查看: 4056|回复: 1
关于C语言定时器重载值修正的问题
ID:204609 发表于 2017-7-24 10:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
只是一个PWM控制LED灯的小程序。我对于C语言的定时器修正值判断不清楚,这里的修正值13,
不知道从哪里开始数机械周期的
#include <reg52.h>
sbit  PWMOUT = P0^0;
sbit  ADDR0 = P1^0;
sbit  ADDR1 = P1^1;
sbit  ADDR2 = P1^2;
sbit  ADDR3 = P1^3;
sbit  ENLED = P1^4;
unsigned char HReloadH = 0;  //高电平重载值的高字节
unsigned char HReloadL = 0;  //高电平重载值的低字节
unsigned char LReloadH = 0;  //低电平重载值的高字节
unsigned char LReloadL = 0;  //低电平重载值的低字节
void ConfigPWM(unsigned int fr, unsigned char dc);
void ClosePWM();
void main ()
    unsigned int i;
    P0 = 0xFF;  //P0口初始化
    ADDR0 = 0;  //选择独立LED
    ADDR1 = 1;
    ADDR2 = 1;
    ADDR3 = 1;
    ENLED = 0;  //LED总使能
    EA = 1;     //开总中断
        ConfigPWM(100, 10);  //频率100Hz,占空比10%
        for (i=0; i<40000; i++);
        ClosePWM();
        ConfigPWM(100, 40);  //频率100Hz,占空比40%
        ClosePWM();
        ConfigPWM(100, 90);  //频率100Hz,占空比90%
        ClosePWM();
void ConfigPWM(unsigned int fr, unsigned char dc)  //PWM配置函数,fr-频率,dc-占空比
    unsigned int  high, low;
    unsigned long tmp;
    tmp  = (11059200 / 12) / fr;  //计算一个周期所需的计数值
    high = (tmp * dc) / 100;      //计算高电平所需的计数值
    low  = tmp - high;            //计算低电平所需的计数值
    high = 65536 - high + 13;     //计算高电平的定时器重载值并修正
    low  = 65536 - low  + 13;     //计算低电平的定时器重载值并修正
    HReloadH = (unsigned char)(high >> 8);  //高电平重载值拆分为高低字节
    HReloadL = (unsigned char)high;
    LReloadH = (unsigned char)(low >> 8);   //低电平重载值拆分为高低字节
    LReloadL = (unsigned char)low;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0为模式1
    TH0 = HReloadH; //加载T0重载值
    TL0 = HReloadL;
    ET0 = 1;        //使能T0中断
    TR0 = 1;        //启动T0
    PWMOUT = 1;     //输出高电平
void ClosePWM()  //关闭PWM
    TR0 = 0;     //停止定时器
    ET0 = 0;
    PWMOUT = 1;  //输出高电平
void InterruptTimer0() interrupt 1  //T0中断服务函数
    if (PWMOUT == 1)  //当前输出为高电平时,装载低电平值并输出低电平
        TH0 = LReloadH;
        TL0 = LReloadL;
        PWMOUT = 0;
    else              //当前输出为低电平时,装载高电平值并输出高电平
        TH0 = HReloadH;
        TL0 = HReloadL;
        PWMOUT = 1;
ID:204609 发表于 2017-7-25 10:05 | 只看该作者
我能说我打错字了吗  “这是控制LED灯的程序”
