查看: 6971|回复: 2
TM1638资料(.c文件和头文件)
ID:234748 发表于 2017-9-21 21:25 | 显示全部楼层 |阅读模式
//-------------------------------------------------------------------------------TM1638.c-------------------------------------------------------------------
#include "TM1638.h"
#include "stdint.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,
                        0x66,0x6D,0x7D,0x07,
                        0x7F,0x6F,0x77,0x7C,
                        0x39,0x5E,0x79,0x71};
#define ADD 10
#define MINUS 11
#define EQUAL 12
#define CLEAR 13
#define PLUS 14
#define DIVIDE 15
unsigned int flag;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void TM1638_Write(unsigned char DATA)   //写数据函数
unsigned char i;
DIO_OUT;
for(i=0;i<8;i++)
   CLK_low;
   if(DATA & 0x01){
    DIO_high;
   }else{
    DIO_low;
   CLK_high;
   DATA>>=1;
unsigned char TM1638_Read(void)     //读数据函数
unsigned char i;
unsigned char temp=0;
DIO_IN;
STB_low;
for(i=0;i<8;i++)
    temp>>=1;
    CLK_low;
    _delay_us(100);
    if(DIO_READ)
     temp |= 0x80;
     temp &= 0x7f;
    CLK_high;
return temp;
void Write_COM(unsigned char cmd)  //发送命令字
CLK_high;
STB_high;
STB_low;
TM1638_Write(cmd);
STB_high;
*函数功能:读取按键值
*输入参数:无
*输出参数:无
*返回值:  无
unsigned char Read_key(void)
unsigned char c[4];
unsigned int key_value=0x00;
unsigned int i;
STB_high;
STB_low;
TM1638_Write(0x42);
_delay_us(1);
for(i=0;i<4;i++)
  c[i]=TM1638_Read();
STB_high;
if(c[0]&BIT2)
  key_value |= BIT1;
else if(c[0]&BIT6)
  key_value |= BIT4;
else if(c[0]&BIT0)
  key_value |= BIT2;
else if(c[0]&BIT1)
  key_value |= BIT3;
else if(c[0]&BIT5)
  key_value |= BIT6;
else if(c[0]&BIT4)
  key_value |= BIT5;
else if(c[1]&BIT0)
  key_value |= BITB;
else if(c[1]&BIT4)
  key_value |= BITC;
else if(c[1]&BIT1)
  key_value |= BITA;
else if(c[2]&BIT0)
  key_value |= BITD;
else if(c[2]&BIT4)
  key_value |= BIT8;
else if(c[2]&BIT5)
  key_value |= BIT9;
else if(c[2]&BIT6)
  key_value |= BIT7;
else if(c[3]&BIT0)
  key_value |= BITF;
else if(c[3]&BIT1)
  key_value |= BITE;
else if(c[3]&BIT2)
  key_value |= BIT0;
//特殊符号‘AC’ ‘+’ ‘-’ ‘=’
else if(c[1]&BIT2)
     flag<=CLEAR;
  Write_allLED(0);//按下AC,清除所有显示
else if(c[1]&BIT6)
  flag<=ADD;//按下+,清除所有显示
else if(c[2]&BIT1)
  flag<=EQUAL;//按下=,清除所有显示
else if(c[2]&BIT2)
     flag<=MINUS;//按下-,清除所有显示
for(i=0;i<16;i++)
  if((0x01<<i)==key_value)
   break;
return i;
void Write_DATA(unsigned char add,unsigned char DATA)  //指定地址写入数据
Write_COM(0x44);
STB_low;
TM1638_Write(0xc0|add);
TM1638_Write(DATA);
STB_high;
void init_TM1638(void)
Write_allLED(0xff);
_delay_ms(100);
Write_allLED(0);
void  Write_allLED(unsigned char DATA){
unsigned char i;
Write_COM(0x8F);//显示控制
Write_COM(0x40); //数据命令
STB_low;
TM1638_Write(0xc0);
for(i=0;i<16;i++)
    TM1638_Write(DATA);
STB_high;
//---------------------------------------------------------------------------TM1638.h------------------------------------------------------------------------------
#ifndef _TM1638_H
#define _TM1638_H
#include "msp430f6638.h"
#include <stdint.h>
#define CPU_F ((double)20000000)
#define _delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define _delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define DIO_high (P3OUT |= BIT5)
#define DIO_low  (P3OUT &= ~BIT5)
#define CLK_high (P3OUT |= BIT4)
#define CLK_low  (P3OUT &= ~BIT4)
#define STB_high (P3OUT |= BIT2)
#define STB_low  (P3OUT &= ~BIT2)
#define DIO_IN   (P3DIR &= ~BIT5) //输入状态
#define DIO_OUT   (P3DIR |= BIT5)  //输出状态
#define DIO_READ  (P3IN & BIT5)   //读引脚电平
void TM1638_Write(unsigned char DATA);   //写数据函数
unsigned char TM1638_Read(void);         //读数据函数
void Write_COM(unsigned char cmd);       //发送命令字
unsigned char Read_key(void);
void Write_DATA(unsigned char add,unsigned char DATA);  //指定地址写入数据
void Write_allLED(unsigned char flag);     //控制全部LED函数,flag表示LED状态
void init_TM1638(void);
#endif
ID:585335 发表于 2019-7-16 20:01 | 显示全部楼层
好像不行啊
按键有问题
