查看: 4141|回复: 8
咨询一个单片机同时驱动数码管和点阵有闪烁的问题
通过数码管做的频率计,点阵来显示波形。但是波形和数码管会出现闪烁的问题,求大神解决
ID:235629 发表于 2017-11-27 16:15 | 只看该作者
#include <reg51.h>
#include<intrins.h>
#define uint  unsigned  int
uchar duan[10]={0xc0,0Xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};         //所需的段的位码
//uchar wei[4]={0XEf,0XDf,0XBf,0X7f};                                 //位的控制端        (开发板)
uchar wei[4]={0X80,0X40,0X20,0X10};                                 //位的控制端        (仿真)
uint z,x,c,v, date;        //定义数据类型
uint dispcount=0;
uint lck=0;
uint disp=0;
/*  数据端接口定义 */
sbit  key0=P1^0;
sbit  key1=P1^1;
sbit  key2=P1^2;
sbit  key3=P1^3;
sbit  sck = P2^0;                 //输入时钟
sbit  row_dat = P2^1;         //行数据时钟
sbit  row_buf_sck = P2^2; //行锁存
//sbit  row_mr = P2^4;          //移位寄存器清零端
//sbit  row_oe = P2^5;        //输出使能
/*  选通端接口定义 */
sbit  col_dat = P2^6;          //列数据时钟
sbit  col_buf_sck = P2^3; //列锁存
unsigned char keyval;
unsigned int code sel[16] = {0xff7f,0x7fff,0xffbf,0xbfff,0xffdf,0xdfff,0xffef,0xefff,
                                                         0xfff7,0xf7ff,0xfffb,0xfbff,0xfffd,0xfdff,0xfffe,0xfeff};
unsigned char code hanzi[4][32] =
{0x1C,0x00,0x20,0x00,0x40,0x00,0x40,0x00,0x20,0x00,0x1C,0x00,0x02,0x00,0x01,0x00,
0x01,0x00,0x02,0x00,0x1C,0x00,0x20,0x00,0x40,0x00,0x40,0x00,0x20,0x00,0x1C,0x00},/*"正弦",0*/
{0x00,0xFF,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFF,0x00,0x01,0x00,0x01,
0x00,0x01,0x00,0x01,0x00,0xFF,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFF},/*"方波",1*/
{0x00,0x40,0x00,0x80,0x01,0x00,0x02,0x00,0x01,0x00,0x00,0x80,0x00,0x40,0x00,0x20,
0x00,0x40,0x00,0x80,0x01,0x00,0x02,0x00,0x01,0x00,0x00,0x80,0x00,0x40,0x00,0x20},/*"三角波",2*/
{0x1C,0xFF,0x20,0x80,0x40,0x80,0x40,0x80,0x20,0x80,0x1C,0xFF,0x02,0x01,0x01,0x01,
0x01,0x01,0x02,0x01,0x1C,0xFF,0x20,0x80,0x40,0x80,0x40,0x80,0x20,0x80,0x1C,0xFF},/*"正弦和方波",3*/
void display(unsigned char *p);
void send_data_row(unsigned int dat);  /*  发送行数据端数据函数  */
void send_data_col(unsigned int dat);  /*  发送列选通端数据函数  */
void delay(unsigned int m);
void T(void);
void delay10ms();
void delayfre(uchar t)
  uchar i,j;
   for(i=0;i<t;i++)
            for(j=13;j>0;j--);
void xianshi()
/*****************数据转换*****************************/
  z=date/1000;                         //求千位
  x=date%1000/100;                 //求百位
  c=date%100/10;                 //求十位
  v=date%10;                         //求个位
      P2=wei[0];
          P0=duan[z];
          delayfre(30);
            P2=wei[1];
      P0=duan[x];
          delayfre(30);
             P2=wei[2];
      P0=duan[c];
          delayfre(30);
      P2=wei[3];
      P0=duan[v];
          delayfre(30);
                                定时器初值1ms
void initTimer(void)
TMOD=0x0;
TH0=0xe3;
TL0=0xc;
                                定时器函数
void timer0(void) interrupt 1
TH0=0xe3;
TL0=0xc;
lck++;
if(lck==1000)
        disp=dispcount;
            lck=0;
                dispcount=0;
                                中断函数
void int0(void) interrupt 0
dispcount++; //每一次中断,计数加一
void T(void)
        P1=0xff;
        if((P1&0x0f)!=0x0f)
        delay10ms();
             if(key0==0)
        keyval=0;
                if(key1==0)
        keyval=1;
                if(key2==0)
        keyval=2;
                if(key3==0)
        keyval=3;
void delay10ms(void)
unsigned char i,j;
for(i=0;i<100;i++)
for(j=0;j<100;j++)
        unsigned char i;
        for(i=0;i<16;i++)
                sck = 0;
                row_dat = dat&0x8000;                //temp<<=1;
                dat = dat<<1;                                //ds = CY;
                sck = 1;
        row_buf_sck = 0;
        _nop_();
        _nop_();
        row_buf_sck = 1;
        unsigned char i;
        for(i=0;i<16;i++)
                sck = 0;
                col_dat = dat&0x8000;
                dat = dat<<1;
                sck = 1;
        col_buf_sck = 0;
        _nop_();
        _nop_();
        col_buf_sck = 1;
        unsigned char i;
        for(;m>0;m--)
                for(i=0;i<124;i++)
        unsigned char i;
//        unsigned int temp;
        for(i=0;i<32;i++)
                if(i<16)
                        send_data_row(0x0000);
                //        temp = sel[i]|0xff00;
                        send_data_col(sel[i]);
                        send_data_row(*p);
                        p++;
                                                delay(2);
                //        temp = (sel[i]<<8)|0x00ff;
                        send_data_col(sel[i-16]);
                        send_data_row((*p)<<8);
                        p++;
                                                delay(2);
          IT0=1;     //INT0下降沿中断
EX0=1;     //允许INT1中断
initTimer(); //装入初值
TR0=1;
ET0=1;
EA=1;
keyval=0;
          date=disp;
xianshi();
T();
switch(keyval)
case 0:display(hanzi[0]);
break;
case 1:display(hanzi[1]);
break;
case 2:display(hanzi[2]);
break;
case 3:display(hanzi[3]);
break;
ID:235629 发表于 2017-11-27 17:09 | 只看该作者
#include <reg51.h>
#include<intrins.h>
uint dispcount=0;
uint lck=0;
uint disp=0;
/*  数据端接口定义 */
sbit  key0=P1^0;
sbit  key1=P1^1;
sbit  key2=P1^2;
sbit  key3=P1^3;
/*  选通端接口定义 */
void T(void);
void delay10ms();
  uchar i,j;
   for(i=0;i<t;i++)
            for(j=13;j>0;j--);
void xianshi()
  z=date/1000;                         //求千位
  v=date%10;                         //求个位
      P2=wei[0];
          P0=duan[z];
          delayfre(30);
            P2=wei[1];
      P0=duan[x];
          delayfre(30);
             P2=wei[2];
      P0=duan[c];
          delayfre(30);
      P2=wei[3];
      P0=duan[v];
          delayfre(30);
                                定时器初值1ms
TMOD=0x0;
TH0=0xe3;
TL0=0xc;
                                定时器函数
TH0=0xe3;
TL0=0xc;
lck++;
if(lck==1000)
        disp=dispcount;
            lck=0;
                dispcount=0;
                                中断函数
void T(void)
        P1=0xff;
        if((P1&0x0f)!=0x0f)
        delay10ms();
             if(key0==0)
        keyval=0;
                if(key1==0)
        keyval=1;
                if(key2==0)
        keyval=2;
                if(key3==0)
        keyval=3;
unsigned char i,j;
for(i=0;i<100;i++)
for(j=0;j<100;j++)
        unsigned char i;
        for(i=0;i<16;i++)
                sck = 0;
                sck = 1;
        row_buf_sck = 0;
        _nop_();
        _nop_();
        row_buf_sck = 1;
        unsigned char i;
        for(i=0;i<16;i++)
                sck = 0;
                dat = dat<<1;
                sck = 1;
        col_buf_sck = 0;
        _nop_();
        _nop_();
        col_buf_sck = 1;
        unsigned char i;
        for(;m>0;m--)
                for(i=0;i<124;i++)
        unsigned char i;
        for(i=0;i<32;i++)
                if(i<16)
                        send_data_row(*p);
                        p++;
                                                delay(2);
                        p++;
                                                delay(2);
          IT0=1;     //INT0下降沿中断
EX0=1;     //允许INT1中断
initTimer(); //装入初值
TR0=1;
ET0=1;
EA=1;
keyval=0;
           T();
          date=disp;
xianshi();
switch(keyval)
break;
break;
break;
break;
ID:254304 发表于 2017-11-27 18:55 | 只看该作者
如果显示结果是正常的,只是显示闪烁,那可能是单片机刷新的速度不够,可以把你耗时间的运算用耗时间少的操作代替掉,比如:*用左移替换掉,把delay10ms用别的操作替换掉,10MS太大了,比如用显示操作替换掉DELAY的时间,还不行的话,就用4片595支持数码管的显示,其与时间用来刷新点阵模块。
ID:235629 发表于 2017-11-27 20:11 | 只看该作者
fancean 发表于 2017-11-27 18:55
如果显示结果是正常的,只是显示闪烁,那可能是单片机刷新的速度不够,可以把你耗时间的运算用耗时间少的操 ...
好的,我试一下。新手,有太多不懂的了
ID:142559 发表于 2017-11-27 20:16 | 只看该作者
应该是你的程序所用时间太长,出现“延时”的情况了
ID:254398 发表于 2017-11-27 21:41 | 只看该作者
程序准备时间太长,再次进入之前耗时太长
ID:253967 发表于 2017-11-27 23:03 | 只看该作者
好帖,赞一个
ID:254453 发表于 2017-11-27 23:37 来自触屏版 | 只看该作者
好帖,赞
