查看: 1852|回复: 0
温湿度监控
ID:253260 发表于 2017-11-24 22:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include "intrins.h"
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit rs=P2^6;         // êy¾YÃüáîÑ¡Ôñ
sbit rw=P2^5;         //¶áD′Ñ¡Ôñ
sbit e=P2^7;          //ê1Äü
sbit k1=P3^3; //Ä£ê½
sbit k2=P2^1; //¼ó
sbit k3=P2^2; //¼õ
sbit DHT11_DQ_OUT=P3^2;
sbit led1=P3^6;
sbit led2=P3^7;
sbit dq=P2^0;
uint8 mode=0,xian;
char temph=50,templ=20;
char humih=80,humil=20;
uint8 temp,humi;
uint8 flag;          //é趨±¨¾ˉ±êÖ¾
uint8 a,c,tempvalue;
uint8 code num[10]="0123456789";
uint8 code str1[]="Temp:";  //ζè
uint8 code str2[]="Humi:";  //êa¶è
uint8 code str3[]="Error";
uint8 code str4[]="Success    ";
uint8 code str5[]="%RH";
uint8 code str6[]="TempH:";          //é趨ζèéÏÏTÏÔê¾
uint8 code str7[]="TempL:";          //é趨ζèÏÂÏTÏÔê¾
uint8 code str8[]="HumiH:";           //é趨êa¶èéÏÏTÏÔê¾
uint8 code str9[]="HumiL:";           //é趨êa¶èÏÂÏTÏÔê¾
void delay(uint16 i)
        while(i--);
void delay_ms(uint16 i)
        while(i--)
                delay(90);
void wrc(uint8 c)         //D′Ãüáî
        delay(1000);
        rs=0;
        rw=0;
        e=0;
        P0=c;
        e=1;
        delay(10);
        e=0;
void wrd(uint8 dat)          //D′êy¾Y
        delay(1000);
        rs=1;
        rw=0;
        e=0;
        P0=dat;
        e=1;
        delay(10);
        e=0;
        rs=0;
void lcd_init()           // LCD16023õê¼»ˉ
        delay(1000);
        wrc(0x38);
        wrc(0x38);         //1|ÄüéèÖÃÃüáѡÔñ8λ×üÏߣ¬Ë«DDÏÔê¾  5*7μãÕó×Ö·û
        wrc(0x38);
        wrc(0x06);        //1a±êoíÏÔê¾Ä£ê½éèÖà 1a±êóòòÆ  ÕûÆá2»òƶˉ
        wrc(0x0c);        //ÏÔ꾿a1Ø¿ØÖÆ  ¿aÏÔê¾  ÎT1a±ê 1a±ê2»éá˸
        wrc(0x01);        //ÇåáãÖ¸áî  1춨μÄ
//¸′λDHT11
void DHT11_Rst()
    DHT11_DQ_OUT=0;         //à-μíDQ
    delay_ms(20);            //à-μíÖáéù18ms
    DHT11_DQ_OUT=1;         //DQ=1
        delay(3);             //Ö÷»úà-¸ß20~40us
//μè′yDHT11μÄ»Øó|
//·μ»Ø1:Î′¼ì2aμ½DHT11μÄ′æÔú
//·μ»Ø0:′æÔú
uint8 DHT11_Check()
        uint8 retry=0;
    while (DHT11_DQ_OUT&&retry<100)//DHT11»áà-μí40~50us
                retry++;
                _nop_();
        if(retry>=100)return 1;
        else retry=0;
    while (!DHT11_DQ_OUT&&retry<100)//DHT11à-μíoó»áÔù′Îà-¸ß40~50us
                retry++;
                _nop_();
        return 0;
//DHT113õê¼»ˉ
//·μ»Ø0£o3õê¼»ˉ3é1|£¬1£oê§°ü
uint8 DHT11_Init()
        DHT11_Rst();
        return DHT11_Check();
//′óDHT11¶áè¡ò»¸öλ
//·μ»ØÖμ£o1/0
uint8 DHT11_Read_Bit(void)
        uint8 retry=0;
        while(DHT11_DQ_OUT&&retry<100)//μè′y±äÎaμíμçÆ½ 12-14us ¿aê¼
                retry++;
                _nop_();
        retry=0;
        while((!DHT11_DQ_OUT)&&retry<100)//μè′y±ä¸ßμçÆ½         26-28us±íê¾0,116-118us±íê¾1
                retry++;
                _nop_();
        delay(1);//μè′y40us
        if(DHT11_DQ_OUT)return 1;
        else return 0;
//′óDHT11¶áè¡ò»¸ö×Ö½ú
//·μ»ØÖμ£o¶áμ½μÄêy¾Y
uint8 DHT11_Read_Byte(void)
    uint8 i,dat=0;
        for (i=0;i<8;i++)
                   dat<<=1;
            dat|=DHT11_Read_Bit();
    return dat;
//′óDHT11¶áè¡ò»′Îêy¾Y
//temp:ζèÖμ(·¶Î§:0~50¡ã)
//humi:êa¶èÖμ(·¶Î§:20%~90%)
//·μ»ØÖμ£o0,Õy3£;1,¶áè¡ê§°ü
uint8 DHT11_Read_Data(uint8 *temp,uint8 *humi)
        uint8 buf[5];
        uint8 i;
        DHT11_Rst();
        if(DHT11_Check()==0)
                for(i=0;i<5;i++)//¶áè¡40λêy¾Y
                        buf[i]=DHT11_Read_Byte();
                if((buf[0]+buf[1]+buf[2]+buf[3])==buf[4])
                        *humi=buf[0];
                        *temp=buf[2];
        }else return 1;
        return 0;
void ds18b20init()                //18b20μÄ3õê¼»ˉ
        dq=1;
        delay(1);
        dq=0;
        delay(80);
        dq=1;
        delay(5);
        dq=0;
        delay(20);
        dq=1;
        delay(35);
void ds18b20wr(uint8 dat)          //18b20D′êy¾Y
        uint8 i;
        for(i=0;i<8;i++)
                dq=0;
                dq=dat&0x01;
                dat>>=1;
                delay(8);//Ôúê±DòéÏÖ»óDÕaò»¿é¶Ôê±DòòaÇó×î׼跣¬ËûμÄê±¼ä±ØDë′óóú15us
                dq=1;
                delay(1);
uint8 ds18b20rd()                  //18b20¶áêy¾Y
        uint8 value,i;
        for(i=0;i<8;i++)
                dq=0;
                value>>=1;
                dq=1;
                if(dq==1)value|=0x80;
                delay(8);//ÔúÕaò»¿éò2¶Ôê±¼äòaÇóìØ±e׼跣¬Õû¶Î3ìDò±ØDë′óóú60us
        return value;
uint8 readtemp()                          //¶áè¡Î¶èÄúDèòa¸′λμÄ
        uint8 b;
        ds18b20init();                //3õê¼»ˉ
        ds18b20wr(0xcc);   //·¢ËíoöÂÔROMÖ¸áî
        ds18b20wr(0x44);   //·¢Ëíζè×a»»Ö¸áî
        delay(100);
        ds18b20wr(0xbe);   //·¢¶áÔY′æÆ÷Ö¸áî
        a=ds18b20rd();         //ζèμÄμí°Ëλ
        b=ds18b20rd();         //ζèμĸ߰Ëλ
        b<<=4;                         //ssss s***£»sÎa±ê־λs=0±íê¾Î¶èÖμÎaÕyêy£¬s=1ζèÖμÎa¸oêy
        c=b&0x80;                //ζèÕy¸o±ê־λè·èÏ
        b+=(a&0xf0)>>4;
        a=a&0x0f;          //ζèμÄD¡êy2¿·Ö
        return b;
void key_pros()  //°′¼ü′|àíoˉêy
        if(k1==0)
                delay(1000);
                if(k1==0)
                        mode++;
                        if(mode==5)mode=0;
                        wrc(0x01);
                while(!k1);
        if(mode==1)                  //¶ÔζèéÏÏTé趨
                if(k2==0)                  //¼ó
                        delay(1000);
                        if(k2==0)
                                temph++;
                                if(temph>=80)temph=80;
                        while(!k2);
                if(k3==0)           //¼õ
                        delay(1000);
                        if(k3==0)
                                temph--;
                                if(temph<=0)temph=0;
                        while(!k3);
        if(mode==2)                  //¶ÔζèÏÂÏTé趨
                if(k2==0)                  //¼ó
                        delay(1000);
                        if(k2==0)
                                templ++;
                                if(templ>=80)templ=80;
                        while(!k2);
                if(k3==0)           //¼õ
                        delay(1000);
                        if(k3==0)
                                templ--;
                                if(templ<=0)templ=0;
                        while(!k3);
        if(mode==3)                  //¶Ôêa¶èéÏÏTé趨
                if(k2==0)                  //¼ó
                        delay(1000);
                        if(k2==0)
                                humih++;
                                if(humih>=80)humih=80;
                        while(!k2);
                if(k3==0)           //¼õ
                        delay(1000);
                        if(k3==0)
                                humih--;
                                if(humih<=0)humih=0;
                        while(!k3);
        if(mode==4)                  //¶Ôêa¶èÏÂÏTé趨
                if(k2==0)                  //¼ó
                        delay(1000);
                        if(k2==0)
                                humil++;
                                if(humil>=80)humil=80;
                        while(!k2);
                if(k3==0)           //¼õ
                        delay(1000);
                        if(k3==0)
                                humil--;
                                if(humil<=0)humil=0;
                        while(!k3);
void lcd_init_display()           //LCD3õê¼»ˉÏÔê¾
        uint8 i;
        for(i=0;i<5;i++)
                wrc(0x80+i);
                wrd(str1[i]);
        for(i=0;i<5;i++)
                wrc(0xc0+i);
                wrd(str2[i]);
void data_pros()        //êy¾Y′|àíoˉêy
        uint8 i;
        uint8 temp_buf[2],humi_buf[2];
        uint8 temphbuf[2],templbuf[2],humihbuf[2],humilbuf[2];
        float dio;
        uint16 k;
        tempvalue=readtemp();
        DHT11_Read_Data(&temp,&humi);
        temp_buf[0]=temp/10+0x30;
        temp_buf[1]=temp%10+0x30;
        humi_buf[0]=humi/10+0x30;
        humi_buf[1]=humi%10+0x30;
        dio=a*0.0625;
        k=dio*10000;//è¡D¡êyμãoóá½Î»óDD§êy×Ö
        temphbuf[0]=temph/10+0x30;
        temphbuf[1]=temph%10+0x30;
        templbuf[0]=templ/10+0x30;
        templbuf[1]=templ%10+0x30;
        humihbuf[0]=humih/10+0x30;
        humihbuf[1]=humih%10+0x30;
        humilbuf[0]=humil/10+0x30;
        humilbuf[1]=humil%10+0x30;
        if(mode==0)
                lcd_init_display();
                wrc(0x85);
                wrd(num[tempvalue%100/10]);
                wrd(num[tempvalue%100%10]);
                wrd('.');
                wrd(num[k/1000]);
                wrd(0xdf);
                wrd('C');
                for(i=0;i<2;i++)
                        wrc(0Xc5+i);
                        wrd(humi_buf[i]);
                for(i=0;i<3;i++)
                        wrc(0Xc7+i);
                        wrd(str5[i]);
        if(mode==1)                          //ζèéÏÏTÏÔê¾
                wrc(0x80);
                for(i=0;i<6;i++)
                        wrd(str6[i]);
                wrd(temphbuf[0]);
                wrd(temphbuf[1]);
        if(mode==2)                          //ζèÏÂÏTÏÔê¾
                wrc(0x80);
                for(i=0;i<6;i++)
                        wrd(str7[i]);
                wrd(templbuf[0]);
                wrd(templbuf[1]);
        if(mode==3)                          //êa¶èéÏÏTÏÔê¾
                wrc(0x80);
                for(i=0;i<6;i++)
                        wrd(str8[i]);
                wrd(humihbuf[0]);
                wrd(humihbuf[1]);
        if(mode==4)                          //êa¶èÏÂÏTÏÔê¾
                wrc(0x80);
                for(i=0;i<6;i++)
                        wrd(str9[i]);
                wrd(humilbuf[0]);
                wrd(humilbuf[1]);
void baojinpros()        //±¨¾ˉ′|àí
        if(tempvalue>=temph||humi>=humih)         //¼ì2aζè»òÕßêa¶è¸ßóúé趨éÏÏTÖμ ½μÎÂêa
                led1=1;                //½μÎÂêaÖ¸ê¾μÆ
                led2=0;
        if(tempvalue<=templ||humi<=humil)        //¼ì2aζè»òÕßêa¶èμíóúé趨ÏÂÏTÖμ  éyÎÂêa
                led1=0;
                led2=1;           //éy¸ßÎÂêaÖ¸ê¾μÆ
        if((tempvalue>templ&&tempvalue<temph)&&(humi>humil&&humi<humih))
                led1=0;
                led2=0;
        uint8 i=0;
        led1=0;
        led2=0;
        lcd_init();
        while(DHT11_Init())        //¼ì2aDHT11êÇ·ñ′¿Ôú
                for(i=0;i<5;i++)
                        wrc(0x80+i);
                        wrd(str3[i]);
        wrc(0x01);
        lcd_init_display();           //LCD3õê¼»ˉÏÔê¾
        i=0;
                i++;
                key_pros();
                baojinpros();        //±¨¾ˉ′|àí
                if(i==15)
                        i=0;
                        data_pros();           //¶áè¡ò»′ÎDHT11êy¾Y×îéùòa′óóú100ms
                delay(1000);
HC6800-ES V2.0.pdf
404.98 KB, 下载次数: 3, 下载积分: 黑币 -5
52单片机
