查看: 11560|回复: 8
stc89c52rc驱动rc522源程序 实测有效
ID:166645 发表于 2017-9-27 12:54 | 显示全部楼层 |阅读模式
之前自己用这个模块的时候也找了很多了历程来测试,但是都是没有通过,最后得出的结论是spi通信的问题,,自己也懒得去找问题,,所以就搁置了现在把调试通过的程序拿来分享给大家,可以读卡的,其他功能需要自己开发哦
  1. #include "lpcreg.h"
  2. #include "main.h"
  3. #include "mfrc522.h"
  4. #include   <STDIO.H>
  5. #include <string.h>
  6. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  7. //M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令
  8. //4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
  9. unsigned char code data2[4]  = {0,0,0,0x01};
  10. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  11. unsigned char g_ucTempbuf[20];
  12. void delay1(unsigned int z)
  13. {
  14.         unsigned int x,y;
  15.         for(x=z;x>0;x--)
  16.         for(y=110;y>0;y--);
  17. }
  18. void main( )
  19. {
  20.      unsigned char status,i;
  21.           unsigned int temp;
  22.      InitializeSystem( );
  23.      PcdReset();
  24.      PcdAntennaOff();
  25.      PcdAntennaOn();
  26.      while (1)
  27.      {
  28.
  29.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//寻卡
  30.          if (status != MI_OK)
  31.          {
  32.                                 InitializeSystem( );
  33.                                 PcdReset();
  34.                                 PcdAntennaOff();
  35.                                 PcdAntennaOn();
  36.                           continue;
  37.          }
  38.
  39.                         printf("读出的卡的类型:");
  40.             for(i=0;i<2;i++)
  41.                                         {
  42.                                                 temp=g_ucTempbuf[i];
  43.                                                 printf("%X",temp);
  44.
  45.
  46.                                         }
  47.
  48.          status = PcdAnticoll(g_ucTempbuf);//防冲撞
  49.          if (status != MI_OK)
  50.          {    continue;    }
  51.
  52.                                         ////////以下为超级终端打印出的内容////////////////////////
  53.
  54.                                         printf("卡序列号:");        //超级终端显示,
  55.                                         for(i=0;i<4;i++)
  56.                                         {
  57.                                                 temp=g_ucTempbuf[i];
  58.                                                 printf("%X",temp);
  59.
  60.                                         }
  61.                                         ///////////////////////////////////////////////////////////
  62.          status = PcdSelect(g_ucTempbuf);//选定卡片
  63.          if (status != MI_OK)
  64.          {    continue;    }
  65.
  66.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//验证卡片密码
  67.          if (status != MI_OK)
  68.          {    continue;    }
  69.
  70.          status = PcdWrite(1, data1);//写块
  71.          if (status != MI_OK)
  72.          {    continue;    }
  73.                 while(1)
  74.                 {
  75.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//寻卡
  76.          if (status != MI_OK)
  77.          {
  78.                  InitializeSystem( );
  79.                 PcdReset();
  80.                 PcdAntennaOff();
  81.                 PcdAntennaOn();
  82.                           continue;
  83.          }
  84.                  status = PcdAnticoll(g_ucTempbuf);//防冲撞
  85.          if (status != MI_OK)
  86.          {    continue;    }
  87.                 status = PcdSelect(g_ucTempbuf);//选定卡片
  88.          if (status != MI_OK)
  89.          {    continue;    }
  90.
  91.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//验证卡片密码
  92.          if (status != MI_OK)
  93.          {    continue;    }
  94.          status = PcdValue(PICC_DECREMENT,1,data2);//扣款
  95.          if (status != MI_OK)
  96.          {    continue;    }
  97.
  98.          status = PcdBakValue(1, 2);//块备份
  99.          if (status != MI_OK)
  100.          {    continue;    }
  101.
  102.          status = PcdRead(2, g_ucTempbuf);//读块
  103.          if (status != MI_OK)
  104.          {    continue;    }
  105.                 printf("此卡的读块:");        //超级终端显示,
  106.          for(i=0;i<16;i++)
  107.                                         {
  108.                                                 temp=g_ucTempbuf[i];
  109.                                                 printf("%X",temp);
  110.
  111.                                         }
  112.                  printf("\n");
  113.                 LED_GREEN = 0;
  114.                 delay1(100);
  115.                 LED_GREEN = 1;
  116.                 delay1(100);
  117.                 LED_GREEN = 0;
  118.                 delay1(200);
  119.                 LED_GREEN = 1;
  120.                  PcdHalt();
  121.                 }
  122.     }
  123. }
  124. /////////////////////////////////////////////////////////////////////
  125. //系统初始化
  126. /////////////////////////////////////////////////////////////////////
  127. void InitializeSystem()
  128. {
  129.         P0M1 = 0x0; P0M2 = 0x0;
  130.         P1M1 = 0x0;        P1M2 = 0x0;
  131.         P3M1 = 0x0; P3M2 = 0xFF;
  132.         P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
  133.         TMOD=0x21;                   //设T0为方式1,GATE=1;
  134.         SCON=0x50;
  135.         TH1=0xFD;          //波特率为4800bps
  136.         TL1=0xFD;
  137. //        TH1=0XE0;                //9600
  138. ……………………
  139. …………限于本文篇幅 余下代码请从51黑下载附件…………
测试通过程序.zip (95.54 KB, 下载次数: 170)
ID:292700 发表于 2018-3-16 12:16 | 显示全部楼层
正好需要
ID:56932 发表于 2018-6-2 23:18 | 显示全部楼层
正好需要,感谢楼主
ID:356526 发表于 2018-11-19 17:44 来自触屏版 | 显示全部楼层
太棒了,希望我能成功
ID:254411 发表于 2019-12-12 23:33 来自触屏版 | 显示全部楼层
感谢楼主分享,楼主好人,我终于找到了。
ID:908573 发表于 2021-4-22 21:11 | 显示全部楼层
想知道 usb转ttl rc522 51引脚的接线方法
ID:228360 发表于 2024-10-1 09:06 | 显示全部楼层
正好需要,感谢楼主
ID:1144822 发表于 2025-3-4 21:23 | 显示全部楼层
看起来不错啊
ID:1144822 发表于 2025-3-4 21:24 | 显示全部楼层
希望对自己有所启发吧
