查看: 4630|回复: 1
1602字符液晶自动水平和垂直滚动演示程序加仿真
在单片机的控制下能实现自动水平滚动与自动垂直滚动,并且带有暂停开始按钮
  1. /***************   writer:shopping.w   ******************/
  2. #include <reg52.h>
  3. #include <string.h>
  5. #define uint unsigned int
  6. void Initialize_LCD();
  7. void ShowString(uchar,uchar,uchar *);
  8. sbit K1 = P3^0;
  9. sbit K2 = P3^1;
  10. sbit K3 = P3^2;
  11. uchar code Prompt[]="PRESS K1--K4 TO START DEMO PROG";
  12. uchar const Line_Count = 6;
  13. uchar code Msg[][80]=
  14. {
  15.          "Many CAD users dismiss",
  16.         "process of creating PCB",
  17.         "of view.with PCB layout",
  18.         "placement and track routing,",
  19.         "can often be the most time",
  20.         "And if you use circuit simulation",
  21.         "you are going to spend even more"
  22. };
  23. uchar Disp_Buffer[32];
  24. void Delayxms(uint ms)
  25. {
  26.          uchar i;
  27.         while(ms--)
  28.         {
  29.                  for(i=0;i<120;i++);
  30.         }
  31. }
  32. void V_Scroll_Display()
  33. {
  34.          uchar i,j,k = 0;
  35.         uchar *p = Msg[0];
  36.         uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  37.         while(p<q)
  38.         {
  39.                  for(i=0;(i<16)&&(p<q);i++)
  40.                 {
  41.                          if(((i==0)||(i==15))&& *p == ' ')
  42.                                 p++;
  43.                         if(*p != '\0')
  44.                         {
  45.                                  Disp_Buffer[i] = *p++;
  46.                         }
  47.                         else
  48.                         {
  49.                                  if(++k>Line_Count)
  50.                                         break;
  51.                                 p = Msg[k];
  52.                                 Disp_Buffer[i] = *p++;
  53.                         }
  54.                 }
  55.                 for(j=i;j<16;j++)
  56.                         Disp_Buffer[j]=' ';
  57.                 while(F0)
  58.                         Delayxms(5);
  59.                 ShowString(0,0,"      ");
  60.                 Delayxms(150);
  61.                 while(F0)
  62.                         Delayxms(5);
  63.                 ShowString(0,1,Disp_Buffer);
  64.                 Delayxms(150);
  65.                 while(F0)
  66.                         Delayxms(5);
  67.                 ShowString(0,0,Disp_Buffer);
  68.                 ShowString(0,1,"      ");
  69.                 Delayxms(150);
  70.         }
  71.         ShowString(0,0,"         ");
  72.         ShowString(0,1,"         ");
  73. }
  74. void H_Scroll_Display()
  75. {
  76.         uchar m,n,t = 0,L=0;
  77.         uchar *p = Msg[0];
  78.         uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  79.         for(m=0;m<16;m++)
  80.                         Disp_Buffer[m]=' ';
  81.         while(p<q)
  82.         {
  83.                  if((m=16||m==31)&& *p == ' ')
  84.                         p++;
  85.                 for(m=16;m<32&&p<q;m++)
  86.                 {
  87.                          if(*p != '\0')
  88.                         {
  89.                                 Disp_Buffer[m] = *p++;
  90.                         }
  91.                         else
  92.                         {
  93.                                  if(++t>Line_Count)
  94.                                         break;
  95.                                 p = Msg[t];
  96.                                 Disp_Buffer[m] = *p++;
  97.                         }
  98.                 }
  99.                 for(n=m;n<32;n++)
  100.                         Disp_Buffer[n]=' ';
  101.                 for(m=0;m<=16;m++)
  102.                 {
  103.                          while(F0)
  104.                                  Delayxms(5);
  105.                            ShowString(0,L,Disp_Buffer+1);
  106.                            while(F0)
  107.                                  Delayxms(5);
  108.                         Delayxms(20);
  109.                 }
  110.                 L = (L==0)? 1:0;
  111.                 Delayxms(200);
  112.         }
  113.         if(L==1)
  114.                 ShowString(0,1,"      ");
  115. }
  116. void EX_INT0() interrupt 0
  117. {
  118.          F0 = !F0;
  119. }
  120. void main()
  121. {
  122.          uint Count = 0;
  123.         IE = 0x81;
  124.         IT0 = 1;
  125. ……………………
  126. …………限于本文篇幅 余下代码请从51黑下载附件…………
60 1602字符液晶滚动演示程序.zip (63.09 KB, 下载次数: 33)
参与人数 1黑币 +5 收起 理由
yinkun230 + 5 淡定
ID:523060 发表于 2019-5-4 19:02 | 只看该作者
很好,解决了我很大问题
