查看: 2605|回复: 2
程序改错
ID:213443 发表于 2017-10-26 16:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<at89c51.h>
uchar key,key_num,sbuf_out,led_sta;
uchar countm,buf[2];
sbit keep=P3^7;
void delay(uchar x)
        uchar y,z;
        for(y=x;y>0;y--)
                for(z=100;z>0;z--);
uchar keyscan()
        uchar code_h;
        uchar code_l;
        P1=0XF0;
        if((P1&0xF0)!=0XF0)
                delay(5);
                if((P1&0xF0)!=0XF0)
                code_h=0xfe;
                while((code_h&0x10)!=0x00)
                        P1=code_h;
                        if((P1&0xF0)!=0XF0)
                                code_l=(P1&0xF0|0x0F);
                                return((~code_h)+(~code_l));
                                        code_h=(code_h<<1)|0x01;
        return(0);
void keynum()
   uchar i,j;
   uchar code tab[4][4]={{1,2,3,4},{5,6,7,8},{9,10,11,12},{13,14,15,16}};
   key=0;
          key=keyscan();
          if((key&0x01)!=0) i=0;
          if((key&0x02)!=0) i=1;
          if((key&0x04)!=0) i=2;
          if((key&0x08)!=0) i=3;
          if((key&0x10)!=0) j=0;
          if((key&0x20)!=0) j=1;
          if((key&0x40)!=0) j=2;
          if((key&0x80)!=0) j=3;
          if(key!=0) key_num=tab[i][j];
void TAKE_SBUF(uchar dat)
        ES=0;
        SBUF=dat;
        while(~TI);
        TI=0;
        SBUF=dat;
        while(~TI);
        TI=0;
        ES=1;
void keyplay()
        bit take_key;
        keynum();
        if(key_num==13)
                take_key=1;
                sbuf_out=0x00;
                led_sta=0xff;
                P2=0xff;
                P0=0xbf;
        if(key_num==14)
                take_key=1;
                sbuf_out=0x00;
                led_sta=0x00;
                P2=0xff;
                P0=0xbf;
        while(take_key)
                keynum();
                while(key!=0)
                keynum();
                if(key_num<9)
                        sbuf_out=sbuf_out|(0x80>>(key_num-1));
                        key_num=17;
                        P2=~sbuf_out;
                if(key_num==15)
                        TAKE_SBUF(sbuf_out);
                        key_num=17;
                        take_key=0;
                        delay(250);
                        TAKE_SBUF(led_sta);
        SCON=0XD0;
        TMOD=0X20;
        TH1=0XFD;
        TL1=0XFD;
        TR1=1;
        EA=1;
        ES=1;
        P2=0xff;
                keyplay();
void setled() interrupt 4
        buf[countm]=SBUF;
        countm++;
        if(countm>1)
                countm=0;
                if(buf[0]==sbuf_out)
                        if(buf[1]==led_sta)
                                if(buf[1]==0xff)
                                        P0=0xf9;
                                if(buf[1]==0x00)
                                        P0=0xc0;
                                keep=0;
                                delay(250);
                                keep=1;
        RI=0;
ID:243203 发表于 2017-10-26 18:16 | 只看该作者
for循环不需要分号结束
ID:149988 发表于 2017-10-27 06:21 | 只看该作者
RE: 程序改错
头文件写的有问题,应该写为#include<reg51.h>,因为你的头文件是reg51.h
