查看: 3071|回复: 2
照网上程序修改的,一直显示045.0,大神帮忙看看
ID:223438 发表于 2017-8-3 23:05 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <math.h>
#include <stdio.h>
#include <intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
/*12864液晶引脚定义*/
sbit CS=P3^3;
sbit SID=P3^4;
sbit SCLK=P3^5;
sbit SCL=P1^0;      //IIC时钟引脚定义
sbit SDA=P1^1;      //IIC数据引脚定义
#define SlaveAddress 0x3c   //定义器件在IIC总线中的从地址
uchar Rec_Data[6];
void Send_byte(unsigned char bbyte);
void Delaynms(unsigned int di);
/*延时函数*/
void Delay(uint t)
    while(t--)
**LCD显示函数
/*写入一个数据或指令*/
void Send_DATA(uchar ddata,uchar start)
        unsigned char start_data,Hdata,Ldata;
          if(start==0)
                start_data=0xf8;//写指令
            start_data=0xfa; //写数据
    SCLK=0;
    CS=1;
        Hdata=ddata&0xf0;                  //取高四位
          Ldata=(ddata<<4)&0xf0;  //取低四位
          Send_byte(start_data);          //发送起始信号
          Delaynms(5); //延时是必须的
          Send_byte(Hdata);              //发送高四位
          Delaynms(1);  //延时是必须的
          Send_byte(Ldata);                  //发送低四位
    CS=0;
    Delay(20);
void Delaynms(unsigned int di) //??
        unsigned int da,db;
        for(da=0;da<di;da++)
                   for(db=0;db<10;db++);
void Send_byte(unsigned char bbyte) //发送一个字节
        unsigned char i;
        for(i=0;i<8;i++)
                   SID=bbyte&0x80; //取出最高位
                SCLK=1;
                   SCLK=0;
                   bbyte<<=1; //左移
void LCD_set_xy( unsigned char x, unsigned char y )
{        //设置LCD显示的起始位置,X为行,Y为列
    unsigned char address;
        switch(x)
                case 0: address = 0x80 + y; break;
            case 1: address = 0x80 + y; break;
                case 2: address = 0x90 + y; break;
                    case 3: address = 0x88 + y; break;
                case 4: address = 0x98 + y; break;
                default:address = 0x80 + y; break;
        Send_DATA(address,0);
/*12864液晶初始化*/
void LCD_Init(void)
    Delay(60000);
    Send_DATA(0x30,0);
    Send_DATA(0x04,0);
    Send_DATA(0x0c,0);
    Send_DATA(0x01,0);
    Delay(3000);
/*显示字符串*/
void Dis_str(uchar Addr,uchar *str)
    Send_DATA(Addr,0);
    Delay(10);
    while(*str!='\0')
        Send_DATA(*str,1);
        str++;
        Delay(10);
/*起始信号*/
void IIC_Start(void)
    SDA=1;
    SCL=1;
    Delay(5);
    SDA=0;
    Delay(5);
    SCL=0;
/*停止信号*/
void IIC_Stop(void)
    SDA=0;
    SCL=1;
    Delay(5);
    SDA=1;
    Delay(5);
/*发送应答信号*/
void IIC_SendAck(bit Ack)
    SDA=Ack;//ack (0:ACK 1:NACK)
    SCL=1;
    Delay(5);
    SCL=0;
    Delay(5);
/*接收应答信号*/
bit IIC_RecAck(void)
    SCL=1;
    Delay(5);
    CY=SDA;
    SCL=0;
    Delay(5);
    return CY;
/*向IIC总线发送一个字节数据*/
void HMC5883_Send_Byte(uchar Dat)
    uchar i;
    for(i=0;i<8;i++)
        Dat<<=1;
        SDA=CY;
        SCL=1;
        Delay(5);
        SCL=0;
        Delay(5);
    IIC_RecAck();
/*从IIC总线接收一个字节数据*/
uchar HMC5883_Rec_Byte(void)
    uchar i,Dat=0;
    SDA=1;
    for(i=0;i<8;i++)
        Dat<<=1;
        SCL=1;
        Delay(5);
        Dat |=SDA;
        SCL=0;
        Delay(5);
    return Dat;
/*单字节写HMC5833*/
void Single_Write_HMC5883(uchar Address,uchar Dat)
    IIC_Start();
    HMC5883_Send_Byte(SlaveAddress);
    HMC5883_Send_Byte(Address);
    HMC5883_Send_Byte(Dat);
    IIC_Stop();
/*单字节读HMC5833*/
/*uchar Single_Read_HMC5883(uchar Addr)
    uchar Value;
    IIC_Start();
    HMC5883_Send_Byte(Addr);
    IIC_Start();
    HMC5883_Send_Byte(SlaveAddress+1);
    Value=HMC5883_Rec_Byte();
    IIC_SendAck(1);
    IIC_Stop();
    return Value;
/*多字节读HMC5833*/
void Multiple_Read_HMC5883(void)
    uchar i;  //连续读出HMC5883内部角度数据,地址范围0x3~0x5
    IIC_Start();
    HMC5883_Send_Byte(0x03);//发送存储单元地址,从0x03开始
    IIC_Start();
    for(i=0;i<6;i++) //连续读取6个地址数据,存储在Rec_Data
        Rec_Data[i]=HMC5883_Rec_Byte();
        if(i==5)
            IIC_SendAck(1); //最后一个数据需要回NOACK
            IIC_SendAck(0); //回应ACK
    IIC_Stop();
    Delay(100);
//初始化HMC5883,根据需要请参考pdf进行修改****
void HMC5883_Init(void)
     Single_Write_HMC5883(0x02,0x00);
/*主函数*/
void main(void)
    int X,Y,Z;
    double Angle;
    uint Acr;
    LCD_Init();//LCD12864液晶初始化
    HMC5883_Init();//HMC5883初始化
        Multiple_Read_HMC5883();//连续读出数据,存储在Rec_Data[]中
        X=Rec_Data[0]<<8 | Rec_Data[1];//Combine MSB and LSB of X Data output register
        Z=Rec_Data[2]<<8 | Rec_Data[3];//Combine MSB and LSB of Z Data output register
        Y=Rec_Data[4]<<8 | Rec_Data[5];//Combine MSB and LSB of Y Data output register
        Angle= atan2((double)Y,(double)X)*(180/3.14159265)+180;//单位:角度 (0~360)
        Angle*=10;
        Acr=(uint)Angle;
                        LCD_set_xy(2,0);
        Send_DATA(Acr%10000/1000+0x30,1);
        Send_DATA(Acr%1000/100+0x30,1);
        Send_DATA(Acr%100/10+0x30,1);
        Send_DATA('.',1);
        Send_DATA(Acr%10+0x30,1);
        Delay(50000);
ID:223438 发表于 2017-8-4 23:05 | 显示全部楼层
怎么没人帮帮我。
ID:645297 发表于 2020-4-30 12:20 | 显示全部楼层
51hww34 发表于 2017-8-4 23:05
怎么没人帮帮我。
你搞懂了嘛
