查看: 4859|回复: 5
51单片机处理GPS模块及LCD1602
ID:201229 发表于 2017-5-16 09:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这其中包括1602驱动头文件,和解析主程序,使用时分开粘贴到对应的 文件中
/*  LCD1602驱动,兼容LCD2402 */
   sbit LCD_DB0= P0^0;
   sbit LCD_DB1= P0^1;
   sbit LCD_DB2= P0^2;
   sbit LCD_DB3= P0^3;
   sbit LCD_DB4= P0^4;
   sbit LCD_DB5= P0^5;
   sbit LCD_DB6= P0^6;
   sbit LCD_DB7= P0^7;
   sbit LCD1602_RS=P2^4;
   sbit LCD1602_RW=P2^5;
   sbit LCD1602_EN=P2^6;
   void LCD_write_char( unsigned char x,unsigned char y,unsigned char dat); //在指定位置显示字符
   void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);//在指定位置显示字符串
   void LCD_cls(void);//清屏
   void LCD_en_command(unsigned char command);
   void LCD_en_dat(unsigned char temp);
   void LCD_set_xy( unsigned char x, unsigned char y );
   void LCD_init(unsigned char bw);
   void SET_LCD(unsigned char IO_temp);
   void delayms(unsigned char ms);
   void lcddelay(void);
   unsigned char LCDIO;
   unsigned char BitWidth;
   void LCD_cls(void)
   LCD_en_command(0x01); //0x01 清屏
     delayms(2);
     LCD1602_RS=0;
     LCD1602_RW=0;
     LCD1602_EN=0;
  switch(BitWidth)
      case 4:   LCDIO=(command & 0xf0);   //取高4位
      break;
      case 8:   LCDIO=command;
      break;
    SET_LCD(LCDIO);
    LCD1602_EN=1;
    lcddelay();
    LCD1602_EN=0;
   if (BitWidth==4)
    LCDIO=(command & 0x0f)<<4;  //取低4位
    SET_LCD(LCDIO);
    LCD1602_EN=1;
    lcddelay();
    LCD1602_EN=0;
{     //高4位
    LCD_DB7=IO_temp&0x80;
    LCD_DB6=IO_temp&0x40;
    LCD_DB5=IO_temp&0x20;
    LCD_DB4=IO_temp&0x10;  //低4位
  if (BitWidth==8)
    LCD_DB3=IO_temp&0x08;
    LCD_DB2=IO_temp&0x04;
    LCD_DB1=IO_temp&0x02;
    LCD_DB0=IO_temp&0x01;
   void LCD_en_dat(unsigned char dat)
    LCD1602_RS=1;
    LCD1602_RW=0;
    LCD1602_EN=0;
  switch(BitWidth)
    case 4:   LCDIO=(dat & 0xf0);   //取高4位
    break;
    case 8:   LCDIO=dat;
    break;
    SET_LCD(LCDIO);
    LCD1602_EN=1;
    lcddelay();
    LCD1602_EN=0;
  if (BitWidth==4)
    LCDIO=(dat & 0x0f)<<4;  //取低4位
    SET_LCD(LCDIO);
    LCD1602_EN=1;
    lcddelay();
    LCD1602_EN=0;
*1602
  * 输入参数:x、y : 显示字符串的坐标,X:0-15,Y:0-1
  *LCD第一行显示寄存器地址:0X80-0X8F
  *LCD第二行显示寄存器地址:0XC0-0XCF
  *2404  *LCD第1行显示地址:1~20(0x80~0x93)
  *LCD第2行显示地址:1~20(0xc0~0xd3)
  *LCD第3行显示地址:1~20(0x94~0xa7)
  *LCD第4行显示地址:1~20(0xd4~0xe7)
  unsigned char address;
  if (y ==0)
       address = 0x80 + x;
    if(y==1)
      address = 0xC0 + x;
      if(y==2)
      address = 0x94 + x;
     if(y==3)
       address = 0xD4 + x;
   LCD_en_command(address);
   void LCD_write_char( unsigned x,unsigned char y,unsigned char dat)
   LCD_set_xy( x, y );
   LCD_en_dat(dat);
      LCD_set_xy( X, Y );    //set address
      while (*s)       // write character
       LCDIO=*s;
       SET_LCD(LCDIO);
       LCD_en_dat(*s);
       s ++;
     BitWidth=bw;
     switch(BitWidth)
       case 4:   LCD_en_command(0x33); //
       delayms(20);
       LCD_en_command(0x32); //
       delayms(20);
       break;
       case 8:   LCD_en_command(0x38); //
       delayms(20);
       delayms(20);
       break;
      LCD_en_command(0x08); //0x08 令显示器off
      delayms(5);
      LCD_en_command(0x01); //0x01 清屏   清屏指令
      delayms(5);
      LCD_en_command(0x06); //0x06 光标模式设置 进入模式设置指令 写入数据后光标右移
      delayms(5);
      LCD_en_command(0x0c); //0x0c 显示开     令光标,0x0c=不显示,0x0d=显示闪动
      delayms(5);
    unsigned char i;
    while(ms--)
  for(i = 0; i < 115; i++);
   void lcddelay(void)
    unsigned char i;
    for(i = 0; i < 2; i++);
  GPS解码显示程序,
#include<reg52.h>
#include "1602.h" //
#include"math.h" //
#include <stdlib.h>
sbit GPS_SPD=P3^2;   //GPS模块速率设置
sbit KEY1=P3^3;   //显示内容分屏切换,(T0,T1引脚 的第二功能为计数器。)
char code TIME_AREA= 8;  //时区
        这是做的部分更改
unsigned long maxspeed,b;
unsigned int count=0;
unsigned int a[5];
unsigned char hspeed[5];
unsigned int dot_count; //小数点计数器
unsigned char x;
//GPS数据存储数组
unsigned char JD[10];  //经度
unsigned char JD_a;  //经度方向
unsigned char WD[9];  //纬度
unsigned char WD_a;  //纬度方向
unsigned char date[6];  //日期
unsigned char time[6];  //时间
unsigned char speed[5]={'0','0','0','.','0'};  //速度
unsigned char high[6];  //高度
  unsigned char angle[5]={'0','0','0','0','0'};  //方位角
unsigned char use_sat[2]; //使用的卫星数
unsigned char total_sat[2]; //天空中总卫星数
unsigned char lock;   //定位状态
//串口中断需要的变量
unsigned char seg_count; //逗号计数器
unsigned char byte_count; //位数计数器
unsigned char cmd_number; //命令类型
unsigned char mode;   //0:结束模式,1:命令模式,2:数据模式
unsigned char buf_full;  //1:整句接收完成,相应数据有效。0:缓存数据无效
unsigned char cmd[5];  //命令类型存储数组
   //显示需要的变量
unsigned int dsp_count;  //刷新次数计数器
unsigned char time_count;
bit page;
void sys_init(void);
bit chk_key(void);
   main()
  unsigned char i;
  char Bhour;
  sys_init();
  ock=1;
  use_sat[0]='0';
  use_sat[1]='0';
  total_sat[0]='0';
  total_sat[1]='0';
     if(buf_full==0)    //无GPS信号时
    dsp_count++;
    if(dsp_count>=65000)
     LCD_cls();   //清屏
     LCD_write_string(0,0,"No GPS connect..");
     LCD_write_string(0,1,"Please Check..");
     while(buf_full==0);
     LCD_cls();
     dsp_count=0;
   else{      //有GPS信号时
     if(chk_key())
    //检测到按键切换显示
     page=!page;
     LCD_cls();
     if(!page)
{      //页面1
     if(buf_full|0x01)
{    //GGA语句
      if(lock==0)
{     //如果未定位
      LCD_write_string(0,0,"*---.--.----  ");
      LCD_write_string(0,1,"* --.--.----  ");
{       //如果已定位
      LCD_write_char(0,0,JD_a);   //显示经度
  for(i=0;i<3;i++)
        LCD_write_char(i+1,0,JD[i]);
         LCD_write_char(4,0,'.');
         for(i=3;i<10;i++)
         LCD_write_char(i+2,0,JD[i]);
         LCD_write_char(0,1,WD_a);   //显示纬度
         LCD_write_char(1,1,' ');
         for(i=0;i<2;i++)
         LCD_write_char(i+2,1,WD[i]);
         LCD_write_char(4,1,'.');
         for(i=2;i<9;i++)
         LCD_write_char(i+3,1,WD[i]);
         LCD_write_char(14,1,use_sat[0]);  //显示接收卫星数
         LCD_write_char(15,1,use_sat[1]);
         buf_full&=~0x01;
         dsp_count=0;
     if(buf_full|0x02)
  {    //GSV语句
      LCD_write_char(14,1,total_sat[0]);
      LCD_write_char(15,1,total_sat[1]);
      buf_full&=~0x02;
      dsp_count=0;
      if(buf_full|0x04)
     if(lock==0)
{     //如果未定位
  {       //如果已定位
       for(i=0;i<3;i++)
       for(i=3;i<10;i++)
       for(i=0;i<2;i++)
      for(i=2;i<9;i++)
      LCD_write_char(14,0,use_sat[0]);  //显示接收卫星数
      LCD_write_char(15,0,use_sat[1]);
      buf_full&=~0x04;
      dsp_count=0;
   {       //页面2
      if(buf_full|0x01)
    {    //GGA语句
      buf_full&=~0x01;
      dsp_count=0;
      if(buf_full|0x02)
      buf_full&=~0x02;
      dsp_count=0;
      if(buf_full|0x04)
  {    //RMC语句
      Bhour=((time[0]-0x30)*10+time[1]-0x30)+TIME_AREA;
      if(Bhour>=24)
       Bhour-=24;
       else if(Bhour<0)
       Bhour+=24;
       LCD_write_char(0,1,date[4]);
       LCD_write_char(1,1,date[5]);
       LCD_write_char(2,1,date[2]);
       LCD_write_char(3,1,date[3]);
       LCD_write_char(4,1,date[0]);
       LCD_write_char(5,1,date[1]);
       LCD_write_char(8,1,Bhour/10+0x30);
       LCD_write_char(9,1,Bhour%10+0x30);
       LCD_write_char(10,1,':');
       LCD_write_char(11,1,time[2]);
       LCD_write_char(12,1,time[3]);
       LCD_write_char(13,1,':');
       LCD_write_char(14,1,time[4]);
       LCD_write_char(15,1,time[5]);
       LCD_write_string(5,0,"knot A");         //在此处做的更改
       if(lock=='0'){     //如果未定位
       LCD_write_string(0,0,"---.-");
       LCD_write_string(11,0,"---.-");
                                                      //已经定位,在此处做的改动。  /*******************************************************************************
  最大速度处理
      dot_count=0;
      b=0;
      for(i=0;i<5;i++)
      if(speed[i]!='.')
      dot_count++;
      break;
      switch(dot_count)
      case 1:
      b=((speed[0]-'0')*10+(speed[2]-'0'))*1.852;
      break;
      case 2:
      b=((speed[0]-'0')*100+(speed[1]-'0')*10+(speed[4]-'0'))*1.852;
      break;
      case 3:
      b=((speed[0]-'0')*1000+(speed[1]-'0')*100+(speed[2]-'0')*10+(speed[4]-'0'))*1.852;
      break;
      if(b>maxspeed)
      maxspeed=b;
  最大速度处理
      if(count<10)
      for(i=0;i<5;i++)
      LCD_write_char(i,0,speed[i]);//knot显示
      count++;
      if(count>15)
      count=0;
      hspeed[0]=maxspeed/1000+0x30;                     //把小数转成字符数组
      hspeed[1]=(maxspeed/100)%10+0x30;
      hspeed[2]=(maxspeed/10)%10+0x30;
      hspeed[3]='.';
      hspeed[4]= maxspeed%10+0x30;
      count++;
      LCD_write_string(5,0,"Km/h A");
      LCD_write_char(0,0,hspeed[0]);
      LCD_write_char(1,0,hspeed[1]);
      LCD_write_char(2,0,hspeed[2]);
      LCD_write_char(3,0,hspeed[3]);
      LCD_write_char(4,0,hspeed[4]); //最大速度显  */
     for(i=0;i<5;i++)
     LCD_write_char(11+i,0,angle[i]);
     buf_full&=~0x04;
     dsp_count=0;
   bit chk_key(void)
  if(!KEY1)
    delayms(10);
    if(!KEY1)
    while(!KEY1);
    delayms(10);
    return(1);
  LCD_cls();   //清屏
  return(0);
   //系统初始化
void sys_init()
  unsigned char i;
  SCON = 0x50;
  /* SCON: mode 1, 8-bit UART, enable rcvr */
  TMOD = 0x21;  /* TMOD: timer 1, mode 2, 8-bit reload */
  if(GPS_SPD)
   TH1 = 0xfa;   /* TH1: reload value for 9600 baud @ 11.059MHz */
   TH1 = 0xfd;   /* TH1: reload value for 4800 baud @ 11.059MHz */
  TR1 = 1;   /* TR1: timer 1 run */
  LCD_init(8);  //初始化LCD
  LCD_write_string(0,0," GPS SIRF II 2 ");
  LCD_write_string(0,1," 11-11-23 1342 ");
  for(i=1;i<4;i++)
   delayms(250);
  //LCD_cls();
  IE=0x90;   //开总中断、串口中断
   //串口接收中断
  void uart(void) interrupt 4
  unsigned char tmp;
  if(RI)
   tmp=SBUF;
   switch(tmp)
     case '$':
     cmd_number=0;  //命令类型清空
     mode=1;    //接收命令模式
     byte_count=0;  //接收位数清空
     break;
     case ',':
     seg_count++;  //逗号计数加1
     byte_count=0;
     break;
     case '*':
     switch(cmd_number)
     case 1:
     buf_full|=0x01;
     break;
     case 2:
     buf_full|=0x02;
     break;
     case 3:
     buf_full|=0x04;
     break;
     mode=0;
     break;
     default:
     if(mode==1)
  {      //命令种类判断
       cmd[byte_count]=tmp;   //接收字符放入类型缓存
       if(byte_count>=4)
  {    //如果类型数据接收完毕,判断类型
       if(cmd[0]=='G')
       if(cmd[1]=='P')
       if(cmd[2]=='G')
       if(cmd[3]=='G')
       if(cmd[4]=='A')
       cmd_number=1;
       mode=2;
       seg_count=0;
       byte_count=0;
   if(cmd[3]=='S')
   if(cmd[4]=='V')
       cmd_number=2;
       mode=2;
       seg_count=0;
       byte_count=0;
   if(cmd[2]=='R')
   if(cmd[3]=='M')
   if(cmd[4]=='C')
      cmd_number=3;
      mode=2;
      seg_count=0;
      byte_count=0;
      else if(mode==2)
     //接收数据处理
      switch (cmd_number)
      case 1:    //类型1数据接收。GPGGA
      switch(seg_count)
      case 2:  //纬度处理
      if(byte_count<9)
      WD[byte_count]=tmp;
      break;
      case 3:  //纬度方向处理
      if(byte_count<1)
      WD_a=tmp;
      break;
      case 4:  //经度处理
      if(byte_count<10)
      JD[byte_count]=tmp;
      break;
      case 5:  //经度方向处理
    if(byte_count<1)
    JD_a=tmp;
    break;
    case 6:  //定位判断
    if(byte_count<1)
    lock=tmp;
    break;
    case 7:  //定位使用的卫星数
    if(byte_count<2)
     use_sat[byte_count]=tmp;
     break;
     case 9:  //高度处理
     if(byte_count<6)
     high[byte_count]=tmp;
     break;
     break;
     case 2:    //类型2数据接收。GPGSV
     switch(seg_count)
     case 3:  //天空中的卫星总数
     if(byte_count<2)
     total_sat[byte_count]=tmp;
     break;
     break;
     case 3:    //类型3数据接收。GPRMC
     switch(seg_count)
     case 1:  //时间处理
     if(byte_count<6)
     time[byte_count]=tmp;
     break;
     case 2:  //定位判断
     if(byte_count<1)
     if (tmp=='A')
    lock=1;
     lock=0;
     break;
     case 3:  //纬度处理
     if(byte_count<9)
     WD[byte_count]=tmp;
          break;
         case 4:  //纬度方向处理
                 if(byte_count<1)
          WD_a=tmp;
         break;
         case 5:  //经度处理
                 if(byte_count<10)
         JD[byte_count]=tmp;
         break;
         case 6:  //经度方向处理
                 if(byte_count<1)
           JD_a=tmp;
          break;
         case 7:  //速度处理
if(byte_count<5)
          speed[byte_count]=tmp;
                                          break;
        case 8:  //方位角处理
                 if(byte_count<5)
          angle[byte_count]=tmp;
          break;
         case 9:  //方位角处理
                 if(byte_count<6)
          date[byte_count]=tmp;
               break;
        break;
      byte_count++;  //接收数位加1
      break;
  RI=0;
收藏收藏3 分享淘帖 顶 踩
ID:161933 发表于 2017-5-16 22:06 | 只看该作者
51单片机处理GPS模块及LCD1602 [复制链接]
ID:315748 发表于 2018-4-26 15:47 | 只看该作者
沙发沙发  前排
ID:232391 发表于 2018-4-26 16:56 | 只看该作者
沙发沙发  前排
ID:371527 发表于 2018-7-14 17:10 | 只看该作者
51单片机处理GPS模块及LCD1602 最大速度处理部分加上设置上限好些
ID:289865 发表于 2020-5-13 13:57 | 只看该作者
好啊好啊
