查看: 2285|回复: 1
串口读加速度数据陀螺仪数据
ID:239419 发表于 2017-11-24 14:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
// GY-521 MPU6050 IIC2aêÔ3ìDò
// ê1óÃμ¥Ƭ»úSTM32F103C8T6
// ¾§Õñ£o8.00M
// ±àòë»·¾3 Keil uVision4
// ê±¼ä£o2012Äê5ÔÂ1èÕ
// óëÄ£¿éᬽó GPIOB6->SCL GPIOB7->SDA
// ê1óãoSTM32F103C8T6′®¿ú1ᬽóμçÄÔ
// μçÄÔ′®¿úÖúêÖÏÔê¾£¬2¨ìØÂê£o115200
// QQ£o531389319
#include "stm32f10x_lib.h"
#include  <math.h>    //Keil library
GPIO_InitTypeDef GPIO_InitStructure;
ErrorStatus HSEStartUpStatus;
#define   uchar unsigned char
#define   uint unsigned int
// ¶¨òåMPU6050Äú2¿μØÖ·
#define        SMPLRT_DIV                0x19        //íóÂYòÇ2éÑùÂ꣬μäDíÖμ£o0x07(125Hz)
#define        CONFIG                        0x1A        //μíí¨ÂË2¨ÆμÂ꣬μäDíÖμ£o0x06(5Hz)
#define        GYRO_CONFIG                0x1B        //íóÂYòÇ×Լ켰2aá¿·¶Î§£¬μäDíÖμ£o0x18(2»×Լ죬2000deg/s)
#define        ACCEL_CONFIG        0x1C        //¼óËù¼Æ×Լ졢2aá¿·¶Î§¼°¸ßí¨ÂË2¨ÆμÂ꣬μäDíÖμ£o0x01(2»×Լ죬2G£¬5Hz)
#define        ACCEL_XOUT_H        0x3B
#define        ACCEL_XOUT_L        0x3C
#define        ACCEL_YOUT_H        0x3D
#define        ACCEL_YOUT_L        0x3E
#define        ACCEL_ZOUT_H        0x3F
#define        ACCEL_ZOUT_L        0x40
#define        TEMP_OUT_H                0x41
#define        TEMP_OUT_L                0x42
#define        GYRO_XOUT_H                0x43
#define        GYRO_XOUT_L                0x44
#define        GYRO_YOUT_H                0x45
#define        GYRO_YOUT_L                0x46
#define        GYRO_ZOUT_H                0x47
#define        GYRO_ZOUT_L                0x48
#define        PWR_MGMT_1                0x6B        //μçÔ′1üàí£¬μäDíÖμ£o0x00(Õy3£ÆôóÃ)
#define        WHO_AM_I                0x75        //IICμØÖ·¼Ä′æÆ÷(ĬèÏêyÖμ0x68£¬Ö»¶á)
#define        MPU6050_Addr   0xD0          //¶¨òåÆ÷¼tÔúIIC×üÏßÖDμÄ′óμØÖ·,¸ù¾YALT  ADDRESSμØÖ·òy½Å2»í¬DT¸Ä
unsigned char TX_DATA[4];           //ÏÔê¾¾Y»o′æÇø
unsigned char TX_DATA1[6];           //ÏÔê¾¾Y»o′æÇø
unsigned char BUF[12];       //½óêÕêy¾Y»o′æÇø
char  test=0;                                  //IICóÃμ½
short T_X,T_Y,T_Z,T_T;                 //X,Y,ZÖᣬζè
short ax,ay,az;
/*Ä£ÄaIIC¶Ë¿úêä3öêäè붨òå*/
#define SCL_H         GPIOB->BSRR = GPIO_Pin_6
#define SCL_L         GPIOB->BRR  = GPIO_Pin_6
#define SDA_H         GPIOB->BSRR = GPIO_Pin_7
#define SDA_L         GPIOB->BRR  = GPIO_Pin_7
#define SCL_read      GPIOB->IDR  & GPIO_Pin_6
#define SDA_read      GPIOB->IDR  & GPIO_Pin_7
/* oˉêyéêÃ÷ -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void USART1_Configuration(void);
void WWDG_Configuration(void);
void Delay(u32 nTime);
void Delayms(vu32 m);
/* ±äá¿¶¨òå ----------------------------------------------*/
* Function Name  : I2C_GPIO_Config
* Description    : Configration Simulation IIC GPIO
* Input          : None
* Output         : None
* Return         : None
void I2C_GPIO_Config(void)
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7;
* Function Name  : I2C_delay
* Description    : Simulation IIC Timing series delay
* Input          : None
* Output         : None
* Return         : None
void I2C_delay(void)
   u8 i=30; //Õaàï¿éòÔóÅ»ˉËù¶è        £¬¾-2aêÔ×îμíμ½5»1ÄüD′èë
   while(i)
     i--;
void delay5ms(void)
   int i=5000;
   while(i)
     i--;
* Function Name  : I2C_Start
* Description    : Master Start Simulation IIC Communication
* Input          : None
* Output         : None
* Return         : Wheather         Start
bool I2C_Start(void)
        SDA_H;
        SCL_H;
        I2C_delay();
        if(!SDA_read)return FALSE;        //SDAÏßÎaμíμçÆ½Ôò×üÏßÃ|,íË3ö
        SDA_L;
        I2C_delay();
        if(SDA_read) return FALSE;        //SDAÏßÎa¸ßμçÆ½Ôò×üÏß3ö′í,íË3ö
        SDA_L;
        I2C_delay();
        return TRUE;
* Function Name  : I2C_Stop
* Description    : Master Stop Simulation IIC Communication
* Input          : None
* Output         : None
* Return         : None
void I2C_Stop(void)
        SCL_L;
        I2C_delay();
        SDA_L;
        I2C_delay();
        SCL_H;
        I2C_delay();
        SDA_H;
        I2C_delay();
* Function Name  : I2C_Ack
* Description    : Master Send Acknowledge Single
* Input          : None
* Output         : None
* Return         : None
void I2C_Ack(void)
        SCL_L;
        I2C_delay();
        SDA_L;
        I2C_delay();
        SCL_H;
        I2C_delay();
        SCL_L;
        I2C_delay();
* Function Name  : I2C_NoAck
* Description    : Master Send No Acknowledge Single
* Input          : None
* Output         : None
* Return         : None
void I2C_NoAck(void)
        SCL_L;
        I2C_delay();
        SDA_H;
        I2C_delay();
        SCL_H;
        I2C_delay();
        SCL_L;
        I2C_delay();
* Function Name  : I2C_WaitAck
* Description    : Master Reserive Slave Acknowledge Single
* Input          : None
* Output         : None
* Return         : Wheather         Reserive Slave Acknowledge Single
bool I2C_WaitAck(void)          //·μ»ØÎa:=1óDACK,=0ÎTACK
        SCL_L;
        I2C_delay();
        SDA_H;
        I2C_delay();
        SCL_H;
        I2C_delay();
        if(SDA_read)
      SCL_L;
          I2C_delay();
      return FALSE;
        SCL_L;
        I2C_delay();
        return TRUE;
* Function Name  : I2C_SendByte
* Description    : Master Send a Byte to Slave
* Input          : Will Send Date
* Output         : None
* Return         : None
void I2C_SendByte(u8 SendByte) //êy¾Y′ó¸ßλμ½μíλ//
    u8 i=8;
    while(i--)
        SCL_L;
        I2C_delay();
      if(SendByte&0x80)
        SDA_H;
        SDA_L;
        SendByte<<=1;
        I2C_delay();
                SCL_H;
        I2C_delay();
    SCL_L;
* Function Name  : I2C_RadeByte
* Description    : Master Reserive a Byte From Slave
* Input          : None
* Output         : None
* Return         : Date From Slave
unsigned char I2C_RadeByte(void)  //êy¾Y′ó¸ßλμ½μíλ//
    u8 i=8;
    u8 ReceiveByte=0;
    SDA_H;
    while(i--)
      ReceiveByte<<=1;
      SCL_L;
      I2C_delay();
          SCL_H;
      I2C_delay();
      if(SDA_read)
        ReceiveByte|=0x01;
    SCL_L;
    return ReceiveByte;
//ZRX
//μ¥×Ö½úD′èë*******************************************
bool Single_Write(unsigned char SlaveAddress,unsigned char REG_Address,unsigned char REG_data)                     //void
          if(!I2C_Start())return FALSE;
    I2C_SendByte(SlaveAddress);   //·¢Ëíé豸μØÖ·+D′DÅoÅ//I2C_SendByte(((REG_Address & 0x0700) >>7) | SlaveAddress & 0xFFFE);//éèÖÃ¸ßÆeê¼μØÖ·+Æ÷¼tμØÖ·
    if(!I2C_WaitAck()){I2C_Stop(); return FALSE;}
    I2C_SendByte(REG_Address );   //éèÖÃμíÆeê¼μØÖ·
    I2C_WaitAck();
    I2C_SendByte(REG_data);
    I2C_WaitAck();
    I2C_Stop();
    delay5ms();
    return TRUE;
//μ¥×Ö½ú¶áè¡*****************************************
unsigned char Single_Read(unsigned char SlaveAddress,unsigned char REG_Address)
{   unsigned char REG_data;
    I2C_SendByte(SlaveAddress); //I2C_SendByte(((REG_Address & 0x0700) >>7) | REG_Address & 0xFFFE);//éèÖÃ¸ßÆeê¼μØÖ·+Æ÷¼tμØÖ·
    if(!I2C_WaitAck()){I2C_Stop();test=1; return FALSE;}
    I2C_SendByte((u8) REG_Address);   //éèÖÃμíÆeê¼μØÖ·
    I2C_WaitAck();
    I2C_Start();
    I2C_SendByte(SlaveAddress+1);
    I2C_WaitAck();
        REG_data= I2C_RadeByte();
    I2C_NoAck();
    I2C_Stop();
    //return TRUE;
        return REG_data;
** oˉêyÃû3Æ £o RCC_Configuration(void)
** oˉêy1|Äü £o ê±Öó3õê¼»ˉ
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
   /* Enable GPIOA, GPIOB, GPIOC, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB , ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD , ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOF , ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG | RCC_APB2Periph_AFIO  , ENABLE);
** oˉêyÃû3Æ £o GPIO_Configuration(void)
** oˉêy1|Äü £o ¶Ë¿ú3õê¼»ˉ
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE  );
   /* Configure USART1 Tx (PA.09) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;                                 //        Ñ¡ÖD1ü½Å9
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                 // ¸′óÃíÆíìêä3ö
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 // ×î¸ßêä3öËùÂê50MHz
  GPIO_Init(GPIOA, &GPIO_InitStructure);                                 // Ñ¡ÔñA¶Ë¿ú
  /* Configure USART1 Rx (PA.10) as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;                          //Ñ¡ÖD1ü½Å10
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;          //¸¡¿Õêäèë
  GPIO_Init(GPIOA, &GPIO_InitStructure);                                  //Ñ¡ÔñA¶Ë¿ú
** oˉêyÃû3Æ £o USART1_Configuration(void)
** oˉêy1|Äü £o ′®¿ú13õê¼»ˉ
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef  USART_ClockInitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 |RCC_APB2Periph_USART1, ENABLE  );
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;                        // ê±ÖóμíμçÆ½»î¶ˉ
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;                                // ê±ÖóμíμçÆ½
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;                                // ê±Öóμú¶t¸ö±ßÑØ½øDDêy¾Y2¶»ñ
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;                // ×îoóò»Î»êy¾YμÄê±ÖóÂö3å2»′óSCLKêä3ö
/* Configure the USART1 synchronous paramters */
USART_ClockInit(USART1, &USART_ClockInitStructure);                                        // ê±Öó2Îêy3õê¼»ˉéèÖÃ
USART_InitStructure.USART_BaudRate = 115200;                                                  // 2¨ìØÂêÎa£o115200
USART_InitStructure.USART_WordLength = USART_WordLength_8b;                          // 8λêy¾Y
USART_InitStructure.USART_StopBits = USART_StopBits_1;                                  // ÔúÖ¡½áÎ2′«êä1¸öí£Ö1λ
USART_InitStructure.USART_Parity = USART_Parity_No ;                                  // ÆæÅ¼ê§Äü
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;        // ó2¼tá÷¿ØÖÆê§Äü
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                  // ·¢Ëíê1Äü+½óêÕê1Äü
/* Configure USART1 basic and asynchronous paramters */
USART_Init(USART1, &USART_InitStructure);
  /* Enable USART1 */
USART_ClearFlag(USART1, USART_IT_RXNE);                         //ÇåÖD¶Ï£¬òÔÃaò»ÆôóÃÖD¶Ïoóᢼ′2úéúÖD¶Ï
USART_ITConfig(USART1,USART_IT_RXNE, ENABLE);                //ê1ÄüUSART1ÖD¶ÏÔ′
USART_Cmd(USART1, ENABLE);                                                        //USART1×ü¿a1Ø£o¿aÆô
** oˉêyÃû3Æ £o NVIC_Configuration(void)
** oˉêy1|Äü £o ÖD¶Ï3õê¼»ˉ
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
  NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  NVIC_InitStructure.NVIC_IRQChannel = WWDG_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_Init(&NVIC_InitStructure);
** oˉêyÃû3Æ £o WWDG_Configuration(void)
** oˉêy1|Äü £o ¿′ÃÅ1·3õê¼»ˉ
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);
  WWDG_SetPrescaler(WWDG_Prescaler_8);                      //  WWDG clock counter = (PCLK1/4096)/8 = 244 Hz (~4 ms)
  WWDG_SetWindowValue(0x41);                                 // Set Window value to 0x41
  WWDG_Enable(0x50);                       // Enable WWDG and set counter value to 0x7F, WWDG timeout = ~4 ms * 64 = 262 ms
  WWDG_ClearFlag();                               // Clear EWI flag
  WWDG_EnableIT();                               // Enable EW interrupt
** oˉêyÃû3Æ £o Delay(vu32 nCount)
** oˉêy1|Äü £o Ñóê±oˉêy
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
void Delay(vu32 nCount)
  for(; nCount != 0; nCount--);
** oˉêyÃû3Æ £o void Delayms(vu32 m)
** oˉêy1|Äü £o 3¤Ñóê±oˉêy         m=1,Ñóê±1ms
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
  u32 i;
  for(; m != 0; m--)
       for (i=0; i<50000; i++);
** oˉêyÃû3Æ £o WWDG_IRQHandler(void)
** oˉêy1|Äü £o ′°¿úìáǰ»½DÑÖD¶Ï
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
void WWDG_IRQHandler(void)
  /* Update WWDG counter */
  WWDG_SetCounter(0x50);
  /* Clear EWI flag */
  WWDG_ClearFlag();
//3õê¼»ˉMPU6050£¬¸ù¾YDèòaÇë2ο¼pdf½øDDDT¸Ä************************
void Init_MPU6050(void)
   Single_Write(MPU6050_Addr,PWR_M, 0x80);   //
   Single_Write(MPU6050_Addr,SMPL, 0x07);    //
   Single_Write(MPU6050_Addr,DLPF, 0x1E);    //¡à2000¡ã
   Single_Write(MPU6050_Addr,INT_C, 0x00 );  //
   Single_Write(MPU6050_Addr,PWR_M, 0x00);   //
           Single_Write(MPU6050_Addr,PWR_MGMT_1, 0x00);        //½a3yDYÃß×′ì¬
        Single_Write(MPU6050_Addr,SMPLRT_DIV, 0x07);
        Single_Write(MPU6050_Addr,CONFIG, 0x06);
        Single_Write(MPU6050_Addr,GYRO_CONFIG, 0x18);
        Single_Write(MPU6050_Addr,ACCEL_CONFIG, 0x01);
//******¶áè¡MPU6050êy¾Y****************************************
void READ_MPU6050(void)
   BUF[0]=Single_Read(MPU6050_Addr,GYRO_XOUT_L);
   BUF[1]=Single_Read(MPU6050_Addr,GYRO_XOUT_H);
   T_X=        (BUF[1]<<8)|BUF[0];
   T_X/=16.4;                                                    //¶á衼ÆËãXÖáêy¾Y
   BUF[2]=Single_Read(MPU6050_Addr,GYRO_YOUT_L);
   BUF[3]=Single_Read(MPU6050_Addr,GYRO_YOUT_H);
   T_Y=        (BUF[3]<<8)|BUF[2];
   T_Y/=16.4;                                                    //¶á衼ÆËãYÖáêy¾Y
   BUF[4]=Single_Read(MPU6050_Addr,GYRO_ZOUT_L);
   BUF[5]=Single_Read(MPU6050_Addr,GYRO_ZOUT_H);
   T_Z=        (BUF[5]<<8)|BUF[4];
   T_Z/=16.4;                                                //¶á衼ÆËãZÖáêy¾Y
        BUF[6]=Single_Read(MPU6050_Addr,ACCEL_XOUT_L);
  BUF[7]=Single_Read(MPU6050_Addr,ACCEL_XOUT_H);
        ax=((BUF[7]<<8)|BUF[6]);
        BUF[8]=Single_Read(MPU6050_Addr,ACCEL_YOUT_L);
  BUF[9]=Single_Read(MPU6050_Addr,ACCEL_YOUT_H);
        ay=((BUF[9]<<8)|BUF[8]);
        BUF[10]=Single_Read(MPU6050_Addr,ACCEL_ZOUT_L);
  BUF[11]=Single_Read(MPU6050_Addr,ACCEL_ZOUT_H);
        az=((BUF[11]<<8)|BUF[10]);
  // BUF[6]=Single_Read(MPU6050_Addr,TEMP_OUT_L);
  // BUF[7]=Single_Read(MPU6050_Addr,TEMP_OUT_H);
  // T_T=(BUF[7]<<8)|BUF[6];
  // T_T = 35+ ((double) (T_T + 13200)) / 280;// ¶á衼ÆËã3öζè
** oˉêyÃû3Æ £o main(void)
** oˉêy1|Äü £o Ö÷oˉêy
** êä    èë        £o ÎT
** êä    3ö        £o ÎT
** ·μ    »Ø        £o ÎT
void  USART1_SendData(uchar SendData)
USART_SendData(USART1, SendData);
Delayms(1);
//********′®¿ú·¢Ëíêy¾Y***************************************
void Send_data(uchar axis)
{uchar i;
  USART1_SendData(axis);
  USART1_SendData(':');
  for(i=0;i<4;i++)USART1_SendData(TX_DATA[i]);
  USART1_SendData(' ');
void Send_data1(uchar axis)
{uchar i;
   for(i=0;i<6;i++)USART1_SendData(TX_DATA1[i]);
// DATA_printf(TX_DATA,T_X);//×a»»XÖáêy¾Yμ½êy×é
void DATA_printf(uchar *s,short temp_data)
        if(temp_data<0){
        temp_data=-temp_data;
    *s='-';
        else *s=' ';//μúò»¸ö
    *++s =temp_data/100+0x30;//μú¶t¸ö
    temp_data=temp_data%100;     //è¡óàÔËËã
    *++s =temp_data/10+0x30;//3
    temp_data=temp_data%10;      //è¡óàÔËËã
    *++s =temp_data+0x30;         //4
void DATA_printf1(uchar *s,short temp_data)
        if(temp_data<0){
    *s='-';
        *(s+1)  =temp_data/10000+0x30;//3
    temp_data=temp_data%10000;
*(s+2) =temp_data/1000+0x30;//3
    temp_data=temp_data%1000;
        *(s+3) =temp_data/100+0x30;//3
        *(s+4) =temp_data/10+0x30;//3
*(s+5) =temp_data+0x30;         //4
int main(void)
  RCC_Configuration();                 //ÅäÖÃRCC
  GPIO_Configuration();                 //ÅäÖÃGPIO
  USART1_Configuration();         //ÅäÖÃ′®¿ú1
  I2C_GPIO_Config();                 //ÅäÖÃIICê1óö˿ú
  Delayms(10);                                 //Ñóê±
  Init_MPU6050();                     //3õê¼»ˉMPU6050
        READ_MPU6050();                 //¶áè¡MPU6050êy¾Y
        Send_data('X');                         //·¢ËíXÖáêy
        DATA_printf(TX_DATA,T_Y);//×a»»YÖáêy¾Yμ½êy×é
        Send_data('Y');                         //·¢ËíYÖáêy
        DATA_printf(TX_DATA,T_Z);//×a»»ZÖáêy¾Yμ½êy×é
        Send_data('Z');                         //·¢ËíZÖáêy
         DATA_printf(TX_DATA,T_T);//×a»»Î¶èêy¾Yμ½êy×é
        Send_data('T');                         //·¢Ëíζèêy¾Y
         DATA_printf1(TX_DATA1,ax);//×a»»Î¶èêy¾Yμ½êy×é
        Send_data1('A');
         DATA_printf1(TX_DATA1,ay);//×a»»Î¶èêy¾Yμ½êy×é
        Send_data1('B');
        Send_data1('C');
        USART1_SendData(0X0D);         //»»DD
        USART1_SendData(0X0A);         //»Ø3μ
        Delayms(5);                                 //Ñóê±
/*************½áêø***************/
直接用   已经写好  板子stm32f103c8
