查看: 2206|回复: 0
单片机贪吃蛇游戏
ID:230970 发表于 2017-9-11 13:06 来自触屏版 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/***********************************************************功能说明:贪吃蛇编译环境:keil4MCU     :STC89C52RC时钟频率: 22.1184MHz注意:该例程中“过关”不能在keil4编译环境中正常显示************************************************************//*****************************************************************                    /^\/^\                  _|__|  O|         \/     /~     \_/ \          \____|__________/  \                 \_______      \                         `\     \                 \                           |     |                  \                          /      /                    \                         /     /                       \\                       /      /                         \ \                      /     /                            \  \                    /     /             _----_            \   \                   /     /           _-~      ~-_         |   |                 (      (        _-~    _--_    ~-_     _/   |                   \      ~-____-~    _-~    ~-_    ~-_-~    /                     ~-_           _-~          ~-_       _-~                           ~--______-~                ~-___-~  *****************************************************************/#include "stc.h"#include "Lcd12864.h"#include "Key.h"#define uchar unsigned char#define uint unsigned intstatic unsigned long Seed = 1;#define A 48271L#define M 2147483647L#define Q (M / A)#define R (M % A)/************************************伪随机数发生器*************************************/double Random(void){        long TmpSeed;        TmpSeed=A*(Seed%Q)-R*(Seed/Q);        if(TmpSeed>=0)                Seed=TmpSeed;        else                Seed=TmpSeed+M;        return (double)Seed/M;}/**************************************为伪随机数发生器播种***************************************/void InitRandom(unsigned long InitVal){        Seed=InitVal;}//延时子程序void delay(unsigned int t){          unsigned int i,j;        for(i=0;i<t;i++)                for(j=0;j<10;j++);    }/*********************************初始化MPU**********************************/void InitCpu(void){        TMOD=0x01;        TH0=0;        TL0=0;        TR0=1;        ET0=1;        EA=1;}#define N 25struct Food{        unsigned char x;        unsigned char y;        unsigned char yes;}food;//食物结构体struct Snake{        unsigned char x[N];        unsigned char y[N];        unsigned char node;        unsigned char direction;        unsigned char life;}snake;//蛇结构体unsigned char Flag=0;unsigned char Score=0;unsigned char Speed=5;                   //speed越大,速度越慢unsigned char KeyBuffer=0;#define FUNC 1                                   //(P3^1)表示级别#define UP 2                                   //(P3^3)表示左#define DOWN 3                                   //(P3^5)表示右#define LEFT 4                                   //(P3^4)表示下#define RIGHT 5                                   //(P3^2)表示上#define PASSSCORE 20                   //预定义过关成绩void Timer0Int(void) interrupt 1{        switch(OSReadKey())        {                case 5:                                KeyBuffer=FUNC;                                                  //表示级别                                /*if(++Speed>=10)                                        Speed=1;                                   Flag|=1<<1;//速度变化标志置1*/                                break;                case 21:                                KeyBuffer=DOWN;                                                 //表示右                                /*if(snake.direction!=2)                                        snake.direction=1;*/                                break;                case 13:                                KeyBuffer=UP;                                                 //表示左                                /*if(snake.direction!=1)                                        snake.direction=2;*/                                break;                case 9:                                KeyBuffer=RIGHT;                                         //表示上                                /*if(snake.direction!=4)                                        snake.direction=3;*/                                break;                   case 17:                                KeyBuffer=LEFT;                                                 //表示下                                /*if(snake.direction!=3)                                        snake.direction=4;*/                                break;                default:                                break;        }}/******************************画墙壁,初始化界面*******************************/void DrawBoard(void){        unsigned char n;        for(n=0;n<31;n++)        {                Lcd_Rectangle(3*n,0,3*n+2,2,1);                Lcd_Rectangle(3*n,60,3*n+2,62,1);        }        for(n=0;n<21;n++)        {                Lcd_Rectangle(0,3*n,2,3*n+2,1);                Lcd_Rectangle(90,3*n,92,3*n+2,1);                        }        Lcd_HoriLine(93,31,35,1);        Lcd_HoriLine(93,63,35,1);}/***************************打印成绩****************************/void PrintScore(void){        unsigned char Str[3];        Lcd_WriteStr(6,0,"成绩");        Str[0]=(Score/10)|0x30;//十位        Str[1]=(Score%10)|0x30;//个位        Str[2]=0;        Lcd_WriteStr(7,1,Str);}/********************************打印速度级别*********************************/void PrintSpeed(void){        unsigned char Str[2];        Lcd_WriteStr(6,2,"级别");        Str[0]=Speed|0x30;        Str[1]=0;        Lcd_WriteStr(7,3,Str);}/***********************************游戏结束处理************************************/void GameOver(void){        unsigned char n;        Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隐出食物        for(n=1;n<snake.node;n++)        {                Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,0);//消隐食物,蛇头已到墙壁内,故不用消去                        }        if(snake.life==0)//如果蛇还活着                Lcd_WriteStr(2,1,"过关");        else             //如果蛇死了                Lcd_WriteStr(2,1,"输了");        Lcd_WriteStr(1,2,"游戏结束");}/********************************游戏的具体过程,也是贪吃蛇算法的关键部分*********************************/void GamePlay(void){        unsigned char n;        InitRandom(TL0);        food.yes=1;//1表示需要出现新事物,0表示已经存在食物尚未吃掉        snake.life=0;//表示蛇还活着        snake.direction=DOWN;        snake.x[0]=6;snake.y[0]=6;        snake.x[1]=3;snake.y[1]=6;        snake.node=2;        PrintScore();        PrintSpeed();        while(1)        {                if(food.yes==1)                {                        while(1)                        {                                food.x=Random()*85+3;                                food.y=Random()*55+3;//获得随机数                                        while(food.x%3!=0)                                        food.x++;                                while(food.y%3!=0)                                        food.y++;                            for(n=0;n<snake.node;n++)//判断产生的食物坐标是否和蛇身重合                                {                                        if((food.x==snake.x[n])&&(food.y==snake.y[n]))                                                break;                                }                                if(n==snake.node)                                {                                        food.yes=0;                                        break;//产生有效的食物坐标                                }                        }                }                if(food.yes==0)                {                        Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,1);                }                        for(n=snake.node-1;n>0;n--)                {                        snake.x[n]=snake.x[n-1];                        snake.y[n]=snake.y[n-1];                }                switch(snake.direction)                {                        case DOWN:snake.x[0]+=3;break;                        case UP:snake.x[0]-=3;break;                        case RIGHT:snake.y[0]-=3;break;                        case LEFT:snake.y[0]+=3;break;                        default:break;                }                for(n=3;n<snake.node;n++)//从第三节开始判断蛇头是否咬到自己                {                        if(snake.x[n]==snake.x[0]&&snake.y[n]==snake.y[0])                        {                                GameOver();                                snake.life=1;                                break;                        }                }                if(snake.x[0]<3||snake.x[0]>=90||snake.y[0]<3||snake.y[0]>=60)//判蛇头是否撞到墙壁                {                        GameOver();                        snake.life=1;                }                if(snake.life==1)                        break;//蛇死,则跳出while(1)循环                if(snake.x[0]==food.x&&snake.y[0]==food.y)//判蛇是否吃到食物                {                        Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隐食物                        snake.x[snake.node]=200;                        snake.y[snake.node]=200;//产生蛇新的节坐标先放在看不见的位置                        snake.node++;//蛇节数加1                        food.yes=1;//食物标志置1                        if(++Score>=PASSSCORE)                        {                                PrintScore();                                GameOver();                                break;                        }                        PrintScore();                }                for(n=0;n<snake.node;n++)                {                        Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,1);                }//根据蛇的节数画出蛇                delay(Speed*1000);          //调速                delay(Speed*1000);                Lcd_Rectangle(snake.x[snake.node-1],snake.y[snake.node-1],snake.x[snake.node-1]+2,snake.y[snake.node-1]+2,0);                switch(KeyBuffer)                {                        case FUNC:                                        KeyBuffer=0;                                        if(++Speed>=10)                                                Speed=1;                                           PrintSpeed();                                        break;                        case DOWN:                                        KeyBuffer=0;                                        if(snake.direction!=UP)                                                snake.direction=DOWN;                                        break;                        case UP:                                        KeyBuffer=0;                                        if(snake.direction!=DOWN)                                                snake.direction=UP;                                        break;                        case RIGHT:                                        KeyBuffer=0;                                        if(snake.direction!=LEFT)                                                snake.direction=RIGHT;                                        break;                           case LEFT:                                        KeyBuffer=0;                                        if(snake.direction!=RIGHT)                                                snake.direction=LEFT;                                        break;                        default:                                        break;                }                                }//结束while(1)}void Main(){          InitCpu();//初始化CPU        Lcd_Reset(); //初始化LCD屏        Lcd_WriteStr(2,1,"航峰兴业");        delay(5000);        delay(5000);        Lcd_WriteCmd(0x01);   //清除显示,并且设定地址指针为00H        Lcd_Clear(0);//清屏        DrawBoard();//画界面        GamePlay();//玩游戏        GameOver();//游戏结束        while(1);//要想重玩,只能重启,可继续完善该游戏
