查看: 2791|回复: 5
在做数字频率计设计,按书上代码,编译的时候找不到头文件
#ifndef INCLUDE_H
#define INCLUDE_H
#include "AT89X51.h"
#include "intrins.h"
#define _BV(x)       (i<<(x))
#define GET_BIT(x,y)   (((x)&(1<<(y)))==0?0:1)
#define SET_BIT(x,y)   ((x)|=(0x0001<<(y)))
#define CLR_BIT(x,y)    ((x)&=~(0x0001<<(y)))
#define LET_BIT(x,y,z)    ((x)=(x)&(~(0x0001<<(y)))|(z)<<(y))
#define F_CPU           11059200UL
#define sei()           (EA=1)
#define cli()           (EA=0)
#endif
#include "target.h"
#include "led.h"
uchar displayBuff[4]={'0','0','0','0'};
const uchar displayMode=0x00;
   uint get_fre;
   target_init();
   init_led();
   sei();
   while()
     get_fre=get_fre_number();
          if(get_fre/1000<0x0A)
            displayBuff[0]=get_fre/1000+'0';
          displayBuff[1]=(get_fre/100)%10+'0';
         displayBuff[2]=(get_fre%100)/10+'0';
          displayBuff[3]=get_fre%10+'0';
         ledSweepDisplay(displayBuff,displayMode,0x04);
#include "Include.h"
#ifndef LED_H
#define LED_H 1
  #ifndef LED_GLOBAL
    #define LED_EXT extern
  #else
    #define LED_EXT
  #endif
  #define LED   P0
  sbit LED_CS1=P2^0;
  sbit LED_CS2=P2^1;
  sbit LED_CS3=P2^2;
  sbit LED_CS4=P2^3;
  enum SEG_DISPLAY_MOD{DIGTAL=0x00,CHARACTER=0x01};
  #ifdef LED_GLOBAL
     uchar segLedCode[10]={0x7e,0x06,0x6d,0x79,0x33,0x5b,0x5f,0x70,0x7f,0x73};
  #endif
  LED_EXT void init_led(void);
  LED_EXT void ledWrite(uchar c,uchar n,uchar mod);
  LED_EXT void ledSweepDisplay(uchar *segCode,uchar segCodeMod,uchar segNumber);
  #endif
#define LED_GLOBAL 1
#include "led.h"
void delay_us(uint us)
   uint i;
   while(us--)
     for(i=0;i<100;i++);
void init_led(void)
   LED=segLedCode[0];
   LED_CS1=0;
   LED_CS2=0;
   LED_CS3=0;
   LED_CS4=0;
   if(CHARACTER==mod)
     LED=c;
   else if(DIGITAL==mod)
              if((c-'0')<0x0a)
                    LED=segLedCode[c-'0'];
                     LED=segLedCode[0];
switch(n)
      case 0x01:
            LED_CS1=0;
                delay_us(10);
                LED_CS1=1;
                break;
          case 0x02:
            LED_CS2=0;
                delay_us(10);
                LED_CS2=1;
                break;
          case 0x03:
            LED_CS3=0;
                delay_us(10);
                LED_CS3=1;
                break;
          case 0x04:
            LED_CS4=0;
                delay_us(10);
                LED_CS4=1;
                break;
          default:
            break;
     uchar segCount;
         for(segCount=0;segCount<segNumber;segCount++)
           if(segCodeMod&0x01)
             ledWrite(segCode[segCount],segCount+1,CHARACTER);
             ledWrite(segCode[segCount],segCount+1,DIGITAL);
           segCodeMod=segCodeMod>>1;
#ifndef TARGET_H
#define TARGET_H 1
#ifndef TARGET_GLOBAL
   #define TARGET_EXT extern
#else
  #define TARGET_EXT
#endif
TARGET_EXT void timer0_init(void);
TARGET_EXT void int0_init(void);
TARGET_EXT void target_init(void);
TARGET_EXT uint get_fre_number(void);
#endif
#define TARGET_GLOBAL 1
#include "target.h"
uint timer0count;
uint pulseCount;
uint pulseCountTemp;
   TMOD|=0x01;
   TH0=0xFC;
   TL0-0x18;
   ET0=1;
   IP=0x02;
   TR0=1;
   EX0=1;
   IT0=1;
  timer0_init();
  int0_init();
  timer0Count=0;
  pulseCount=0;
  pulseCountTemp=0;
void T0_overflow(void) interrupt 1
  TH0=0xFC;
  TL0=0x18;
  cli();
  if(timer0Count<1000)
    timer0Count++;
         pulseCountTemp=pulseCount-pulseCount/(uint)36;
          pulseCount=0;
         timer0Count=0;
  sei();
void int0(void) interrupt 0
   pulseCount++;
  return pulseCountTemp;
ID:245896 发表于 2017-11-5 23:07 | 只看该作者
wulin 发表于 2017-11-5 19:23
这些代码应该是几个C文件和几个H文件混在一起,需要分开写成模块化工程文件。
分开编译成功后数码管又乱码了...
ID:245896 发表于 2017-11-5 23:06 | 只看该作者
lq3698 发表于 2017-11-4 11:27
#include "AT89X51.h"换成#include
换了不行
ID:213173 发表于 2017-11-5 19:23 | 只看该作者
电子小学生 发表于 2017-11-4 09:28
刚学单片机,谢谢!
ID:61135 发表于 2017-11-4 11:27 | 只看该作者
#include "AT89X51.h"换成#include <reg52.h>
ID:245896 发表于 2017-11-4 09:28 | 只看该作者
刚学单片机,谢谢!
