1602液晶上面一行全部是黑色的,51单片机求助啊
wushuai1115
2014-12-1 16:04
本人想学51单片机,做了一个程序,在不加定时器和主函数的时候液晶显示正常,虽然时间不动,但是当打开定时器时加入main函数1602液晶上面一行全部是黑色的,下面一行没反应,具体程序有,望大虾帮助解惑。
#include<reg52.h>
sbit RS=P2^4;
sbit RW=P2^5;
sbit EN=P2^6;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
uchar count,shi,fen,miao;
uchar code shijian[]="TIME 00:00:00 ";
uchar code wendu[]="TEMP 00 C ";
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void LCD_write_com(uchar com)
RS=0;
RW=0;
EN=0;
P0=com;
delay(5);
EN=1;
delay(5);
EN=0;
void LCD_write_date(uchar date)
RS=1;
RW=0;
EN=0;
P0=date;
delay(5);
EN=1;
delay(5);
EN=0;
void LCD_init()
uchar num;
EN=0;
LCD_write_com(0x38);
delay(5);
LCD_write_com(0x0c);
delay(5);
LCD_write_com(0x06);
delay(5);
LCD_write_com(0x01);
LCD_write_com(0x80);
for(num=0;num<14;num++)
LCD_write_date(shijian[num]);
delay(5);
LCD_write_com(0x80+0x40);
for(num=0;num<11;num++)
LCD_write_date(wendu[num]);
delay(5);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void LCD_write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
LCD_write_com(0x80+add);
LCD_write_date(0x30+shi);
LCD_write_date(0x30+ge);
LCD_init;
if(count==20)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
LCD_write_sfm(6,shi);
LCD_write_sfm(9,fen);
LCD_write_sfm(12,miao);
void Timer0_isr(void) interrupt 1
count++;
admin
2014-12-1 17:47
看这个应该对你有帮助
http://www.51hei.com/bbs/dpj-28753-1.html
