查看: 6694|回复: 1
xc8编译器,pic16f1825 单片机 串口发送程序编译不过.
ID:248855 发表于 2017-11-13 10:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好!请教个问题:
    xc8编译器,pic16f1825 单片机 串口发送程序编译不过.代码如下:
/串口发送一串字符
void EUSART_SendString(const unsigned char  *pData)
    di(); //GIE = 0 //disable all interrupts
    TXIE =0;  //屏闭EUSART 发送中断
    int len = strlen(pData);
    unsigned char  *str= malloc(len);
    if(str !=NULL){
        strcpy(str,pData);
        while(*str!='\0')
            TXREG = *str++;
            while(TXSTAbits.TRMT==0);//TRMT=1时,TSR为空,否则不为空
        free(str);
编译错误 如下:
:: warning: (1273) Omniscient Code Generation not available in Free mode
mcu_wifi.c:108: advisory: (1510) non-reentrant function "_EUSART_SendString" appears in multiple call graphs and has been duplicated by the compiler
C:\Program Files\Microchip\xc8\v1.42\sources\common\strcpy.c:8: advisory: (1510) non-reentrant function "_strcpy" appears in multiple call graphs and has been duplicated by the compiler
C:\Program Files\Microchip\xc8\v1.42\sources\common\strlen.c:4: advisory: (1510) non-reentrant function "_strlen" appears in multiple call graphs and has been duplicated by the compiler
uart_comm.c:9: warning: (520) function "_calc_checksum" is never called
:0: error: (500) undefined symbols:
        _free(dist/default/production\mcu_wifi.X.production.obj) _malloc(dist/default/production\mcu_wifi.X.production.obj)
(908) exit status = 1
nbproject/Makefile-default.mk:147: recipe for target 'dist/default/production/mcu_wifi.X.production.hex' failed
make[2]: Leaving directory 'D:/VM/share/AbleCloud/mcu_firmware/mcu_wifi/mcu_wifi.X'
nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
make[1]: Leaving directory 'D:/VM/share/AbleCloud/mcu_firmware/mcu_wifi/mcu_wifi.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** [dist/default/production/mcu_wifi.X.production.hex] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
编译已失败 (退出值2, 总时间: 2s)
各位大牛,请帮我看下是什么问题!!
ID:869731 发表于 2020-12-31 15:49 | 只看该作者
你的free 没有包含头文件 free 的头文件是 #include<stdlib.h>
