查看: 19450|回复: 21
stm32 PWM调速电机控制源码
ID:226590 发表于 2017-8-10 15:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
** 红龙开发板
** 实验名: 红龙板_基定时器(带视频)
** KEIL MDK-ARM Standard Version:4.11
** 软件库(keil) Version: unused
** 固件库(ST) Version: V3.5
** 使用外设: 基定时器
程序测试说明: #define TEST_1  TEST_1 LED灯测试
              #define TEST_2  TEST_2 按键测试
LED 测试说明:注释掉 TEST_2 按键测试   //#define TEST_2
              初始化系统时钟
              LED灯的IO口初始化
测试现象:    JLINK下载运行后,三个LED灯轮番闪烁。
TIM 测试说明:TIM定时器定时点灯(高级定时器TIM1,通用定时器TIM2 均可设置,
                                 其他定时器以此为例,均能快速掌握)
        步骤:初始化系统时钟
              中断初始化
              TIM初始化
        注意:中断使能(NVIC)
              中断函数调用(STM32F10X_IT.C)
实验现象:
      JLINK下载运行后
      软件:定时时间到,发生一次更新事件Update;
      硬件:LED1灯按设置闪烁。打开和关闭LED3由亮渐灭控制。
*函数名称:void RCC_Configuration(void)
*功能说明:系统时钟初始化配置
*           RCC_HSICmd(ENABLE);//使能内部高速晶振 ;
*          RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//选择内部高速时钟作为系统时钟SYSCLOCK=8MHZ
*           RCC_HCLKConfig(RCC_SYSCLK_Div1);       //选择HCLK时钟源为系统时钟SYYSCLOCK
*           RCC_PCLK1Config(RCC_HCLK_Div4);        //APB1时钟为2M
*           RCC_PCLK2Config(RCC_HCLK_Div4);        //APB2时钟为2M
*           RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE);//使能APB2外设GPIOB时钟
void RCC_Configuration(void);
    /* RCC system reset(for debug purpose) */
      RCC_DeInit();
      /* Enable HSE */
      RCC_HSEConfig(RCC_HSE_ON);
      /* Wait till HSE is ready */
      while (RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08);
#define   GPIO_IN     GPIOB
#define   GPIO_PWM     GPIOA
#define   GPIO_Pin_IN1    GPIO_Pin_1
#define   GPIO_Pin_IN2    GPIO_Pin_2
#define   GPIO_Pin_IN3    GPIO_Pin_5
#define   GPIO_Pin_IN4    GPIO_Pin_6
#define   GPIO_PWM_A      GPIO_Pin_8
#define   GPIO_PWM_B      GPIO_Pin_11
#define   IN1_H       GPIO_SetBits(GPIO_IN,GPIO_Pin_IN1);
#define   IN1_L       GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN1);
#define   IN2_H       GPIO_SetBits(GPIO_IN,GPIO_Pin_IN2);
#define   IN2_L       GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN2);
#define   IN3_H       GPIO_SetBits(GPIO_IN,GPIO_Pin_IN3);
#define   IN3_L       GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN3);
#define   IN4_H       GPIO_SetBits(GPIO_IN,GPIO_Pin_IN4);
#define   IN4_L       GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN4);
#define   PWM_A_OFF   1000
#define   PWM_B_OFF   1000
  1. #define   GPIO_IN     GPIOB
  2. #define   GPIO_PWM     GPIOA
  3. #define   GPIO_Pin_IN1    GPIO_Pin_1
  4. #define   GPIO_Pin_IN2    GPIO_Pin_2
  5. #define   GPIO_Pin_IN3    GPIO_Pin_5
  6. #define   GPIO_Pin_IN4    GPIO_Pin_6
  7. #define   GPIO_PWM_A      GPIO_Pin_0
  8. #define   GPIO_PWM_B      GPIO_Pin_1
  9. #define   IN1_H       GPIO_SetBits(GPIO_IN,GPIO_Pin_IN1);
  10. #define   IN1_L       GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN1);
  11. #define   IN2_H       GPIO_SetBits(GPIO_IN,GPIO_Pin_IN2);
  12. #define   IN2_L       GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN2);
  13. #define   IN3_H       GPIO_SetBits(GPIO_IN,GPIO_Pin_IN3);
  14. #define   IN3_L       GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN3);
  15. #define   IN4_H       GPIO_SetBits(GPIO_IN,GPIO_Pin_IN4);
  16. #define   IN4_L       GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN4);
  17. #define   PWM_A_OFF   1001
  18. #define   PWM_B_OFF   1001
  19. #include "pbdata.h"
  20. void TimCounterInit(int rate_1,int rate_2);
  21. void Gpio_PWM_Init(void);
  22. void Gpio_M_Init(void);
  23. void NVIC_Configuration(void);
  24. void TurnLeft(void);
  25. void TurnRight(void);
  26. void straight(void);
  27. void sternway(void);
  28. int A,B;
  29. /****主函数****/
  30. int main(void)
  31. {
  32.           u8 flag=1;
  33.                 Gpio_PWM_Init();
  34.           Gpio_M_Init();
  35.     while(flag==1)
  36.                 {
  37.                         flag=0;
  38.                         straight();//直走
  39.                         delay_ms(1000);
  40.                         delay_ms(1000);
  41.                         delay_ms(1000);
  42.                   TurnLeft();//左转
  43.                         delay_ms(1000);
  44.                         delay_ms(500);
  45.                         straight();
  46.       delay_ms(1000);
  47.                         TurnRight();
  48.       delay_ms(1000);
  49.       delay_ms(500);
  50.                         straight();
  51.       delay_ms(500);
  52.                         TurnRight();
  53.       delay_ms(1000);
  54.        straight();
  55.       delay_ms(1000);
  56.       delay_ms(1000);
  57.       delay_ms(1000);
  58.
  59. //                /*    回到中线     */
  60. //
  61. //                        TurnLeft(1.5);
  62. //                        straight(0.5);
  63. //                        TurnLeft(0.5);
  64. //      straight(4);
  65. //                        /*  回到中线   */
  66. //
  67. //                        TurnRight(1.5);
  68. //                        straight(0.5);
  69. //                        TurnRight(1);
  70. //      straight(2);
  71. //
  72. //                        /*    回到中线     */
  73. //
  74. //                        TurnLeft(1.5);
  75. //                        straight(0.5);
  76. //                        TurnLeft(1);
  77. //                        straight(2);
  78. //                        sternway(1);
  79.
  80.                         TimCounterInit(PWM_A_OFF,PWM_B_OFF);
  81.                 }
  82. }
  83. void TurnLeft()
  84. {
  85.          IN1_H IN2_L
  86.          IN3_H IN4_L
  87.          A=500;
  88.          B=800;
  89.          TimCounterInit(A,B);
  90. }
  91. void TurnRight(void)
  92. {
  93.          IN1_H IN2_L
  94.          IN3_H IN4_L
  95.          A=800;
  96.          B=500;
  97.         TimCounterInit(A,B);
  98. }
  99. void straight(void)
  100. {
  101.          IN1_H IN2_L
  102.          IN3_H IN4_L
  103.          A=600;
  104.          B=600;
  105.   TimCounterInit(A,B);
  106. }
  107. void sternway(void)
  108. {
  109.         IN1_L        IN2_H
  110.         IN3_L IN4_H
  111.         A=700;
  112.         B=700;
  113.         TimCounterInit(A,B);
  114. }
  115. void Gpio_PWM_Init(void)
  116. {
  117.         GPIO_InitTypeDef GPIO_InitStructure;
  118.   //以下设定是将TIM2的通道1(PA0)的复用功能打开,这很重要很容易被忘掉
  119.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  120.         GPIO_InitStructure.GPIO_Pin        = GPIO_PWM_A|GPIO_PWM_B;              //选择led1
  121.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;          //管脚频率为50MHZ
  122.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;         //模式为复用推挽输出
  123.   GPIO_Init(GPIO_PWM, &GPIO_InitStructure);           //初始化led1寄存器
  124. }
  125. void Gpio_M_Init(void)
  126. {
  127.         GPIO_InitTypeDef GPIO_InitStructure;
  128.
  129.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  130.         GPIO_InitStructure.GPIO_Pin        = GPIO_Pin_IN1|GPIO_Pin_IN2|GPIO_Pin_IN3|GPIO_Pin_IN4;              //选择led1
  131.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;          //管脚频率为50MHZ
  132.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  133.   GPIO_Init(GPIO_IN, &GPIO_InitStructure);           //初始化led1寄存器
  134. }
  135. /********************************************************************************************
  136. *函数名称:void TimCounterInit(void)
  137. *功能说明:TIM计数初始化配置
  138. *               TIMCLK = 72 MHz, Prescaler = TIM_PSC, TIM counter clock = TIMCLK/TIM_COUNTER MHz
  139. *******************************************************************************************/
  140. void TimCounterInit(int rate_1,int rate_2)        //rate可以改变占空比
  141. {
  142.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  143.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  144.
  145.         /* TIM时钟使能 */
  146.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  147.         /* 基定时器初始化 */
  148.         TIM_TimeBaseStructure.TIM_Period = 1000000*0.001;        //计数值 1000;须介于0~65535
  149.         TIM_TimeBaseStructure.TIM_Prescaler = 72;          //分频系数,为了设定值数值较大,这里选得较小
  150.         TIM_TimeBaseStructure.TIM_ClockDivision = 0;                //时钟分割:计数模式中无作用
  151.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;        //计数模式,向上计数
  152.         TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;        //重复计数值
  153.         TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);                //初始化TIM
  154.
  155.         /* PWM1 Mode configuration: Channel1 */
  156.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;//输出模式设定
  157.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//输出模式使能
  158.   TIM_OCInitStructure.TIM_Pulse = rate_1; //设置占空比,0时全低电平,1001时全高电平.须介于0~65535
  159.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//输出比较极性;最终输出值是高/低电平
  160.
  161.         TIM_OC1Init(TIM2, &TIM_OCInitStructure);//输出通道x,参数写入
  162.         TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);//使能通道x预装载寄存器
  163.
  164.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;//输出模式设定
  165.         TIM_OCInitStructure.TIM_Pulse = rate_2; //设置占空比,0时全低电平,1001时全高电平.须介于0~65535
  166.         TIM_OC2Init(TIM2, &TIM_OCInitStructure);//输出通道x,参数写入
  167.         TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);//使能通道x预装载寄存器
  168.         TIM_Cmd(TIM2, ENABLE);                                                //使能TIM
  169. }
1.PWM调速电机控制(6.10).rar (279.69 KB, 下载次数: 300)
收藏收藏7 分享淘帖 顶顶 踩踩
ID:151000 发表于 2017-8-10 23:55 | 只看该作者
谢谢楼主分享
ID:137742 发表于 2017-11-8 21:41 | 只看该作者
下来学习一下
ID:244172 发表于 2017-12-1 15:21 | 只看该作者
谢谢漏卮分享
ID:258069 发表于 2017-12-6 10:41 | 只看该作者
新人  黑币不够   不能下载 能不能麻烦楼主发一下我的邮箱呀  398262842@qq.com   拜托啦
ID:265454 发表于 2017-12-22 20:39 | 只看该作者
学习一下,现在在做项目需要用
ID:343208 发表于 2018-6-1 22:51 | 只看该作者
谢谢楼主分享
ID:337376 发表于 2018-6-3 22:19 | 只看该作者
谢谢分享~~~
ID:386504 发表于 2018-8-22 16:22 | 只看该作者
新人  黑币不够   不能下载 能不能麻烦楼主发一下我的邮箱呀  475225389@qq.com   拜托啦
ID:386504 发表于 2018-8-22 16:23 | 只看该作者
新人不能下载 。麻烦楼主发一下我的邮箱 475225389@qq.com  。想学习学习,麻烦楼z
ID:386504 发表于 2018-8-22 17:09 | 只看该作者
glxmf 发表于 2017-11-8 21:41
**** 作者被禁止或删除 内容自动屏蔽 ****
之前那个STM32 电机控制的底层还有没有,能发给我一下嘛。475225389@qq.com。学习学习
ID:395317 发表于 2018-9-25 18:23 | 只看该作者
为什么我输入到F103里面 通过L298n后 蜂鸣器一直在响
蜂鸣器一直在响
ID:375272 发表于 2018-9-26 10:31 | 只看该作者
谢谢分享~
ID:324611 发表于 2019-1-3 15:07 | 只看该作者
好东西,学习下。
ID:480593 发表于 2019-2-25 19:58 | 只看该作者
谢谢分享
ID:413719 发表于 2019-4-19 14:52 | 只看该作者
谢谢楼主分享
ID:538948 发表于 2019-5-17 16:53 | 只看该作者
请问下文件为什么没有mdk打开文件。。。
ID:505027 发表于 2019-5-21 22:31 | 只看该作者
感谢分享,学习一下
ID:342094 发表于 2019-6-20 15:58 | 只看该作者
你好,怎么找不到OBJ文件
ID:584441 发表于 2019-7-18 20:20 | 只看该作者
在做智能小车中,感谢分享
ID:476093 发表于 2020-4-13 20:27 | 只看该作者
这个复杂么?我也想学
