查看: 13373|回复: 7
最近搞了一个OLED的字库程序
ID:218264 发表于 2017-7-9 15:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* OLED屏测试程序
* msp430g2553
* 调用方法:
*                LCD_Init();  //        OLED 初始化
*                LCD_Fill(0x00);  // 全屏填充 0x00
*                LCD_GBK16(0, 2, "1.锄禾日当午,\r2.汗滴禾下土。\r3.谁知盘中餐,");
*                LCD_P6x8Str (0,4,"OLED"); // 显示6*8  字符串
*                = HowMuchWidth(Num);// 获取某数有几位
*                LCD_IntNum(x, y, HowMuchWidth(v), v); // 显示数字
*                LCD_16Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char dat[]);//16像素高度图片
*                LCD_8Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char ch[]);//8像素高度图片
*                LCD_AllPic(unsigned char dat[]);//全局图像显示
* 说明:图像取模:纵向取模,字节倒序
* 作者:星希望(已校验)
* 日期:2016年7月25日
#include "msp430f149.h"
#include "OLED.h"
#include "OLED_Font.h"
#define LCD_SCL_1        P2OUT |=  BIT0
#define LCD_SCL_0        P2OUT &= ~BIT0
#define LCD_SDA_1        P2OUT |=  BIT1
#define LCD_SDA_0        P2OUT &= ~BIT1
#define LCD_RST_1        P2OUT |=  BIT2
#define LCD_RST_0        P2OUT &= ~BIT2
#define LCD_DC_1        P2OUT |=  BIT3
#define LCD_DC_0        P2OUT &= ~BIT3
#define XLevelL                0x00
#define XLevelH                0x10
#define XLevel                ((XLevelH&0x0F)*16+XLevelL)
#define Max_Column        128
#define Max_Row                64
#define        Brightness        0xCF
#define X_WIDTH 128
#define Y_WIDTH 64
unsigned int hz16_num = 0; // 汉字个数
void LCD_WrDat(unsigned char dat)
        unsigned char i=8;
        LCD_DC_1;
        LCD_SCL_0;
        while(i--)
                if(dat&0x80)        {LCD_SDA_1;}
                else                        {LCD_SDA_0;}
                LCD_SCL_1;
                dat<<=1;
                LCD_SCL_0;
void LCD_WrCmd(unsigned char cmd)
        unsigned char i=8;
        LCD_DC_0;
        LCD_SCL_0;
        while(i--)
                if(cmd&0x80)        {LCD_SDA_1;}
                else                        {LCD_SDA_0;}
                LCD_SCL_1;
                cmd<<=1;
                LCD_SCL_0;
void LCD_Set_Pos(unsigned char x, unsigned char y)
        LCD_WrCmd(0xb0+y);
        LCD_WrCmd(((x&0xf0)>>4)|0x10);
        LCD_WrCmd((x&0x0f)|0x00);
void LCD_Fill(unsigned char bmp_dat)
        unsigned char y, x;
        for(y=0;y<8;y++)
                LCD_WrCmd(0xb0+y);
                LCD_WrCmd(0x01);
                LCD_WrCmd(0x10);
                for(x=0;x<X_WIDTH;x++)
                        LCD_WrDat(bmp_dat);
void LCD_DLY_ms(unsigned int ms)
        while(ms--)
                __delay_cycles(100);
        return;
* OLED 初始化
void LCD_Init(void)
        P2DIR |= BIT0 | BIT1 | BIT2 | BIT3;
          LCD_SCL_1;
        //LCD_CS=1;        //预制SLK和SS为高电平
        LCD_RST_0;
        LCD_DLY_ms(50);
        LCD_RST_1;
        /* 计算汉字库的大小 */
        hz16_num = sizeof hz16 / sizeof (struct typFNT_GB162);
        //从上电到下面开始初始化要有足够的时间,即等待RC复位完毕
        LCD_WrCmd(0xae);//--关闭OLED面板
        LCD_WrCmd(0x00);//---set low column address置低列地址
        LCD_WrCmd(0x10);//---set high column address设置高列地址
        LCD_WrCmd(0x40);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)设置起始行地址设置映射RAM显示起始行(0×00?0x3F之间)
        LCD_WrCmd(0x81);//--set contrast control register设置对比度控制寄存器
        LCD_WrCmd(0xcf);// Set SEG Output Current Brightness设置SEG输出电流亮度
        LCD_WrCmd(0xa1);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常 设置SEG/列映射0XA0左右反置0xa1正常
        LCD_WrCmd(0xc8);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常 设置COM/行扫描方向为0xC0上下反置0xc8正常
        LCD_WrCmd(0xa6);//--set normal display        设置正常显示
        LCD_WrCmd(0xa8);//--set multiplex ratio(1 to 64) 设置复用率(1~64)
        LCD_WrCmd(0x3f);//--1/64 duty         1/64责任
        LCD_WrCmd(0xd3);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)         置显示失调漂移映射RAM计数器(为0x00?0x3F之间)
        LCD_WrCmd(0x00);//-not offset         不能抵消
        LCD_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency        设置显示时钟分频比/振荡器频率
        LCD_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec                设置的分频比,设置时钟为100帧/秒
        LCD_WrCmd(0xd9);//--set pre-charge period          组预充电期间
        LCD_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock         设置预充电为15时钟和放电为1时钟
        LCD_WrCmd(0xda);//--set com pins hardware configuration                                   组COM插针的硬件配置
        LCD_WrCmd(0x12);
        LCD_WrCmd(0xdb);//--set vcomh
        LCD_WrCmd(0x40);//Set VCOM Deselect Level         设置VCOM取消等级
        LCD_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)   设置页面寻址模式(0×00/0×01/0X02)
        LCD_WrCmd(0x02);//
        LCD_WrCmd(0x8d);//--set Charge Pump enable/disable                设置电荷泵启用/禁用
        LCD_WrCmd(0x14);//--set(0x10) disable                                        设置(0x10)后关闭
        LCD_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)   禁用整个显示屏(0xa4/到0x55)
        LCD_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)    禁用逆显示(0xa6/ A7)
        LCD_WrCmd(0xaf);//--turn on oled panel
        LCD_Fill(0x00);  //初始清屏
        LCD_Set_Pos(0,0);
* 函数名:LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char *p)
* 功能描述:写入一组标准ASCII字符串
* 参数:显示的位置(x,y),y为页范围0~7,要显示的字符串
* 返回:无
void LCD_P6x8Str(unsigned char x, unsigned char y, unsigned char ch[])
        unsigned char c=0,i=0,j=0;
        while (ch[j]!='\0')
                c =ch[j]-32;
                if(x>126 || c==13)        // 下一行
                {x=0;y++;}
                LCD_Set_Pos(x,y);
                for(i=0;i<6;i++)
                  LCD_WrDat(F6x8[c][i]);
                x+=6;
                j++;
* 函数名:LCD_8Pic(unsigned char x,unsigned char y,unsigned char *p)
* 功能描述:写入一组高度为8像素的图标
* 返回:无
void LCD_8Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char ch[])
        unsigned char j=0;
        LCD_Set_Pos(x,y);
        while (width)
                LCD_WrDat(ch[j]);
                j++;
                width--;
* 显示汉字 及 8x16 ascii码
* 坐标x,坐标y,内容
* 查找 hz16[] 结构体数组
void LCD_GBK16(unsigned int x, unsigned int y, unsigned char *s)
        unsigned char j;
        unsigned short k,x0;
        x0=x;
        while(*s)
                if((*s) < 128) // ASC段
                        k = *s;
                        if (k==13) //回车
                                x = x0;
                                y += 2;
                                if (k>32)        k-=32; //从有效字符开始编码,避开前面的非字符区
                                else                k=0;
                                LCD_Set_Pos(x, y);
                                for(j=0; j<8; j++)
                                        LCD_WrDat(F8X16[k*16+j]);
                                LCD_Set_Pos(x, y+1);
                                for(j=0; j<8; j++)
                                        LCD_WrDat(F8X16[k*16+j+8]);
                                x += 8;
                        s++;
                else         // 汉字段
                        for(k=0; k<hz16_num; k++)
                                if( (hz16[k].Index[0]==*(s)) && (hz16[k].Index[1]==*(s+1)) )
                                        LCD_Set_Pos(x, y);
                                        for(j=0; j<16; j++)        //高8位
                                                LCD_WrDat(hz16[k].Msk[j]);
                                        for(j=0; j<16; j++)        //低8位
                                                LCD_WrDat(hz16[k].Msk[j+16]);
                                        break;
                        if( k==hz16_num )// 没有找到该汉字
                                LCD_Set_Pos(x, y);
                                        LCD_WrDat(UnknowFont[j]);
                                        LCD_WrDat(UnknowFont[j+16]);
                        s += 2;
                        x += 16;
                if(x>120) {x=0; y+=2;}
* 函数名:LCD_16Pic(unsigned char x,unsigned char y,unsigned char *p)
* 参数:x,y                 显示的位置,y为页范围0~7,
*                 width    图标宽度
*                 dat[]    图像数据
void LCD_16Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char dat[])
        unsigned char i=0;
          LCD_Set_Pos(x, y);
          for(i = 0;i < width;i++)
                  LCD_WrDat(dat[i]);
          LCD_Set_Pos(x, y + 1);
                  LCD_WrDat(dat[i+width]);
* 全屏图像显示
void LCD_AllPic(unsigned char dat[])
        unsigned char y, x;
        for(y=0; y<8; y++)
                LCD_Set_Pos(0, y);
                for(x=0; x<128; x++)
                         LCD_WrDat(dat[y*128+x]);
* 计算某数有几位
unsigned char HowMuchWidth(unsigned long Num)
        unsigned char cnt=0;
        while(Num)
                Num /= 10;
                cnt++;
        return cnt;
* 显示数字
* 参数:x,y - 坐标
*                Width- 宽度(有几位数)
*                v         - 数字
* 说明:右对齐
void LCD_IntNum(unsigned char x, unsigned char y, unsigned char Width, unsigned long v)
        unsigned char a[11];
        unsigned char *p;
        // 数位分解
        a[10]= 0;
        a[9] = v    % 10 + '0';
        a[8] = v /10 % 10 + '0';
        a[7] = v /100 % 10 + '0';
        a[6] = v /1000 % 10 + '0';
        a[5] = v /10000 % 10 + '0';
        a[4] = v /100000 % 10 + '0';
        a[3] = v /1000000 % 10 + '0';
        a[2] = v /10000000 % 10 + '0';
        a[1] = v /100000000 % 10 + '0';
        a[0] = v /1000000000 % 10 + '0';
        p = &a[10-Width];
        // 显示
        LCD_GBK16(x, y, p); // 显示 8*16  字符串
* 显示数字
* 参数:x,y - 坐标
*                Width- 宽度(有几位数)
*                v         - 数字
* 说明:右对齐
void LCD_IntNum6x8(unsigned char x, unsigned char y, unsigned char Width, unsigned long v)
        unsigned char *p;
        // 数位分解
        a[10]= 0;
        p = &a[10-Width];
        // 显示
        LCD_P6x8Str(x, y, p); // 显示 8*16  字符串
#ifndef _OLED_H
#define _OLED_H
extern unsigned int hz16_num; // 汉字个数
void LCD_Init(void);
void LCD_CLS(void);
void LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char ch[]);
void LCD_GBK16(unsigned int x, unsigned int y, unsigned char *s);
unsigned char HowMuchWidth(unsigned long Num);
void LCD_IntNum(unsigned char x, unsigned char y, unsigned char Width, unsigned long v);
void LCD_IntNum6x8(unsigned char x, unsigned char y, unsigned char Width, unsigned long v);
void LCD_8Pic (unsigned char x,unsigned char y,unsigned char width,unsigned char ch[]);
void LCD_16Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char dat[]);
void LCD_AllPic(unsigned char dat[]);
void LCD_Fill(unsigned char dat);
#endif
收藏收藏3 分享淘帖 顶顶 踩踩
ID:305384 发表于 2018-12-4 01:21 来自触屏版 | 只看该作者
哥可以给完整的吗
ID:371527 发表于 2018-12-27 18:10 | 只看该作者
很规整,比较完善的,不过显示字体种类程序有些少,比如16*32 32*32 48*48 类的,并且数字也缺少小数显示。。。
ID:16848 发表于 2019-1-25 12:38 | 只看该作者
谢谢,学习了。
ID:305384 发表于 2019-2-17 16:01 | 只看该作者
兄弟你的不太完整我现在完善了功能,自己做了字库,输入自动搜索匹配!
ID:477629 发表于 2019-2-18 11:12 | 只看该作者
谢谢,学习了。
ID:260347 发表于 2019-4-12 12:45 来自触屏版 | 只看该作者
兄弟,你这字库不见呢?哪位可以给个完整的,谢谢!
ID:708805 发表于 2020-3-15 13:13 | 只看该作者
前面的程序能不能加点文字,看不太懂!拜托
