return k;
  833. }
  834. //**********************************写地址函数******************************
  835. void write_add(uchar address,uchar date)
  836. {
  837.        start();
  838.        write_byte(0xa0);
  839.        respond();
  840.        write_byte(address);
  841.        respond();
  842.        write_byte(date);
  843.        respond();
  844.        stop();
  845. }
  846. //*******************************读地址函数*************************************
  847. uchar read_add(uchar address)
  848. {
  849.        uchar date;
  850.        start();
  851.        write_byte(0xa0);
  852.        respond();
  853.        write_byte(address);
  854.        respond();
  855.        start();
  856.        write_byte(0xa1);
  857.        respond();
  858.        date=read_byte();
  859.        stop();
  860.        return date;
  861. }
  862. //****************************LCD1602的初始化*******************************
  863. void write_com(uchar com)
  864. {
  865.        rs=0;
  866.        lcden=0;
  867.        P0=com;
  868.        delay(5);
  869.        lcden=1;
  870.        delay(5);
  871.        lcden=0;
  872. }
  873. void write_date(uchar date)
  874. {
  875.        rs=1;
  876.        lcden=0;
  877.        P0=date;
  878.        delay(5);
  879.        lcden=1;
  880.        delay(5);
  881.        lcden=0;
  882. }
  883. //***************************************密码比较函数********************************
  884. bit mimacmp()
  885. {
  886.        bit flag;
  887.        uchar i;
  888.        for(i=0;i<8;i++)
  889.                 {
  890.                         if(mima[ i]==tab_key[ i])
  891. [ i][ i]
  892.                                 flag=1;
  893.                         else
  894.                                 {
  895.                                 flag=0;
  896.                                 i=8;
  897.                                 }
  898.                 }
  899.        return(flag);                                                        //返回flag
  900. }
  901. ////**********************************LCD显示函数开始**************************************
  902. void lcd_display()
  903. {
  904. uchar i=0;
  905. write_com(0x80+0x40+8);
  906. for(i=0;i<n;i++)
  907. {
  908. write_date(table3[0]);
  909. }
  910. }
  911. //****************************************键盘功能分配函数群开始****************************
  912. //** 0 ** 1 **2 ** 3**
  913. //** 4** 5** 6 **7 **
  914. //**8** 9** 确认(A)  **无效(B)
  915. //**取消(C)**修改密码键(D)**确认修改键(E)**无效(F)
  916. void key_manage1()
  917. {
  918. tab_key[n]=0;
  919. n++;
  920. if(xiugaiflag==1)
  921. {
  922. mima[count4]=0;
  923. count4++;
  924. }
  925. }
  926. void key_manage2()
  927. {
  928. tab_key[n]=1;
  929. n++;
  930. if(xiugaiflag==1)
  931. {
  932. mima[count4]=1;
  933. count4++;
  934. }
  935. }
  936. void key_manage3()
  937. {
  938. tab_key[n]=2;
  939. n++;
  940. if(xiugaiflag==1)
  941. {
  942. mima[count4]=2;
  943. count4++;
  944. }
  945. }
  946. void key_manage4()
  947. {
  948. tab_key[n]=3;
  949. n++;
  950. if(xiugaiflag==1)
  951. {
  952. mima[count4]=3;
  953. count4++;
  954. }
  955. }
  956. void key_manage5()
  957. {
  958. tab_key[n]=4;
  959. n++;
  960. if(xiugaiflag==1)
  961. {
  962. mima[count4]=4;
  963. count4++;
  964. }
  965. }
  966. void key_manage6()
  967. {
  968. tab_key[n]=5;
  969. n++;
  970. if(xiugaiflag==1)
  971. {
  972. mima[count4]=5;
  973. count4++;
  974. }
  975. }
  976. void key_manage7()
  977. {
  978. tab_key[n]=6;
  979. n++;
  980. if(xiugaiflag==1)
  981. {
  982. mima[count4]=6;
  983. count4++;
  984. }
  985. }
  986. void key_manage8()
  987. {
  988. tab_key[n]=7;
  989. n++;
  990. if(xiugaiflag==1)
  991. {
  992. mima[count4]=7;
  993. count4++;
  994. }
  995. }
  996. void key_manage9()
  997. {
  998. tab_key[n]=8;
  999. n++;
  1000. if(xiugaiflag==1)
  1001. {
  1002. mima[count4]=8;
  1003. count4++;
  1004. }
  1005. }
  1006. void key_manage10()
  1007. {
  1008. tab_key[n]=9;
  1009. n++;
  1010. if(xiugaiflag==1)
  1011. {
  1012. mima[count4]=9;
  1013. count4++;
  1014. }
  1015. }
  1016. //**********************************确认键**************************************************************
  1017. void key_manage11()
  1018. {
  1019.        enterflag=1;                                        //确认键按下
  1020.        if(n==8)                                           //只有输入8个密码后按确认才做比较
  1021.                 mimaflag=mimacmp();
  1022.        else
  1023.                 mimaflag=0;
  1024.         if(enterflag==1)
  1025.                 {
  1026.                         enterflag=0;
  1027.                         n=0;
  1028.                         //用FFFFFFFF清除已经输入的密码
  1029.                        for(count3=0;count3<8;count3++)
  1030.                         {
  1031.                                 delay(5);
  1032.                                tab_key[count3]=0x0f;
  1033.                         }
  1034.                         TR1=1;        //打开计数器1
  1035.                         count1=0;        //定时器1由50MS累计到1S所用的计数器
  1036.                         if(mimaflag==1)
  1037.                         {
  1038.                                 a=0;
  1039.                                 write_com(0x01);
  1040.                                write_com(0x80);
  1041.                                for(count3=0;count3<16;count3++)
  1042.                                 {
  1043.                                        write_date(table4[count3]);       //密码正确,显示RIGHT,绿灯亮
  1044.                                        delay(5);
  1045.                                 }
  1046.                         }
  1047.                     else
  1048.                         {
  1049.                                  n=0;
  1050.                                  red=0;
  1051.                             bell=0;
  1052.                                 a++;
  1053.                                 if(a==1)
  1054.                                 {
  1055.                                        for(count3=0;count3<8;count3++) //ffffffff清除密码
  1056.                                         {
  1057.                                                delay(5);
  1058.                                                tab_key[count3]=0x0f;
  1059.                                         }
  1060.                                        write_com(0x01);
  1061.                                        write_com(0x80);
  1062.                                        for(count3=0;count3<16;count3++)
  1063.                                         {
  1064.                                                write_date(table5[count3]);       //密码错误,显示 first error,红灯亮
  1065.                                                delay(5);
  1066.                                         }
  1067.                                                TR1=1;
  1068.                                 }
  1069.                                 if(a==2)
  1070.                                 {
  1071.                                        for(count3=0;count3<8;count3++) //ffffffff清除密码
  1072.                                         {
  1073.                                                delay(5);
  1074.                                                tab_key[count3]=0x0f;
  1075.                                         }
  1076.                                                write_com(0x01);
  1077.                                                write_com(0x80);
  1078.                                                for(count3=0;count3<16;count3++)
  1079.                                                {
  1080.                                                        write_date(table6[count3]);       //密码错误,显示SECOND ERROR,红灯亮
  1081.                                                        delay(5);
  1082.                                                }
  1083.                                                         TR1=1;
  1084.                                 }
  1085.                                   if(a==3)
  1086.                                         {
  1087.                                                for(count3=0;count3<8;count3++) //ffffffff清除密码
  1088.                                                {
  1089.                                                        delay(5);
  1090.                                                        tab_key[count3]=0x0f;
  1091.                                                }
  1092.                                                write_com(0x01);
  1093.                                                write_com(0x80);
  1094.                                                for(count3=0;count3<16;count3++)
  1095.                                                {
  1096.                                                        write_date(table7[count3]);       //密码错误,显示third error see,红灯亮
  1097.                                                        delay(5);
  1098.                                                }
  1099.                                                write_com(0x80+0x40);
  1100.                                                for(count3=0;count3<16;count3++)
  1101.                                                {
  1102.                                                        write_date(table8[count3]);//密码错误,显示 UTOMORROW ,红灯亮
  1103.                                                        delay(5);
  1104.                                                }
  1105.                                                        TR1=0;
  1106.                                         }
  1107.                 }
  1108.        }
  1109. }
  1110. void key_manage12()
  1111. {
  1112. tab_key[n]=11;
  1113. n++;                                                 //密码计数清零
  1114. }
  1115. //****************************************************取消键********************************************
  1116. void key_manage13()
  1117. {
  1118. n=0;                                                  //密码计数清零
  1119. write_com(0x80);                                               //指针所指位置
  1120. for(count3=0;count3<16;count3++)
  1121. {
  1122.        write_date(table1[count3]);                //第一行显示INPUTTHE PASSPORD:
  1123.        delay(5);
  1124. }
  1125. write_com(0x80+0x40);
  1126. for(count3=0;count3<16;count3++)
  1127. {
  1128.        write_date(table2[count3]);       //开机显示--------
  1129.        delay(5);
  1130.        tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已经输入的密码
  1131. }
  1132. }
  1133. //*******************************************修改密码键**********************************
  1134. void key_manage14()
  1135. {
  1136.        uchar aa=0;
  1137.        n=0;
  1138.        xiugaiflag=1;
  1139.        write_com(0x01);
  1140.        write_com(0x80);
  1141. for(count3=0;count3<16;count3++)
  1142. {
  1143.        write_date(table9[count3]);       //显示define the password
  1144.        delay(5);
  1145.        tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已经输入的密码
  1146. }
  1147.        write_com(0x80+0x40);
  1148. for(count3=0;count3<16;count3++)
  1149. {
  1150.        write_date(table10[count3]);       //显示--------
  1151.        delay(5);
  1152. }
  1153. TR0=1;
  1154. }
  1155. //******************************************修改密码键的确认键********************************
  1156. void key_manage15()
  1157. {
  1158. n=0;
  1159. enter1flag=1;
  1160. if(enter1flag==1)
  1161. {
  1162.        enter1flag=0;
  1163.        count4=0;
  1164.        for(count3=0;count3<16;count3++)
  1165.        {
  1166.        tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已经输入的密码
  1167.         }
  1168.        write_com(0x01);
  1169.        write_com(0x80);
  1170.        for(count3=0;count3<16;count3++)
  1171.        {
  1172.                 write_date(table11[count3]);
  1173.                 delay(100);
  1174.        }
  1175.        TR1=1;
  1176.        count1=0;
  1177. }
  1178. }
  1179. void key_manage16()
  1180. {
  1181. tab_key[n]=15;
  1182. n++;
  1183. }
  1184. //****************************************定时器1的50MS,共延时1秒*****************************
  1185. void time_1() interrupt 3
  1186. {
  1187.        TH1=(65536-50000)/256;
  1188.        TL1=(65536-50000)%256;
  1189.        if(count1<20)
  1190.        {
  1191.                 count1++;
  1192.        }
  1193.        else                                                        //计时到1S
  1194.        {
  1195.                 TR1=0;
  1196.                 count1=0;
  1197.                 mimaflag=0;
  1198.                 red=1;
  1199.                 bell=1;
  1200.                 //显示FFFFFFFF
  1201.                 write_com(0x01);
  1202.                 write_com(0x80);
  1203.                for(count3=0;count3<16;count3++)
  1204.                         {
  1205.                                 write_date(table1[count3]);        //显示INPUT THE PASSCODE
  1206.                                 delay(5);
  1207.                         }
  1208.                 write_com(0x80+0x40);
  1209.                for(count3=0;count3<16;count3++)
  1210.                         {
  1211.                                write_date(table2[count3]);       //开机显示FFFFFFFF
  1212.                                 delay(5);
  1213.                         }
  1214.        }
  1215. }
  1216. //***********************************************定时0**********************************************
  1217. void time_0() interrupt 1
  1218. {
  1219.        TH0=(65536-50000)/256;
  1220.        TL0=(65536-50000)%256;
  1221. if(count4<8)
  1222. {
  1223.        key_scan();
  1224. }
  1225. else
  1226. {
  1227.        TR0=0;
  1228.        count4=0;
  1229. }
  1230. }
  1231. //初始化函数
  1232. void init()
  1233. {
  1234.        uchar i;
  1235.        lcden=0;
  1236.        write_com(0x38);                                        //打开显示模式设置
  1237.        write_com(0x0c);                                        //打开显示,光标等等设置未零
  1238.        write_com(0x06);                                        //当读或写一个字符后地址指针加一,且光标加一,当写一个字符后整频显示左移,
  1239.        write_com(0x01);                                        //清零指令
  1240.        write_com(0x80);                                        //指针所指位置
  1241.        //定时器初始化
  1242.        TMOD=0x11;                                                       //T0,T1工作方式1
  1243.         TH0=(65536-2000)/256;
  1244.        TL0=(65536-2000)%256;                                //T0初始化2MS
  1245.        TH1=(65536-50000)/256;
  1246.        TL1=(65536-50000)%256;                                //T1初始化50MS
  1247.        TR1=0;
  1248.        ET1=1;
  1249.        EA=1;
  1250.        TR0=0;
  1251.        ET0=1;
  1252.        count0=0;                                                       //初始没有密码输入,故为零
  1253.        enterflag=0;                                               //没有确认键按下
  1254.        mimaflag=0;                                                       //密码正确与否键先置零
  1255.        red=1;                                                               //红灯不亮
  1256. //************密码存入EPROM中**********************************
  1257.        sda=1;
  1258.        delay(5);
  1259.        scl=1;
  1260.        delay(5);
  1261.        for(i=0;i<8;i++)
  1262.        {
  1263.                 write_add(i,8);
  1264.                 delay2(100);
  1265.        }
  1266.        for(i=0;i<8;i++)
  1267.        {
  1268.                 mima[ i]=read_add(i);
  1269. [ i]
  1270.                 delay(5);
  1271.        }
  1272. }
  1273. void main()
  1274. {       rw=0;
  1275.        init();
  1276.        write_com(0x80);                                               //指针所指位置
  1277.        for(count3=0;count3<16;count3++)
  1278.        {
  1279.                write_date(table1[count3]);                //第一行显示INPUTTHE PASSPORD:
  1280.                 delay(5);
  1281.        }
  1282.        write_com(0x80+0x40);
  1283.        for(count3=0;count3<16;count3++)
  1284.        {
  1285.                write_date(table2[count3]);                //开机显示FFFFFFFF
  1286.                 delay(5);
  1287.        }
  1288.        while(1)
  1289.        {
  1290.                 key_scan();                                                     //调用键盘扫描函数
  1291.                 lcd_display();
  1292.        }
  1293. }
  1294. //**************************************************键盘扫描函数开始********************************
  1295. void key_scan()
  1296. {
  1297. //**********扫描第一行*********
  1298. P1=0xfe;
  1299. temp=P1;
  1300. temp=temp&0xf0;
  1301. if(temp!=0xf0)
  1302. {
  1303. delay(100);
  1304. if(temp!=0xf0)
  1305. {
  1306. temp=P1;
  1307. switch(temp)
  1308. {
  1309. case 0xee:
  1310. key_manage1();
  1311. break;
  1312. case 0xde:
  1313. key_manage2();
  1314. break;
  1315. case 0xbe:
  1316. key_manage3();
  1317. break;
  1318. case 0x7e:
  1319. key_manage4();
  1320. break;
  1321. }
  1322. while(temp!=0xf0)
  1323. {
  1324. temp=P1;
  1325. temp=temp&0xf0;
  1326. }
  1327. }
  1328. }
  1329. //**************************************************扫描第二行***********************************
  1330. P1=0xfd;
  1331. temp=P1;
  1332. temp=temp&0xf0;
  1333. if(temp!=0xf0)
  1334. {
  1335. delay(100);
  1336. if(temp!=0xf0)
  1337. {
  1338. temp=P1;
  1339. switch(temp)
  1340. {
  1341. case 0xed:
  1342. key_manage5();
  1343. break;
  1344. case 0xdd:
  1345. key_manage6();
  1346. break;
  1347. case 0xbd:
  1348. key_manage7();
  1349. break;
  1350. case 0x7d:
  1351. key_manage8();
  1352. break;
  1353. }
  1354. while(temp!=0xf0)
  1355. {
  1356. temp=P1;
  1357. temp=temp&0xf0;
  1358. }
  1359. }
  1360. }
  1361. //*********************************************扫描第三行***********************************
  1362. P1=0xfb;
  1363. temp=P1;
  1364. temp=temp&0xf0;
  1365. if(temp!=0xf0)
  1366. {
  1367. delay(100);
  1368. if(temp!=0xf0)
  1369. {
  1370. temp=P1;
  1371. switch(temp)
  1372. {
  1373. case 0xeb:
  1374. key_manage9();
  1375. break;
  1376. case 0xdb:
  1377. key_manage10();
  1378. break;
  1379. case 0xbb:
  1380. key_manage11();
  1381. break;
  1382. case 0x7b:
  1383. key_manage12();
  1384. break;
  1385. }
  1386. while(temp!=0xf0)
  1387. {
  1388. temp=P1;
  1389. temp=temp&0xf0;
  1390. }
  1391. }
  1392. }
  1393. //***************************************************扫描第四行****************************************
  1394. P1=0xf7;
  1395. temp=P1;
  1396. temp=temp&0xf0;
  1397. if(temp!=0xf0)
  1398. {
  1399. delay(100);
  1400. if(temp!=0xf0)
  1401. {
  1402. temp=P1;
  1403. switch(temp)
  1404. {
  1405. case 0xe7:
  1406. key_manage13();
  1407. break;
  1408. case 0xd7:
  1409. key_manage14();
  1410. break;
  1411. case 0xb7:
  1412. key_manage15();
  1413. break;
  1414. case 0x77:
  1415. key_manage16();
  1416. break;
  1417. }
  1418. while(temp!=0xf0)
  1419. {
  1420. temp=P1;
  1421. temp=temp&0xf0;
  1422. }
  1423. }
  1424. }
  1425. }
ID:421848 发表于 2018-11-6 16:50 | 只看该作者
你厉害+++
ID:254123 发表于 2018-11-7 12:57 | 只看该作者
大佬大佬
ID:287482 发表于 2018-11-25 10:57 | 只看该作者
大佬可以发一张高清点的原理图吗
ID:467935 发表于 2019-1-14 14:53 | 只看该作者
能发清晰一点的原理图吗
