查看: 2481|回复: 0
请问各位大神,如何用一个单片机控制两个步进电机?
[img]file:///C:\Users\Administrator\Documents\Tencent Files\1425274073\Image\C2C\7$JNVZ[1F(T]KKX99BG}{68.png[/img]
#include<reg51.h>
uchar code FFW[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09};
uchar code REV[]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01};
sbit K1=P3^0;
sbit K2=P3^1;
sbit K3=P3^2;
sbit K4=P3^3;
sbit K5=P3^4;
void delayMS(uint ms)
    uchar i;
        while(ms--)
            for(i=0;i<120;i++);
  void SETP_MOTOR_FFW(uchar n)
          uchar i,j;
          uint ms=200;
          for(i=0;i<5*n;i++)
            for(j=0;j<8;j++)
                    if(K3==0) break;
                        if(K2==0) break;
                 if(K4==0)
               P0=0xf6;
               ms=50;
                  if(K5==0)
               P0=0xee;
               ms=500;
                         P1=FFW[j];
                    delayMS(ms);
void SETP_MOTOR_REV(uchar n)
    uchar i,j;
        uint ms=200;
          for(i=0;i<5*n;i++)
            for(j=0;j<8;j++)
                    if(K1==0) break;
                        if(K3==0) break;
                    if(K4==0)
                  P0=0xf5;
                  ms=50;
                     if(K5==0)
                  P0=0xed;
                  ms=500;
                        P1=REV[j];
                    delayMS(ms);
    uchar N=3;
            uchar ms=50;
            if(K1==0)
                    P0=0xfe;
                    SETP_MOTOR_FFW(N);
                          if(K3==0) break;
                  else if(K2==0)
                          P0=0xfd;
              SETP_MOTOR_REV(N);
                          if(K3==0) break;
                          P0=0xfb;
                          P1=0x03;
