查看: 6008|回复: 1
STC12单片机两路PWM输出(占空比可调)程序
ID:224782 发表于 2017-8-4 18:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*                                                     PWM输出(可调)程序
*        Don.2017.7
#include <STC12C5A60S2.h>
#include <intrins.h>
typedef unsigned char uchar8;
sbit PWM0_ADD = P2 ^ 0;
sbit PWM0_CUT = P2 ^ 1;
sbit PWM1_ADD = P2 ^ 2;
sbit PWM1_CUT = P2 ^ 3;
void PWM0_OUT( )
        CCON = 0x00;
        //PCA控制器清零
        CL = 0;
        CH = 0;
        //16位PAC计数器清零
        TMOD = 0x42;
        //定时器0工作在模式2(8位自动重装)
        TL0 = ;
        TH0 = ;
        //写入初值
        //计算: 初值 = (256 - 外部晶振频率 / PCA时钟源频率)H
        //PCA时钟源频率 = 256 * PWM频率
        AUXR = 0X80;
        //T0工作在1T模式
        TR0 = 1;
        //T0开始工作
        CMOD = 0x08;
        //设置计数器时钟源
        //0x00:系统时钟/12, 0x02:系统时钟/2
        //0x04: 定时器T0溢出脉冲, 0x06: P1.2引脚输入的外部时钟
        //0x08:系统时钟, 0x0a: 系统时钟/4
        //0x0c: 系统时钟/6, 0x0e: 系统时钟/8
        //PWM波的频率 = CMOD数值(10位)/256
        CCAPM0 = 0x42;
        //8位PWM P1.3输出
        //0x42:无中断;0x53:下降沿产生中断;
        //0x63:上升沿产生中断;0x73:跳变沿产生中断
        CCAP0L = 0xc0;
        CCAP0H = 0xc0;
        //占空比设置:数值 / 256 * 100%
        //0xc0:占空比为25%,0x80:占空比为50%,0x40:占空比为75%
        CR = 1;
void PWM1_OUT( )
        CCON = 0x00;
        //PCA控制器清零
        CL = 0;
        CH = 0;
        //16位PAC计数器清零
        CMOD = 0x08;
        //设置计数器时钟源
        CCAPM1 = 0x42;
        //8位PWM P1.3输出
        CCAP1L = 0xc0;
        CCAP1H = 0xc0;
        CR = 1;
void PWM0_Alter(uchar8 type0, uchar8 change0)
//type = 0减占空比,1增加占空比 change: 0x0c约5%,0x05约2%
        if(type0  ==  0)
                    if(CCAP0L < 0xe6)   //<90%
                        CCAP0L += change0;
                    CCAP0H += change0;
                if(CCAP0L > 0x19)  //>10%
                        CCAP0L -= change0;
                           CCAP0H -= change0;
void PWM1_Alter(uchar8 type1, uchar8 change1)
//type1 = 0减占空比,1增加占空比 change1: 0x0c约5%,0x05约2%
        if(type1  ==  0)
                    if(CCAP1L < 0xe6)   //<90%
                        CCAP1L += change1;
                    CCAP1H += change1;
                if(CCAP1L > 0x19)  //>10%
                        CCAP1L -= change1;
                           CCAP1H -= change1;
void PWM_Alter_Drive( )
        if(PWM0_ADD == 0)
                _nop_( );_nop_( );_nop_( );_nop_( );
                //按键消抖
                while(PWM0_ADD == 0);
                //按键释放才跳出执行下一步
                PWM0_Alter(1, 0x05);
        if(PWM0_CUT == 0)
                while(PWM0_CUT == 0);
                PWM0_Alter(0, 0x05);
        if(PWM1_ADD == 0)
                //按键消抖
                while(PWM1_ADD == 0);
                //按键释放才跳出执行下一步
                PWM1_Alter(1, 0x05);
        if(PWM1_CUT == 0)
                while(PWM1_CUT == 0);
                PWM1_Alter(0, 0x05);
void main( )
        P1M0 = 0x00;
        P1M1 = 0x00;
        P2M0 = 0x00;
        P2M1 = 0x00;
        //配置标准I/O口
        PWM0_OUT( );
        PWM1_OUT( );
                 PWM_Alter_Drive( );
收藏收藏3 分享淘帖 顶 踩
ID:224782 发表于 2017-8-4 19:49 | 只看该作者
可调占空比
