查看: 2720|回复: 0
寻迹小车程序
ID:244394 发表于 2017-10-30 22:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
上周做的寻迹小车程序,上传保存一下
  1. #include <reg52.h>
  2.
  3. sbit IN1 = P1^0;
  4. sbit IN2 = P1^1;
  5. sbit ENA = P1^2;
  6. sbit IN3 = P1^3;
  7. sbit IN4 = P1^4;
  8. sbit ENB = P1^5;
  9.
  10. sbit left1 = P0^0;
  11. sbit left2 = P0^1;
  12. sbit right1 = P0^2;
  13. sbit right2 = P0^3;
  14.
  15. unsigned char zkb1 = 0;
  16. unsigned char zkb2 = 0;
  17. unsigned char t = 0;
  18.
  19.
  20. void init()
  21. {
  22.     EA = 1;
  23.     TMOD |= 0x01;
  24.     TH0 =(65536 - 100) / 256;
  25.     TL0 = (65536 - 100)% 256;
  26.     ET0 = 1;
  27.     TR0 = 1;
  28. }
  29.
  30. void timer0() interrupt 1
  31. {
  32.
  33.     TH0 = (65536 - 100) / 256;
  34.     TL0 = (65536 - 100) % 256;
  35.
  36.     if(t < zkb1)
  37.     {
  38. //      if(t % 2 == 0)
  39. //      {
  40. //          ENA = 1;
  41. //      }
  42. //      else
  43. //      {
  44. //          ENA = 0;
  45. //      }
  46.         ENA = 1;
  47.     }
  48.     else
  49.     {
  50.         ENA = 0;
  51.     }
  52.     if(t < zkb2)
  53.     {
  54. //      if(t%2 == 0)
  55. //      {
  56. //          ENB = 1;
  57. //      }
  58. //      else
  59. //      {
  60. //          ENB = 0;
  61. //      }
  62.         ENB =1;
  63.     }
  64.     else
  65.     {
  66.         ENB = 0;
  67.     }
  68.     ++t;
  69.     if(t >= 50)
  70.     {
  71.         t = 0;
  72.     }
  73. }
  74.
  75. void turn_left1()
  76. {
  77.     zkb1 = 13;
  78.     zkb2 = 0;
  79. }
  80.
  81. void turn_left2()
  82. {
  83.     zkb1 = 13;
  84.     zkb2 = 0;
  85. }
  86.
  87. void turn_right1()
  88. {
  89.     zkb1 = 0;
  90.     zkb2 = 13;
  91. }
  92.
  93. void turn_right2()
  94. {
  95.     zkb1 = 0;
  96.     zkb2 = 13;
  97. }
  98.
  99. void qianjin()
  100. {
  101.     zkb1 = 8;
  102.     zkb2 = 8;
  103. }
  104. void xunji()
  105. {
  106.     unsigned char flag;
  107.     if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0))
  108.     {
  109.         flag = 0;
  110.     }
  111.
  112.     if((right2 == 0)&&(right1 ==1)&&(left1 == 0)&&(left2 == 0))
  113.     {
  114.         flag = 1;
  115.     }
  116.
  117.     if((right2 == 0)&&(right1 == 0)&&(left1 == 1)&&(left2 == 0))
  118.     {
  119.         flag = 2;
  120.     }
  121.
  122.     if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 1))
  123.     {
  124.         flag = 3;
  125.     }
  126.
  127.     if((right2 == 1)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0))
  128.     {
  129.         flag = 4;
  130.     }
  131.
  132.     switch(flag)
  133.     {
  134.         case 0:
  135.                         qianjin();
  136.                 break;
  137.
  138.         case 1:
  139.                         turn_right1();
  140.                 break;
  141.
  142.         case 2:
  143.                         turn_left1();
  144.                 break;
  145.
  146.         case 3:
  147.                         turn_left2();
  148.                 break;
  149.
  150.         case 4:
  151.                         turn_right2();
  152.                 break;
  153.
  154.         default:
  155.                         qianjin();
  156.                 break;
  157.     }
  158. }
  159.
  160. void main()
  161. {
  162.     init();
  163. //  zkb1 = 40;
  164. //  zkb2 = 30;
  165.     IN1 = 0;
  166.     IN2 = 1;
  167.     IN3 = 0;
  168.     IN4 = 1;
  169.     while(1)
  170.     {
  171.                 xunji();
  172.     }
  173. }
xunji.zip (28.44 KB, 下载次数: 21)
