查看: 2059|回复: 0
单片机制造出来的电子计时表
ID:220060 发表于 2017-7-16 15:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>//单片机制造出来的电子计时表//
uchar num,num0,num1,num2,num3,num4;
uint xq;
void delayms(zms);
sbit key1=P2^5;
sbit key2=P2^6;
sbit key3=P2^3;
sbit key4=P2^4;
sbit led0=P1^0;
sbit led1=P1^1;
sbit led2=P1^2;
sbit led3=P1^3;
sbit led4=P1^4;
sbit led5=P1^5;
sbit led6=P1^6;
sbit led7=P1^7;
uchar code table1[]={
0x05,0x7d,0x46,0x54,
0x3c,0x94,0x84,0x5d,
0x04,0x14 };  //无小数点
uchar code table2[]={
0x01,0x79,0x42,0x50,
0x38,0x90,0x80,0x59,
0x00,0x10};//有小数点
        xq=1;
        num=0;
        num0=0;
        num1=0;
        num2=0;
        num3=0;
        num4=0;
        led0=0 ;
        TMOD=0x01;
          TH0=(65536-45872)/256;
        TL0=(65536-45872)%256;
        EA=1;
        ET0=1;
        TR0=1;
                key4=0;
                P0=table1[num1];
                key4=1;
                P0=0xff;
                key3=0;
                P0=table1[num2];
                key3=1;
                P0=0xff;
                   key2=0;
                P0=table2[num3];
                key2=1;
                P0=0xff;
                key1=0;
                P0=table1[num4];
                key1=1;
                P0=0xff;
                   if(num==20)
                        num=0;
                        num0++;
                if(num0==60)
                        num0=0;
                        num1++;
                if(num1==10)
                        num1=0;
                        num2++;
                 if(num2==6)
                         num2=0;
                        num3++;
                 if(num3==10)
                         num3=0;
                        num4++;
                  if(num4*10+num3==24)
                          num3=0;
                        num4=0;
                        xq++;
                  if(xq==1)
                          led1=0;
                        led2=1;
                        led3=1;
                        led4=1;
                        led5=1;
                        led6=1;
                        led7=1;
                  if(xq==2)
                          led1=1;
                        led2=0;
                        led3=1;
                        led4=1;
                        led5=1;
                        led6=1;
                        led7=1;
                  if(xq==3)
                          led1=1;
                        led2=1;
                        led3=0;
                        led4=1;
                        led5=1;
                        led6=1;
                        led7=1;
                  if(xq==4)
                          led1=1;
                        led2=1;
                        led3=1;
                        led4=0;
                        led5=1;
                        led6=1;
                        led7=1;
                  if(xq==5)
                          led1=1;
                        led2=1;
                        led3=1;
                        led4=1;
                        led5=0;
                        led6=1;
                        led7=1;
                  if(xq==6)
                          led1=1;
                        led2=1;
                        led3=1;
                        led4=1;
                        led5=1;
                        led6=0;
                        led7=1;
                  if(xq==7)
                          led1=1;
                        led2=1;
                        led3=1;
                        led4=1;
                        led5=1;
                        led6=1;
                        led7=0;
                  if(xq==8)
                          xq=1;
