查看: 4009|回复: 0
C++多点拟合线代码
ID:233602 发表于 2017-9-21 10:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//A program finds the best-fitted straight line to the x and y values, and then writes
//the original x, y values and the new y values on the line (for each x) to a data file.
#include<iostream>;                //include the first library
#include<fstream>;                //include the fstream library
using namespace std;        //tell complier that we will use entire namespace standard
void main(void)
double ax,ay;                        //declare two double variables
double x[20]={1.0000,2.0000,3.0000,4.0000,5.0000,6.0000,7.0000,8.0000,9.0000,10.0000,11.0000,12.0000,13.0000,14.0000,15.0000,16.0000,17.0000,18.0000,19.0000,20.0000};
                                                //declare a double array with length 20 to store original x values
double y[20]={13.3068,15.0928,16.2509,18.6416,23.6987,27.6380,26.1267,28.4638,33.9061,35.6735,36.0599,39.9298,40.6010,40.0202,43.9743,43.4650,45.7730,50.0811,51.1671,52.4696};
                                                //declare a double array with length 20 to store original y values
double sumx=0, sumy=0;  //declare two double variables
double sub1=0, sub2=0, sumsub1=0, sumsub2=0;
                                                //declare four double variables
double a,b;                                //declare two double variables
for(int i=0;i<20;i++)        //set a for loop to calculate the sum of original x values
                                                //and the sum of original y values
sumx=sumx+x[i];
sumy=sumy+y[i];
ax=sumx/20;                                //calculate the average of x values
ay=sumy/20;                                //calculate the average of y values
cout<<"The average value of X is:"<<ax<<"\nThe average value of Y is:"<<ay;
                                                //Display the average of all x values and y values
for(int j=0;j<20;j++)        //set a for loop to calculate the component
                                                //of equation of linear regression         to get the value of slope
        sub1=(x[j]-ax)*(y[j]-ay);
        sub2=(x[j]-ax)*(x[j]-ax);
        sumsub1=sumsub1+sub1;
        sumsub2=sumsub2+sub2;
a=sumsub1/sumsub2;                //the  equation to calculate the slope
                                                //by using the value get from the last for loop
b=ay-a*ax;                                //calculate the value of constant b
cout<<"\nThe value of slope 'a' is:"<<a<<"\nThe value of 'b' is:"<<b;
                                                 //display the value of slope a and the value of constant b
ofstream out("data.dat");//opening a file and output the value of original
                                                 //x, y and new y to a data file named "data.dat"
out<<"x"<<"\t\t"<<"y"<<"\t\t"<<"new y"<<endl;
                                                 //set the format of values display in data file
for(int k=0;k<20;k++)         //set a for loop to display
                                                 //the value of x, y and calculated new y
out<<x[k]<<"\t\t"<<y[k]<<"\t\t"<<a*x[k]+b<<endl;
cout<<"\nThe data is output to the file\n";
                                                 //indicate the data is stored in the data file
system("pause");                 //keep the screen otherwise it will appear fast
