查看: 3512|回复: 1
单片机秒表的程序和仿真分享给大家共同学习
秒表的程序和编程思路,分享给大家共同学习
  1. #include<reg52.h>
  2. typedef unsigned char u8;
  3. typedef unsigned int  u16;
  4. /********端口定义*********/
  5. #define DATA P0
  6. sbit seg_sel = P1^4;
  7. sbit bit_sel = P1^5;
  8. sbit start = P3^2;
  9. sbit store = P3^3;
  10. sbit diskey = P3^4;
  11. sbit reset = P3^5;
  12. sbit led = P1^0;
  13. /********变量定义*********/
  14. u16 tem_ms;
  15. u8        n_ten_ms,n_sec,n_min;
  16. u8        run_flag;//当run_flag为1,代表开始计数
  17. u8  temp_buf[5][3];
  18. u8  arr_pt;
  19. u8 code seg_tab[]={
  20.                           0xc0,0xf9,0xa4,0xb0,
  21.                           0x99,0x92,0x82,0xf8,
  22.                           0x80,0x90,0x88,0x83,
  23.                           0xc6,0xa1,0x86,0x8e
  24.                          };
  25. u8 code bit_tab[]={
  26.                           0x10,0x20,0x40,0x80,
  27.                           0x01,0x02,0x04,0x08
  28.                          };
  29. void delay(unsigned int y)
  30. {
  31.         unsigned int x,z;
  32.         for(x=y; x>0; x--)
  33.                 for(z=110; z>0; z--);
  34. }
  35. void display_led(u8 which_bit, u8 which_number)
  36. {
  37.         bit_sel = 1;//Q[7..0]=D[7..0]
  38.         DATA = bit_tab[which_bit];
  39.         bit_sel = 0;//BIT[7..0]=0x80
  40.         seg_sel = 1;//Q[7..0]=D[7..0]
  41.         DATA = seg_tab[which_number];
  42.         seg_sel = 0;
  43. }
  44. void display(u8 which_bit, u8 which_number)
  45. {
  46.         u8 x,y;
  47.         x = which_number/10;//分离十位
  48.         y = which_number%10;//分离个位
  49.         if (which_bit == 1)
  50.         {
  51.                 display_led(1, x);
  52.                 delay(2);
  53.                 display_led(0, y);
  54.                 delay(2);
  55.         }
  56.         if (which_bit == 2)
  57.         {
  58.                 display_led(4, x);
  59.                 delay(2);
  60.                 display_led(3, y);
  61.                 delay(2);
  62.         }
  63.         if (which_bit == 3)
  64.         {
  65.                 display_led(7, x);
  66.                 delay(2);
  67.                 display_led(6, y);
  68.                 delay(2);
  69.         }
  70. }
  71. void reflash (void)
  72. {
  73.         display(1, n_ten_ms);
  74.         display(2, n_sec);
  75.         display(3, n_min);
  76. }
  77. void main (void)
  78. {
  79.         TMOD = 0x01;//设置定时/计数器T0
  80.         TH0 = (65535-10000) / 256;
  81.         TL0 = (65535-10000) % 256;
  82.         EA = 1;//开放总中断
  83.         ET0 = 1;//开放定时器0的溢出中断
  84.         //TR0 = 1;
  85.         while (1)
  86.         {
  87.
  88. ……………………
  89. …………限于本文篇幅 余下代码请从51黑下载附件…………
Keil.rar (19.68 KB, 下载次数: 18)
Proteus.rar (31.51 KB, 下载次数: 15)
ID:768379 发表于 2020-6-11 21:53 | 只看该作者
根本运行不出来
