查看: 1736|回复: 0
分享关于单片机的I2C总线代码
ID:253022 发表于 2017-11-24 13:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit sda=P2^0;
sbit scl=P2^1;
uchar a;
void delay()
void start()  //开始信号
    sda=1;
    delay();
    scl=1;
    delay();
    sda=0;
    delay();
void stop()   //停止
    sda=0;
    delay();
    scl=1;
    delay();
    sda=1;
    delay();
void respons()  //应答
    uchar i;
    scl=1;
    delay();
    while((sda==1)&&(i<250))i++;
    scl=0;
    delay();
void init()
    sda=1;
    delay();
    scl=1;
    delay();
void write_byte(uchar date)
    uchar i,temp;
    temp=date;
    for(i=0;i<8;i++)
        temp=temp<<1;
        scl=0;
        delay();
        sda=CY;
        delay();
        scl=1;
        delay();
    //    scl=0;
     //   delay();
    scl=0;
    delay();
    sda=1;
    delay();
uchar read_byte()
    uchar i,k;
    scl=0;
    delay();
    sda=1;
    delay();
    for(i=0;i<8;i++)
        scl=1;
        delay();
        k=(k<<1)|sda;
        scl=0;
        delay();
    return k;
void delay1(uchar x)
    uchar a,b;
    for(a=x;a>0;a--)
     for(b=100;b>0;b--);
void write_add(uchar address,uchar date)
    start();
    write_byte(0xa0);
    respons();
    write_byte(address);
    respons();
    write_byte(date);
    respons();
    stop();
uchar read_add(uchar address)
    uchar date;
    start();
    write_byte(0xa0);
    respons();
    respons();
    start();
    write_byte(0xa1);
    respons();
    date=read_byte();
    stop();
    return date;
    init();
    write_add(23,0xaa);
    delay1(100);
    P1=read_add(23);
    while(1);
