查看: 1725|回复: 0
警报装置,温度在1602上显s示
ID:236125 发表于 2017-11-13 21:31 | 显示全部楼层 |阅读模式
#include <reg51.h>
sbit rw = P3^6;
sbit RS = P3^5;
sbit ds = P2^2;
sbit LCDEN = P3^4;
beep=P2^3;
uchar code table[] = " test temp:";
int value;
void delayMs(uint a)  //延时
    uint i, j;
    for(i = a; i > 0; i--)
        for(j = 100; j > 0; j--);
void writeComm(uchar comm)
    RS = 0;
    P0 = comm;
        delayMs(5);
    LCDEN = 1;
    delayMs(5);
    LCDEN = 0;
void writeData(uchar dat)
     RS = 1;
     P0 = dat;
         delayMs(1);
     LCDEN = 1;
     delayMs(1);
     LCDEN = 0;
void init()
     rw = 0;
     writeComm(0x38);
     writeComm(0x0c);
     writeComm(0x06);
     writeComm(0x01);
void writeString(uchar * str, uchar length)
     uchar i;
     for(i = 0; i < length; i++)
         writeData(str[i]);
/**//*****************************DS18B20*******************************/
void dsInit()
     unsigned int i;
     ds = 0;
     i = 100;
     while(i>0)
         i--;
     ds = 1;
     i = 4;
     while(i>0)
         i--;
bit readBit()
    unsigned int i;
    bit b;
    ds = 0;
    i++;
    ds = 1;
    i++;
        i++;
    b = ds;
    i = 8;
    while(i>0)
        i--;
    return b;
unsigned char readByte()
     unsigned int i;
     unsigned char j, dat;
     dat = 0;
     for(i=0; i<8; i++)
        j = readBit();
        dat = (j << 7) | (dat >> 1);
    return dat;
void writeByte(unsigned char dat)
    int i,j;
        for(j=0;j<8;j++)
           ds=0;
           i++;
           ds=dat&0x01;
           i=6;
           while(i--);
           ds=1;
           dat>>=1;
void sendChangeCmd()//温度转化命令
    dsInit();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0x44);
void sendReadCmd() //读取温度
    dsInit();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0xbe);
int getTmpValue()
    unsigned int tmpvalue;
    float t;
    unsigned char low, high;
    sendReadCmd();
    low = readByte();
    high = readByte();
    tmpvalue = high;
    tmpvalue <<= 8;
    tmpvalue |= low;
    value = tmpvalue;
    t = value * 0.0625;
    value = t * 100 + (value > 0 ? 0.5 : -0.5); //大于0加0.5, 小于0减0.5
    return value;
void display()
    unsigned char count;
    unsigned char datas[] = {0, 0, 0, 0, 0};
    unsigned int tmp =getTmpValue();
    datas[0] = tmp / 10000;
    datas[1] = tmp % 10000 / 1000;
    datas[2] = tmp % 1000 / 100;
    datas[3] = tmp % 100 / 10;
    datas[4] = tmp % 10;
    writeComm(0xc0+3);
    if(tmp< 0)
        writeString("- ", 1);
       writeString("+ ", 1);
    for(count = 1; count < 5; count++)
        writeData('0'+datas[count]);
        if(count == 2)
            writeData('.');
    init();
    writeComm(0x80);
    writeString(table,11);
            sendChangeCmd();//发送温度转化命令
        delayMs(750); //温度转换时间需要750ms以上
        writeComm(0xc0);
        display();
       if(value>2000)
       beep=0;
        P1=0x00;
         beep=1;
           P1=0xff;
