查看: 2606|回复: 0
一个协议转换器的程序,大家 看看给提一下意见
ID:237942 发表于 2017-10-17 17:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
typedef unsigned char u8;
typedef unsigned int u16;
u8 code str11[]={0x7E,0x41,0x06,0x0D};     //测试帧,定义点歌系统协议
u8 code str12[]={0x7E,0x41,0x19,0x0D};
u8 code str13[]={0x7E,0x41,0x09,0x0D};
u8 code str14[]={0x7E,0x41,0x03,0x0D};
u8 code str1[]={0x23,0x01,0x04,0x00,0x00,0x00,0x01,0x23};  //测试帧,定义灯光系统协议
u8 code str2[]={0x23,0x01,0x04,0x00,0x00,0x00,0x02,0x23};
u8 code str3[]={0x23,0x01,0x04,0x00,0x00,0x00,0x03,0x23};
u8 code str4[]={0x23,0x01,0x04,0x00,0x00,0x00,0x04,0x23};
void  Uart_init()
  SCON=0X50;   //设置为工作方式1,打开接收允许位
  TMOD=0X20;   //设置定时器为工作方式2
  PCON=0X80;   //波特率加倍( PCON &= 0xef;波特率不倍增)
  TH1=0XF4;           //定时器初始值设置,波特率4800
  TL1=0XF4;
  ES=1;                   //打开接收中断
  EA=1;                   //打开总中断
  TR1=1;          //打开定时器1
void com_send()            //串口发送函数
  u8 receive_buffer;
  u16 m;
if(receive_buffer[2]=0x06)
  for(m=0;str1[m]!='\0';m++)
   SBUF=str1;
else if(receive_buffer[2]=0x19)
  for(m=0;str2[m]!='\0';m++)
  SBUF=str2;
else if(receive_buffer[2]=0x09)
for(m=0;str3[m]!='\0';m++)
  SBUF=str3;
else (receive_buffer[2]=0x03)
  for(m=0;str4[m]!='\0';m++)
  SBUF=str4;
  while(!TI);    //T1==0
  TI=0;
void com_receive()  //串口接收
u8  receive_buffer[];
if(SBUF='\0')
receive_buffer[]=SBUF;
while(!RI);
RI=0;
void  main()
  Uart_init();
  com_receive();
  com_send();
收藏收藏1 分享淘帖 顶 踩
