查看: 4660|回复: 0
Visual studio c#简易计算器例程
如题。计算器的运行界面如下:
Calculators.rar (63.24 KB, 下载次数: 29)
Visual studio c#计算器源程序如下:
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9. using System.Text.RegularExpressions;
  10. using System.Collections;
  11. namespace Calculators
  12. {
  13.     public partial class Form1 : Form
  14.     {
  15.         public Form1()
  16.         {
  17.             InitializeComponent();
  18.         }
  19.         private void ShowAsStandard()//“标准型”模式
  20.         {
  21.             groupT.Location = new Point(6, 78);//groupT中存放标准型模式下的按钮控件
  22.             txtEnterBox.Size = new Size(250, 23);
  23.             txtExpression.Size = new Size(250, 14);
  24.             groupShowWindow.Size = new Size(260, 49);
  25.             groupS.Location = new Point(-333, 77);//groupT中存放科学型模式下特有的按钮控件
  26.             this.Size = new Size(290, 349);
  27.         }
  28.         private void ShowAsScience()//“科学型”模式
  29.         {
  30.             groupT.Location = new Point(268, 78);
  31.             txtEnterBox.Size = new Size(511, 23);
  32.             txtExpression.Size = new Size(511, 14);
  33.             groupShowWindow.Size = new Size(517, 49);
  34.             groupS.Location = new Point(3, 77);
  35.             this.Size = new Size(551, 349);
  36.         }
  37.         private void Form1_Load(object sender, EventArgs e)
  38.         {
  39.             //界面初始化为“标准型”的样子
  40.             ShowAsStandard();
  41.         }
  42.         //================标志================================================
  43.         private Expression leftValue = null;//左操作数
  44.         bool txtEnterBoxClearFlag = true;//是否清除txtEnterBox的标志,是否可启用backspace的标志
  45.         bool txtExpressionClearFlag = true;//是否清除txtExpression的标志
  46.         bool txtExpressionInsertFlag = true;//是否在txtExpression中插入新数据的标志
  47.         bool btnBackSpaceEnableFlag = true;//是否启用BackSpace键
  48.         //====================================================================
  49.         string op;//操作符
  50.         Expression expression = null;//表达式对象
  51.         private void btn0_Click(object sender, EventArgs e)//数字及点号按钮被按下时触发该事件
  52.         {
  53.             Button btn = sender as Button;
  54.             if (txtEnterBoxClearFlag)
  55.             {
  56.                 txtEnterBox.Clear();
  57.             }
  58.             if (txtExpressionClearFlag)
  59.             {
  60.                 txtExpression.Clear();
  61.             }
  62.             txtEnterBox.Text += btn.Text;
  63.             txtEnterBoxClearFlag = false;
  64.             txtExpressionClearFlag = false;
  65.             btnBackSpaceEnableFlag = true;
  66.         }
  67.         private void buttonClear_Click(object sender, EventArgs e)
  68.         {
  69.             #region 清除数字显示框、表达式显示框及左操作数
  70.             txtEnterBox.Text = "0";
  71.             txtExpression.Text = "";
  72.             leftValue = null;//左操作数清空
  73.             #endregion
  74.         }
  75.         private void txtEnterBox_TextChanged(object sender, EventArgs e)
  76.         {
  77.             #region 检查输入数字是否规范
  78.             if (Regex.IsMatch(txtEnterBox.Text, "^[0]+[1-9]+")) //1.非小数数字不能以0开头。
  79.             {
  80.                 txtEnterBox.Text = Regex.Replace(txtEnterBox.Text, "^0+", "");
  81.             }
  82.             if (Regex.IsMatch(txtEnterBox.Text, "^0+"))//2.数字开头不能连续输入多个0,最多只能输入一个
  83.             {
  84.                 txtEnterBox.Text = Regex.Replace(txtEnterBox.Text, "^0+", "0");
  85.             }
  86.             if (Regex.IsMatch(txtEnterBox.Text, "[.].*[.]"))//3.数字中小数点个数不能超过1
  87.             {
  88.                 txtEnterBox.Text = Regex.Replace(txtEnterBox.Text, "[.]{1}$", "");
  89.             }
  90.             #endregion
  91.         }
  92.         private void btnNegative_Click(object sender, EventArgs e)
  93.         {
  94.             #region 将输入框中的数字乘以-1
  95.             double dTemp = Convert.ToDouble(txtEnterBox.Text);
  96.             dTemp = dTemp * (-1);
  97.             txtEnterBox.Text = dTemp.ToString();
  98.             #endregion
  99.
  100.         }
  101.         private void btnAdd_Click(object sender, EventArgs e)//双目运算符:加减乘除、取余按钮按下时触发该事件
  102.         {
  103.             Button btn = sender as Button;
  104.             if (txtExpressionInsertFlag)
  105.             {
  106.                 txtExpression.Text += txtEnterBox.Text + btn.Text;//表达式显示控件添加数值输入控件中的值和操作符的值
  107.             }
  108.             else
  109.             {
  110.                 txtExpression.Text +=  btn.Text;//表达式显示控件仅添加操作符的值
  111.             }
  112.             if (leftValue == null)
  113.             {
  114.                 leftValue = new Constant(Convert.ToDouble(txtEnterBox.Text));//创建左操作数
  115.             }
  116.             else
  117.             {
  118.                 Constant RightVaue = new Constant(Convert.ToDouble(txtEnterBox.Text));//创建右操作数
  119.                 expression = new Operation(leftValue, op, RightVaue);//创建表达式
  120.                 leftValue = expression;//将表达式赋值给左操作数
  121.                 txtEnterBox.Text = expression.Evaluate().ToString();//数值输入控件显示当前计算值
  122.             }
  123.             op = btn.Text;//更新操作符
  124.             txtEnterBoxClearFlag = true;
  125.             txtExpressionClearFlag = false;
  126.             txtExpressionInsertFlag = true;
  127.             btnBackSpaceEnableFlag = false;
  128.         }
  129.         private void btnEvaluate_Click(object sender, EventArgs e)//按下等于号按钮
  130.         {
  131.
  132.             if (leftValue != null)
  133.             {
  134.                 Constant RightVaue = new Constant(Convert.ToDouble(txtEnterBox.Text));//创建右操作数
  135.                 expression = new Operation(leftValue, op, RightVaue);//创建表达式
  136.                 leftValue = null;//清空左操作数
  137.                 txtEnterBox.Text = expression.Evaluate().ToString();
  138.
  139.             }
  140.             else
  141.             {
  142.                 leftValue = new Constant(Convert.ToDouble(txtEnterBox.Text));//创建左操作数
  143.             }
  144.             txtExpression.Clear();
  145.             txtEnterBoxClearFlag = true;
  146.             btnBackSpaceEnableFlag = false;
  147.         }
  148.         private void btnSqrt_Click(object sender, EventArgs e)//单目运算符:计算平方根,求倒数按钮按下时触发该事件
  149.         {
  150.             Button btn = sender as Button;
  151.             txtExpression.Text +=(string)btn.Tag+ "(" + txtEnterBox.Text + ")";//表达式显示控件显示当前表达式
  152.             leftValue = new Constant(Convert.ToDouble(txtEnterBox.Text));//创建左操作数
  153.             expression = new Operation(leftValue, btn.Text, null);//创建表达式
  154.             leftValue = null;
  155.             txtEnterBox.Text = expression.Evaluate().ToString();
  156.             txtEnterBoxClearFlag = true;
  157.             txtExpressionClearFlag = true;
  158.             txtExpressionInsertFlag = false;
  159.             btnBackSpaceEnableFlag = false;
  160.
  161.         }
  162.         private void btnBackSpace_Click(object sender, EventArgs e)
  163.         {
  164.             if (btnBackSpaceEnableFlag)
  165.             {
  166.                 int strLength = txtEnterBox.Text.Length;
  167.                 if (strLength==1)
  168.                 {
  169.                     txtEnterBox.Text = "0";//只剩一个字符时,将该字符修改为0
  170. ……………………
  171. …………限于本文篇幅 余下代码请从51黑下载附件…………
