查看: 8411|回复: 6
单片机粮仓温湿度控制系统原理图和源码 DHT11传感器
给大伙分享一个51单片机做粮仓温湿度控制系统,下面是原理图基于dht11传感器做的.
  1. #include <reg52.h>
  2. #include "1602.h"
  3. #include "dht.h"
  4. #include "2402.h"
  5. //定义三个LED灯
  6. sbit Led_qushi=P1^6;                //去湿灯
  7. sbit Led_jiangwen=P1^5;                //降温灯
  8. sbit Led_shengwen=P1^4;                //升温灯
  9. sbit Key_TH1 = P3^2;
  10. sbit Key_TH2 = P3^3;
  11. sbit Key_HH1 = P3^4;
  12. sbit Key_HH2 = P3^5;
  13. //定义标识
  14. volatile bit FlagStartRH = 0;  //开始温湿度转换标志
  15. volatile bit FlagKeyPress = 0; //有键按下
  16. //定义温湿度传感器用外部变量
  17. extern U8  U8FLAG,k;
  18. extern U8  U8count,U8temp;
  19. extern U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
  20. extern U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
  21. extern U8  U8comdata;
  22. extern U8  count, count_r;
  23. U16 temp;
  24. S16 temperature, humidity;
  25. S16 idata TH, HH;  //温度上限和湿度上限
  26. char * pSave;
  27. U8 keyvalue, keyTH1, keyTH2, keyHH1, keyHH2;
  28. //定义变量
  29. U16 RHCounter;
  30. //数据初始化
  31. void Data_Init()
  32. {
  33.    RHCounter = 0;
  34.    Led_qushi = 1;
  35.    Led_jiangwen = 1;
  36.    Led_shengwen = 1;
  37.    TH = 40;
  38.    HH = 85;
  39.    keyvalue = 0;
  40.    keyTH1 = 1;
  41.    keyTH2 = 1;
  42.    keyHH1 = 1;
  43.    keyHH2 = 1;
  44. }
  45. //定时器0初始化
  46. void Timer0_Init()
  47. {
  48.         ET0 = 1;        //允许定时器0中断
  49.         TMOD = 1;       //定时器工作方式选择
  50.         TL0 = 0x06;
  51.         TH0 = 0xf8;     //定时器赋予初值
  52.         TR0 = 1;        //启动定时器
  53. }
  54. //定时器0中断
  55. void Timer0_ISR (void) interrupt 1 using 0
  56. {
  57.         TL0 = 0x06;
  58.         TH0 = 0xf8;     //定时器赋予初值
  59.         //每2秒钟启动一次温湿度转换
  60.     RHCounter ++;
  61.     if (RHCounter >= 1000)
  62.     {
  63.        FlagStartRH = 1;
  64.            RHCounter = 0;
  65.     }
  66. }
  67. //存入设定值、
  68. void Save_Setting()
  69. {
  70.    pSave =  (char *)&TH;          //地址低位对应低8位,高位对应高8位
  71.    wrteeprom(0, *pSave);          //存温度上限值TH低8位
  72.    DELAY(500);
  73.    pSave ++;
  74.    wrteeprom(1, *pSave);          //存温度上限值TH高8位
  75.    DELAY(500);
  76.    pSave =  (char *)&HH;
  77.    wrteeprom(2, *pSave);          //存湿度上限值RH低8位
  78.    DELAY(500);
  79.    pSave ++;
  80.    wrteeprom(3, *pSave);          //存湿度上限值RH高8位
  81.    DELAY(500);
  82. }
  83. //载入设定值、
  84. void Load_Setting()
  85. {
  86.    pSave =  (char *)&TH;
  87.    *pSave++ = rdeeprom(0);
  88.    *pSave = rdeeprom(1);
  89.    pSave = (char *)&HH;
  90.    *pSave++ = rdeeprom(2);
  91.    *pSave = rdeeprom(3);
  92.    if ((TH>99)||(TH<0)) TH = 40;
  93.    if ((HH>99)||(HH<0)) HH = 85;
  94. }
  95. void KeyProcess(uint num)
  96. {
  97.    switch (num)
  98.    {
  99.       case 1:
  100.              if (TH<99) TH++;
  101.              L1602_char(1, 15, TH/10+48);
  102.              L1602_char(1, 16, TH%10+48);
  103.              break;
  104.           case 2:
  105.              if (TH>1) TH--;
  106.              L1602_char(1, 15, TH/10+48);
  107.              L1602_char(1, 16, TH%10+48);
  108.              break;
  109.           case 3:
  110.              if (HH<99) HH++;
  111.              L1602_char(2, 15, HH/10+48);
  112.              L1602_char(2, 16, HH%10+48);
  113.              break;
  114.           case 4:
  115.              if (HH>1) HH--;
  116.              L1602_char(2, 15, HH/10+48);
  117.              L1602_char(2, 16, HH%10+48);
  118.              break;
  119.           default:
  120.              break;
  121.    }
  122.    Save_Setting();
  123. }
  124. /********************************************************************
  125. * 名称 : Main()
  126. * 功能 : 主函数
  127. ***********************************************************************/
  128. void main()
  129. {
  130.     U16 i, j, testnum;
  131.     EA = 0;
  132.         Timer0_Init();  //定时器0初始化
  133.     Data_Init();
  134.         EA = 1;
  135.         L1602_init();
  136.         L1602_string(1,1," Welcome to T&H   ");
  137.         L1602_string(2,1," Control System!  ");
  138.         //延时
  139.         for (i=0;i<500;i++)
  140.            for (j=0;j<1000;j++)
  141.            {;}
  142.     //清屏
  143.         L1602_string(1,1,"                ");
  144.         L1602_string(2,1,"                ");
  145.     L1602_string(1,1,"Tem:    C  TH:");
  146.         L1602_string(2,1,"Hum:    %  HH:");
  147.
  148.     //载入温度上限和湿度上限设定值
  149.         Load_Setting();
  150.         L1602_char(1, 15, TH/10+48);
  151.         L1602_char(1, 16, TH%10+48);
  152.         L1602_char(2, 15, HH/10+48);
  153.         L1602_char(2, 16, HH%10+48);
  154.         while(1)
  155.         {
  156.        //温湿度转换标志检查
  157.                  if (FlagStartRH == 1)
  158.                  {
  159.                      TR0 = 0;
  160.              testnum = RH();
  161.                          FlagStartRH = 0;
  162.                          TR0 = 1;
  163.              //读出温湿度,只取整数部分
  164.                          humidity = U8RH_data_H;
  165.                          temperature = U8T_data_H;
  166.                          //显示温湿度
  167.                          L1602_int(1,5,temperature);
  168.                      L1602_int(2,5,humidity);
  169.                 }
  170.                 //温湿度控制
  171.                 if (temperature > TH) Led_jiangwen = 0;
  172. ……………………
  173. …………限于本文篇幅 余下代码请从51黑下载附件…………
粮仓温度控制系统.rar (682.39 KB, 下载次数: 215)
收藏收藏5 分享淘帖 顶顶 踩踩
ID:142687 发表于 2017-9-12 22:59 | 只看该作者
好资料,51黑有你更精彩!!!
ID:696735 发表于 2020-2-22 22:08 来自触屏版 | 只看该作者
测温探头是什么探头
ID:282869 发表于 2020-2-24 11:57 | 只看该作者
好東西,謝謝分享....
ID:421783 发表于 2020-2-26 22:09 | 只看该作者
好东西,谢谢楼主
ID:214276 发表于 2020-3-15 03:53 | 只看该作者
这个传感器精度不是很好,如果能换成SHT21,30之类的就好了。
ID:688393 发表于 2020-4-6 12:27 | 只看该作者
I2C总线有什么用啊?
