查看: 3543|回复: 0
51单片机超声波测距(LCD1602显示)代码
ID:223069 发表于 2017-7-28 18:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Trig -------  P2^1;
Echo -------  P2^0;
VCC  -------- +5v
GND  -------- GND
请在上电之前,检查好接线是否正确。
#include"lcd.h"
void Read_Busy()           //忙检测函数,判断bit7是0,允许执行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,释放总线
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd)     //写命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //写数据
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐标显示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置显示一个字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
        X |= 0x80; //算出指令码
        Lcd1602_Write_Cmd(X); //发命令字
        Lcd1602_Write_Data(DData); //发数据
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //显示字符串
    LcdSetCursor(x,y);      //当前字符的坐标
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打开,5*8,8位数据
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
#include<reg51.h>
#include<intrins.h>
#include"lcd.h"
sbit Trig = P2^1;
sbit Echo = P2^0;
unsigned char PuZh[]=" Pechin Science ";
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //显示用指针
       unsigned int  time=0;
           unsigned long S=0;
           bit      flag =0;
           unsigned char disbuff[4]           ={ 0,0,0,0,};
* 函 数 名         : main
* 函数功能                   : 主函数
* 输    入         : 无
* 输    出         : 无
void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.7)/100;     //算出来是CM
         if((S>=700)||flag==1) //超出测量范围显示“-”
          flag=0;
          DisplayOneChar(0, 1, ASCII[11]);
          DisplayOneChar(1, 1, ASCII[10]);        //显示点
          DisplayOneChar(2, 1, ASCII[11]);
          DisplayOneChar(3, 1, ASCII[11]);
          DisplayOneChar(4, 1, ASCII[12]);        //显示M
          disbuff[0]=S%1000/100;
          disbuff[1]=S%1000%100/10;
          disbuff[2]=S%1000%10 %10;
          DisplayOneChar(0, 1, ASCII[disbuff[0]]);
          DisplayOneChar(2, 1, ASCII[disbuff[1]]);
          DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void zd0() interrupt 1                  //T0中断用来计数器溢出,超过测距范围
    flag=1;                                                         //中断溢出标志
void  StartModule()                          //启动模块
          Trig=1;                                             //启动一次模块
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          Trig=0;
void delayms(unsigned int ms)
        unsigned char i=100,j;
        for(;ms;ms--)
                while(--i)
                        j=10;
                        while(--j);
void main(void)
         TMOD=0x01;                   //设T0为方式1,GATE=1;
         TH0=0;
         TL0=0;
         ET0=1;             //允许T0中断
         EA=1;                           //开启总中断
        InitLcd1602();
        LcdShowStr(0,0,PuZh);
                 StartModule();
             while(!Echo);                //当RX为零时等待
             TR0=1;                            //开启计数
             while(Echo);                        //当RX为1计数并等待
             TR0=0;                                //关闭计数
         Conut();                        //计算
                 delayms(80);
程序.rar
23.81 KB, 下载次数: 23, 下载积分: 黑币 -5
源代码
