查看: 2053|回复: 0
请问这个case 3为什么不能执行?
#include <reg51.h>
#define LED P0
sbit P17=P1^7;
sbit LSA=P2^0;
sbit LSB=P2^1;
sbit LSC=P2^2;
unsigned char code discode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char disp[]={0x3f,0x3f};
unsigned int n=0,second=0,i=0;
void delay(unsigned int i)  //Ñóê±oˉêy
unsigned int j;
for(i;i>0;i--)
  for(j=110;j>0;j--);
void display()  //ÏÔê¾oˉêy
  LED=0;
        switch(i)  //λѡ
                case(0):
                        LSA=0;LSB=0;LSC=0;break;
                case(1):
                        LSA=1;LSB=0;LSC=0;break;
        LED=disp[i];  //¶ÎÑ¡
  i++;
  if(i>1)
                i=0;
        TMOD=0x61;  //3õê¼»ˉ
        IE=0x8B;
  IT0=1;
        TH1=0xE7;
        TL1=0xE7;
        TR1=1;
  display();  //ÎTÏTÑ-»·ÏÔê¾oˉêy
void int0() interrupt 0  //ía2¿ÖD¶Ï0
        n++;
        switch (n)
                case 1:   //n=1,¿aÆô¶¨ê±Æ÷0£¬¼Æê±20ms
                  TH0=0xB1;
                        TL0=0xE0;
                        TR0=1;
                        break;
                case 2:  //n=2,1رն¨ê±Æ÷0
                        TR0=0;
                        break;
                case 3:  //n=3,Çåáã
                        n=0;
      LED=0x3f;
                        break;
void intt0()  interrupt 1 //¶¨ê±Æ÷0ÖD¶Ï
        if(P17==1)  //2úéúÖüÆúÎa40msμÄÂö3å
                P17=0;
                P17=1;
        TH0=0xB1;
        TL0=0xE0;
        TR0=1;
void intt1()  interrupt 3 //¶¨ê±Æ÷1ÖD¶Ï
{  second++;
         if(second==11)
                 second=0;
        disp[0]=discode[second%10]; //½«ÏÔê¾′úÂëËíèëÏÔê¾êy×é
        disp[1]=discode[second/10];
        TH1=0xE7;
        TL1=0xE7;
        TR1=1;
这个是按一次开始计时,再按一次停止,再按一次清零的。但是第三次按并不能清零,显示的数字不变。
