查看: 18334|回复: 9
4×4矩阵键盘的按键在lcd上显示数字仿真及单片机代码
lcd1602显示矩阵键盘的按键值的仿真原理图(proteus工程文件可到本帖附件中下载)
全部资料51hei下载地址:
4×4矩阵键盘的按键在lcd上显示数字.rar (91.96 KB, 下载次数: 289)
单片机代码:
#include <reg51.h>
#include <intrins.h>                        //包含_nop_( )空函数指令的头文件
#define out P0
sbit RS=P2^0;                                         //位变量
sbit RW=P2^1;                                        //位变量
sbit E=P2^2;
void lcd_initial(void);                                                //位变量void lcd _initial(void);                                        //LCD初始化函数
void check_busy(void);                                 //检查忙标志函数
void write_command(uchar com);                         //写命令函数
void write_data(uchar dat);                        //写数据函数
void string(uchar ad ,uchar *s);
void delay(uint);                                //延时函数
unsigned char key_scan()
        unsigned char key_temp0,key_temp1;
        unsigned char key_num=0;
        P1=0x0f;
        key_temp0=P1;
        if(key_temp0!=0x0f)
                delay(5);
                key_temp0=P1;
                if(key_temp0!=0x0f)
                        P1=0xf0;
                        key_temp1=P1;
                        if(key_temp0==0x0e)
                                switch(key_temp1)
                                        case 0xe0: key_num=4;break;
                                        case 0xd0: key_num=3;break;
                                        case 0xb0: key_num=2;break;
                                        case 0x70: key_num=1;break;
                                        default:key_num=0;break;
                        else if(key_temp0==0x0d)
                                switch(key_temp1)
                                        case 0xe0: key_num=8;break;
                                        case 0xd0: key_num=7;break;
                                        case 0xb0: key_num=6;break;
                                        case 0x70: key_num=5;break;
                        else if(key_temp0==0x0b)
                                switch(key_temp1)
                                        case 0xe0: key_num=12;break;
                                        case 0xd0: key_num=11;break;
                                        case 0xb0: key_num=10;break;
                                        case 0x70: key_num=9;break;
                        else if(key_temp0==0x07)
                                switch(key_temp1)
                                        case 0xe0: key_num=16;break;
                                        case 0xd0: key_num=15;break;
                                        case 0xb0: key_num=14;break;
                                        case 0x70: key_num=13;break;
return key_num;
void main(void)                         //主函数
        unsigned char key_num;
        lcd_initial( );                        //调用对LCD初始化函数
   do
                        key_num=key_scan();
                        string(0x82,"Yu Wang wang");                //显示的第1行字符串
                  switch(key_num)
                                case 1 :string(0xC8,"1");  break;
                                case 2 :string(0xC8,"2");  break;
                                case 3 :string(0xC8,"3");  break;
                                case 4 :string(0xC8,"4");  break;
                                case 5 :string(0xC8,"5");  break;
                                case 6 :string(0xC8,"6");  break;
                                case 7 :string(0xC8,"7");  break;
                                case 8 :string(0xC8,"8");  break;
                                case 9 :string(0xC8,"9");  break;
                                case 10:string(0xC8,"10"); break;
                                case 11:string(0xC8,"11"); break;
                                case 12:string(0xC8,"12"); break;
                                case 13:string(0xC8,"13"); break;
                                case 14:string(0xC8,"14"); break;
                                case 15:string(0xC8,"15"); break;
                                case 16:string(0xC8,"16"); break;
                        delay(100);                         //延时
                        write_command(0x01);                //写入清屏命令
                        delay(1);                        //延时
         }while(1);
void delay(uint j)                        //1ms延时子程序
        uchar i=250;
        for(;j>0;j--)
                while(--i);
                i=249;
                while(--i);
                i=250;
void check_busy(void)                        //检查忙标志函数
        uchar dt;
        do
                dt=0xff;
                E=0;
                RS=0;
                RW=1;
E=1;
dt=out;
}while(dt&0x80);
E=0;
void write_command(uchar com)                 //写命令函数
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_( );
E=0;
delay(1);
void write_data(uchar dat)                                 //写数据函数
        check_busy();
        E=0;
        RS=1;
        RW=0;
        out=dat;
        E=1;
        _nop_();
        E=0;
        delay(1);
void LCD_initial(void)                         //液晶显示器初始化函数
write_command(0x38);        //写入命令0x38:8位两行显示,5×7点阵字符
write_command(0x0C);        //写入命令0x0C:开整体显示,光标关,无黑块
write_command(0x06);        //写入命令0x06:光标右移
write_command(0x01);                         //写入命令0x01:清屏
delay(1);
void string(uchar ad,uchar *s)        //输出显示字符串的函数
write_command(ad);
while(*s>0)
write_data(*s++);                        //输出字符串,且指针增1
delay(50);
收藏收藏6 分享淘帖 顶顶1 踩踩
ID:316059 发表于 2018-4-25 11:38 | 只看该作者
把string(0x82,"Yu Wang wang");     这行屏蔽了 效果就明显了
ID:256783 发表于 2018-6-24 20:23 | 只看该作者
根本没有工程文件
ID:414868 发表于 2018-10-29 17:53 | 只看该作者
有没有数码管的
ID:632906 发表于 2019-10-30 20:57 | 只看该作者
代码没错,原理图也没错,为什么就是不显示呢
ID:735660 发表于 2020-4-22 22:51 | 只看该作者
非常好的代码
ID:761855 发表于 2020-5-30 09:43 | 只看该作者
程序下载了,proteus工程文件在那里啊
ID:382952 发表于 2020-6-6 09:48 | 只看该作者
附件在哪
ID:939552 发表于 2021-6-17 19:37 | 只看该作者
大家不能发个汇编语言的?我想要学习汇编语言
ID:989272 发表于 2021-12-8 09:57 | 只看该作者
感谢大佬分析
