查看: 2585|回复: 0
蓝牙程序
ID:217649 发表于 2017-7-7 15:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include "delay.h"
sbit RS = P2^2;
sbit RW = P2^1;
sbit E  = P2^0;
sbit RES = P2^5;
sbit PSB = P2^3;
#define DataPort P0        //MCU P0<------> LCM
unsigned char code user16x16[]={ //笑脸图片
0x0F,0xF0,0x10,0x08,0x20,0x04,0x40,0x02,0x9C,0x39,0xBE,0x7D,0x80,0x01,0x80,0x01,
0x80,0x01,0x88,0x11,0x84,0x21,0x43,0xC2,0x20,0x04,0x10,0x08,0x0F,0xF0,0x00,0x00,
                    检测忙位
void Check_Busy()
    RS=0;
    RW=1;
    E=1;
    DataPort=0xff;
    while((DataPort&0x80)==0x80);//忙则等待
    E=0;
                   写命令
void Write_Cmd(unsigned char Cmd)
        Check_Busy();
        RS=0;
        RW=0;
        E=1;
        DataPort=Cmd;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                    写数据
void Write_Data(unsigned char Data)
        Check_Busy();
        RS=1;
        RW=0;
        E=1;
        DataPort=Data;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                   液晶屏初始化
void Init_ST7920()
   DelayMs(40);           //大于40MS的延时程序
   PSB=1;                 //设置为8BIT并口工作模式
   DelayMs(1);            //延时
   RES=0;                 //复位
   DelayMs(1);            //延时
   RES=1;                 //复位置高
   DelayMs(10);
   Write_Cmd(0x30);       //选择基本指令集
   DelayUs2x(50);         //延时大于100us
   Write_Cmd(0x30);       //选择8bit数据流
   DelayUs2x(20);         //延时大于37us
   Write_Cmd(0x0c);       //开显示(无游标、不反白)
   Write_Cmd(0x01);       //清除显示,并且设定地址指针为00H
   DelayMs(15);           //延时大于10ms
   Write_Cmd(0x06);       //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位,光标从右向左加1位移动
                   用户自定义字符
void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
     for(i=0;i<16;i++)
            Write_Data(user16x16[i*2]);
        Write_Data(user16x16[i*2+1]);
                   显示用户自定义字符
void DisplayCGRAM(unsigned char x,unsigned char y)
switch(y)
          case 1: Write_Cmd(0x80+x);break;
          case 2: Write_Cmd(0x90+x);break;
          case 3: Write_Cmd(0x88+x);break;
          case 4: Write_Cmd(0x98+x);break;
      default:break;
    Write_Data(00);
    Write_Data(00);
                   显示字符串
x:横坐标值,范围0~8
y:纵坐标值,范围1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
      default:break;
while(*s>0)
      Write_Data(*s);
      s++;
      DelayUs2x(50);
                      清屏
void ClrScreen()
   Write_Cmd(0x01);
   DelayMs(15);
                   显示图片
void LCD_PutGraphic(unsigned char code *img)
int i,j;
//显示上半屏内容设置
   for(i=0;i<32;i++)
      Write_Cmd(0x80 + i); //SET  垂直地址 VERTICAL ADD
      Write_Cmd(0x80);     //SET  水平地址 HORIZONTAL ADD
      for(j=0;j<16;j++)
         Write_Data(*img);
         img++;
//显示下半屏内容设置
   for(i=0;i<32;i++)
      Write_Cmd(0x88);     //SET 水平地址 HORIZONTAL ADD
      for(j=0;j<16;j++)
         Write_Data(*img);
         img++;
                 设置到绘图模式
void SetGraphicMode()
   Write_Cmd(0x36);       //选择8bit数据流 图形模式
   DelayUs2x(20);
void display_init()
          LCD_PutString(0,1,"智能家居控制系统");
          LCD_PutString(0,2,"学生:郑家波");
          LCD_PutString(0,3,"老师:李湘文");
      LCD_PutString(0,4,"时间:2015/6/2");
                 主程序
main()
  unsigned char i;
  // CGRAM();     //写入自定义字符
    Init_ST7920();   //初始化
      LCD_PutString(0,4,"时间:2015/5/5");
          //延时30x200ms
      for(i=0;i<30;i++)
          DelayMs(200);
           ClrScreen();
          LCD_PutString(0,1,"窗帘OFF 灯光OFF");
          LCD_PutString(0,2,"烟雾OK  温度OK ");
          LCD_PutString(0,3,"  温度:28°C");
      LCD_PutString(0,4,"  光照度:53% ");
          //延时30x200ms
      for(i=0;i<30;i++)
          DelayMs(200);
                  LCD_PutString(0,1,"窗帘ON  灯光OFF");
                  for(i=0;i<30;i++)
          DelayMs(200);
          ClrScreen();
          LCD_PutString(0,2,"  短信通知中...");        //"正”字显示不出
            for(i=0;i<20;i++)
          DelayMs(200);
