查看: 3522|回复: 1
单片机串口计算器源码
ID:221388 发表于 2017-7-21 15:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个计算器的结果是在电脑串口上面显示的
串口计算器所有资料51hei提供下载:
串口练习.zip (22.33 KB, 下载次数: 37)
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. //  # include <stdlib. h>
  4. #include<math.h>
  5. sbit dula=P2^6;                //段选信号的锁存器控制
  6. sbit wela=P2^7;                //位选信号的锁存器控制                                   ,0x77,0x7c,0x39,0x5e,0x79,0x71
  7. bit flag0=0; //"="号按键标志
  8. bit flag1=0; //"+"号按键标志
  9. bit flag2=0; //"-"号按键标志
  10. bit flag3=0; //"*"号按键标志
  11. bit flag4=0; //"^"号按键标志
  12. bit flag5=0; //清楚标志
  13. #define uint unsigned int
  14. #define uchar unsigned char
  15. unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  16. unsigned int j,t,sum,s1=0,s2=0,a1,a2,a3;
  17. uint m;
  18. void delay(unsigned int i)
  19. {
  20.         unsigned int m,n;
  21.         for(m=i;m>0;m--)
  22.                 for(n=90;n>0;n--);
  23. }
  24. void display(uint s)
  25. {
  26.                 P0=0xfe;
  27.                 wela=1;
  28.                 wela=0;
  29.                 P0=table[s/100];
  30.                 dula=1;
  31.                 dula=0;
  32.                 delay(6);
  33.
  34.                 P0=0xfd;
  35.                 wela=1;
  36.                 wela=0;
  37.                 P0=table[s%100/10];
  38.                 dula=1;
  39.                 dula=0;
  40.                 delay(6);
  41.
  42.
  43.                 P0=0xfb;
  44.                 wela=1;
  45.                 wela=0;
  46.                 P0=table[s%10];
  47.                 dula=1;
  48.                 dula=0;
  49.                 delay(6);
  50. }
  51.
  52. void InitUART(void)
  53. {
  54.     TMOD = 0x20;
  55.     SCON = 0x50;
  56.     TH1 = 0xFD;
  57.     TL1 = TH1;
  58.     PCON = 0x00;
  59.     EA = 1;
  60.     ES = 1;
  61.     TR1 = 1;
  62. }
  63. void SendOneByte(unsigned char c)
  64. {
  65.     SBUF = c;
  66.     while(!TI);
  67.     TI = 0;
  68. }
  69.
  70. void main(void)
  71. {
  72.         InitUART();
  73.         while(1)
  74.         {
  75.                 display(sum);
  76.
  77.
  78.    }
  79. }
  80. void UARTInterrupt(void) interrupt 4
  81. {
  82.
  83.                 if(RI)
  84.                 {
  85.                         RI = 0;
  86.                         m= SBUF;
  87.
  88.                         SendOneByte(m);
  89.                         if((m-0x30)>=0 && (m-0x30)<=9)
  90.                               {
  91.                                    s1=s1*10+(m-0x30);
  92.                                  //         display(m);
  93.                                 }
  94.                         switch(m)
  95.                         {
  96.                                         case 0x2B:{        s2=s1;s1=0;flag1=1;}break; //加法
  97.                                         case 0x2a:{s2=s1; s1=0;flag3=1;}break; //乘法
  98.                                                 case 0x2d: {s2=s1; s1=0;flag2=1;}break; //减法
  99.                                         case 0x5e: {s2=s1; s1=0;flag4=1;}break; //幂运算
  100.                                         case 0x3d: flag0=1;   break; //"="号按键
  101.                                         case 0xFF: flag5=1; break;        //"/"号按键
  102.                                         default:         break;
  103.                                 }
  104.                                 if(flag0==1)
  105.                 {        if(flag1==1)
  106.                         {
  107.                                 sum=0;
  108.                                 sum=s1+s2;
  109.                         }
  110.                         else if(flag3==1)
  111.                         {
  112.                                 sum=s1*s2;
  113.                         }
  114.                         else if(flag2==1)
  115.                         {
  116.                                 sum=s2-s1;
  117.                         }
  118.                                 else if(flag4==1)
  119.                         {
  120.                                 sum=pow(s1,s2);
  121.                         }
  122.                                    display(sum);
  123.                                  a1=sum/10;
  124.                                  a2=sum%10;
  125.
  126.                         SendOneByte(a1+0x30);
  127.                          SendOneByte(a2+0x30);
  128.
  129.
  130.
  131.
  132.                 }
  133. ……………………
  134. …………限于本文篇幅 余下代码请从51黑下载附件…………
ID:677261 发表于 2020-1-1 23:39 | 只看该作者
感谢,如果加上图片更好
