查看: 1615|回复: 0
中断
ID:253243 发表于 2017-11-24 21:55 | 显示全部楼层 |阅读模式
#include<reg51.h>
uchar seg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80};
sbit K1=P3^2;
void delay(uint z);
void delay(uint z){
uint i,j;
for(i=0;i<200;i++)
for(j=0;j<z;j++);
void int0() interrupt 0 using 1{
uchar i;
for(i=1;i<9;i++){
P2=seg[i];
delay(200);
P2=0xff;
void main(){
uchar i;
IE=0x81;
TCON=0x01;
while(1){
for(i=1;i<9;i++){
P0=seg[i];
delay(200);
