查看: 9776|回复: 1
赋值法直接驱动uln2003步进电机
ID:220449 发表于 2017-7-18 09:33 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include "stm32....h" //头文件自己写,按需要弄
//uint16_t phasecw[4] ={0x0200,0x0100,0x0080,0x0040};// D-C-B-A
//uint16_t phaseccw[4]={0x0040,0x0080,0x0100,0x0200};// A-B-C-D
void rightMoto_Init(void)//初始化左轮
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC,&GPIO_InitStructure);
GPIO_ResetBits(GPIOC,GPIO_Pin_6 | GPIO_Pin_7 |GPIO_Pin_8 |GPIO_Pin_9 );
void leftMoto_Init(void)//初始化右轮
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 ;
GPIO_Init(GPIOB,&GPIO_InitStructure);
GPIO_ResetBits(GPIOB,GPIO_Pin_10 | GPIO_Pin_11 |GPIO_Pin_12 |GPIO_Pin_13 );
//LED¶Ôó|IO3õê¼»ˉ
void Delay_xms(int x)//这里调节转速如果太大就不能转了,主要问题就是这里的延时脉冲
int i,j;
for(i=0;i<x;i++)
  for(j=0;j<112;j++);
void Motorcw(void)  //ǰ½ø直接按照规律赋值操作
    int i= 225;//这里调节他以一种模式跑多长时间
        GPIO_SetBits(GPIOC,GPIO_Pin_6| GPIO_Pin_9);
        GPIO_ResetBits(GPIOC,GPIO_Pin_7|GPIO_Pin_8);
        GPIO_SetBits(GPIOB,GPIO_Pin_13| GPIO_Pin_10);
        GPIO_ResetBits(GPIOB,GPIO_Pin_11|GPIO_Pin_12);
   Delay_xms(i);//×aËùμ÷½ú
        GPIO_SetBits(GPIOC,GPIO_Pin_6| GPIO_Pin_7);
        GPIO_ResetBits(GPIOC,GPIO_Pin_8|GPIO_Pin_9);
        GPIO_SetBits(GPIOB,GPIO_Pin_13| GPIO_Pin_12);
        GPIO_ResetBits(GPIOB,GPIO_Pin_11|GPIO_Pin_10);
        Delay_xms(i);
        GPIO_SetBits(GPIOC,GPIO_Pin_7| GPIO_Pin_8);
        GPIO_ResetBits(GPIOC,GPIO_Pin_9|GPIO_Pin_6);
        GPIO_SetBits(GPIOB,GPIO_Pin_11| GPIO_Pin_12);
        GPIO_ResetBits(GPIOB,GPIO_Pin_13|GPIO_Pin_10);
        Delay_xms(i);
        GPIO_SetBits(GPIOC,GPIO_Pin_8| GPIO_Pin_9);
        GPIO_ResetBits(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
        GPIO_SetBits(GPIOB,GPIO_Pin_10| GPIO_Pin_11);
        GPIO_ResetBits(GPIOB,GPIO_Pin_12|GPIO_Pin_13);
         Delay_xms(i);
void Motorccw(void)  //μ1íË
    int i= 225;
        GPIO_SetBits(GPIOC,GPIO_Pin_9| GPIO_Pin_8);
        GPIO_ResetBits(GPIOC,GPIO_Pin_7|GPIO_Pin_6);
        Delay_xms(i);
        Delay_xms(i);
        GPIO_SetBits(GPIOC,GPIO_Pin_7| GPIO_Pin_6);
        GPIO_SetBits(GPIOB,GPIO_Pin_12| GPIO_Pin_13);
        GPIO_ResetBits(GPIOB,GPIO_Pin_10|GPIO_Pin_11);
         Delay_xms(i);
void turn_left(void)
            int i= 225;
        Delay_xms(i);
        Delay_xms(i);
         Delay_xms(i);
void turn_right(void)
           int i= 225;
        Delay_xms(i);
        Delay_xms(i);
         Delay_xms(i);
ID:611551 发表于 2019-9-15 14:55 | 只看该作者
你好,我根据你的思路这样写,电机一点反应都没有,驱动的芯片发热,是哪里出了问题?
#define C7_H()        GPIO_SetBits(GPIOC, GPIO_Pin_7)
#define C7_L()        GPIO_ResetBits(GPIOC, GPIO_Pin_7)
#define C13_H()        GPIO_SetBits(GPIOC, GPIO_Pin_13)
#define C13_L()        GPIO_ResetBits(GPIOC, GPIO_Pin_13)
#define C14_H()        GPIO_SetBits(GPIOC, GPIO_Pin_14)
#define C14_L()        GPIO_ResetBits(GPIOC, GPIO_Pin_14)
#define C15_H()        GPIO_SetBits(GPIOC, GPIO_Pin_15)
#define C15_L()        GPIO_ResetBits(GPIOC, GPIO_Pin_15)
uint16_t phasecw[4] ={0x0080,0x2000,0x4000,0x8000};// D-C-B-A
uint16_t phaseccw[4]={0x8000,0x4000,0x2000,0x0080};// A-B-C-D
void LED_gpio_cfg(void)
                  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
                 // RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
                GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_15|GPIO_Pin_13|GPIO_Pin_14;
                GPIO_Init(GPIOC, &GPIO_InitStructure);
                GPIO_SetBits(GPIOC,GPIO_Pin_0);
                GPIO_SetBits(GPIOC,GPIO_Pin_2);
                GPIO_SetBits(GPIOC,GPIO_Pin_3);
                GPIO_SetBits(GPIOC,GPIO_Pin_4);
                C6_L();
                C7_L();
                C13_L();
                C15_L();
                C14_L();
//步进电机正转函数
void Motorcw(void)
        GPIO_ResetBits(GPIOC,GPIO_Pin_7);//依次高电平输出
        GPIO_SetBits(GPIOC,GPIO_Pin_13);
        GPIO_SetBits(GPIOC,GPIO_Pin_14);
        GPIO_SetBits(GPIOC,GPIO_Pin_15);
        delay_ms(10);
        GPIO_SetBits(GPIOC,GPIO_Pin_7);
        GPIO_ResetBits(GPIOC,GPIO_Pin_13);
        delay_ms(10);
        GPIO_ResetBits(GPIOC,GPIO_Pin_14);
        delay_ms(10);
        GPIO_ResetBits(GPIOC,GPIO_Pin_15);
        delay_ms(10);
//步进电机反转函数
void Motordw(void)
        GPIO_SetBits(GPIOC,GPIO_Pin_7);//依次高电平输出
        delay_ms(10);
        delay_ms(10);
        delay_ms(10);
        GPIO_SetBits(GPIOC,GPIO_Pin_5);
        delay_ms(10);
