查看: 513|回复: 7
STC8H8K64U单片机LCD1602做的电压表数字一直在变化怎么回事?
回帖奖励 40 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
#include <STC8h.H>
#include <stdio.h>
#include <intrins.h>
sbit RS = P2^4;   //定义LCD1602端口
sbit RW = P2^5;
sbit EN = P2^6;
#define DataPort P0
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
void delay(unsigned int ms)    //@11.0592MHz
    unsigned char i, j;
   while(ms--)
    i = 15;
    j = 90;
    do
        while (--j);
    } while (--i);
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
delay(1);
EN_SET;
delay(1);
return (bit)(DataPort & 0x80);
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙则等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
delay(1);
EN_CLR;
delay(1);
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
delay(1);
EN_CLR;
delay(1);
void LCD_Clear(void)
LCD_Write_Com(0x01);
delay(5);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
  LCD_Write_Com(0x80 + x);     //表示第一行
  LCD_Write_Com(0xC0 + x);      //表示第二行
while ((*s)!='\0')
LCD_Write_Data( *s);
s ++;
void LCD_Init(void)
LCD_Write_Com(0x38);    /*显示模式设置*/
delay(5);
delay(5);
delay(5);
LCD_Write_Com(0x08);    /*显示关闭*/
LCD_Write_Com(0x01);    /*显示清屏*/
LCD_Write_Com(0x06);    /*显示光标移动设置*/
delay(5);
LCD_Write_Com(0x0C);    /*显示开及光标设置*/
void DisplayVoltage(float voltage)
    unsigned char str[16];
    sprintf(str,"Voltage: %.2fV",voltage);
    LCD_Write_Com(0x80);
    LCD_Write_String(0,0,str);
void ADC_Init(void)
    ADC_CONTR |= 0x80;     //AD上电
    ADCTIM = 0x3f;         //设置ADC内部时序
    ADC_CONTR &= 0x7f;     //AD断电
    ADCCFG = 0x2f;         //设置ADC时钟为系统时钟/2/16,12位结果右对齐
    ADC_CONTR = 0x80;      //使能ADC模块上电
    delay(4);
    ADC_CONTR |= 0x01;     //选P01作为AD输入
uint ADC_Read()
    ADC_CONTR |= 0x40;                          //启动AD转换
    delay(2);
    while ((ADC_CONTR & 0x20)==0);                //查询ADC完成标志
    ADC_CONTR &= ~0x20;                         //清完成标志
    return ADC_RES << 8 | ADC_RESL;         //返回12位ADC结果
void main(void)
    P0M0=0;
    P0M1=0;
    P2M0=0;
    P2M1=0;
    LCD_Init();
    LCD_Clear();//清屏
    ADC_Init();
    delay(3);
    while (1)
        unsigned int rawVoltage = ADC_Read();
        float voltage = (rawVoltage * 5.0) / 4095; // 假设参考电压是5V
        DisplayVoltage(voltage);
        delay(900);
在测量时有点电压(不管是0.5v还是3.3v)就直接显示5V,不进行测量时读数在0~5v之间一直变化。程序有什么错误?指教指教!
收藏收藏2 分享淘帖 顶 踩
ID:41656 发表于 2024-3-8 19:12 | 只看该作者
需要把ADC的输入端口IO模式设置为高阻模式,你全部初始化准双向模式肯定读取不正常的
ID:712097 发表于 2024-3-8 19:43 | 只看该作者
多次重复读取后累加,再取平均值。
ID:213173 发表于 2024-3-8 21:34 | 只看该作者
几mV的跳动是正常的,把此示例端口按实际电路改一下即可。
  1. #include "STC8H.H"
  2. #include "intrins.h"
  3. #define uint unsigned int
  5. #define ulong unsigned long
  6. #define LCD1602_DB P4
  7. sbit  LCD1602_RS=P1^0;
  8. sbit  LCD1602_RW=P1^1;
  9. sbit  LCD1602_EN=P1^2;
  10. uchar data dis_buf[]="VCC=0.000VVIN=0.000V";
  11. int *BGV;//内部1.19V参考信号源值
  12. uint res;//读取内部第15通道ADC结果
  13. uint VCC;//电源电压
  14. uint VCA;//缓冲
  15. uint Vin;//被测电压
  16. uint VADC;//ADC转换结果
  17. uint count;//计数
  18. bit flag;//T0中断标志
  19. void Delay_ms(unsigned int t)        //@11.0592MHz
  20. {
  21.         unsigned char data i, j;
  22.         while (t--)
  23.         {
  24.                 i = 15;
  25.                 j = 90;
  26.                 do
  27.                 {
  28.                         while (--j);
  29.                 } while (--i);
  30.         }
  31. }
  32. //初始化ADC
  33. void ADC_Init(void)
  34. {
  35.         P_SW2 |= 0x80;
  36.         ADCTIM = 0x3f;         //设置ADC内部时序
  37.         P_SW2 &= 0x7f;
  38.         ADCCFG = 0x2f;         //设置ADC时钟为系统时钟/2/16,12位结果右对齐
  39.         ADC_CONTR = 0x80;      //使能ADC模块
  40. }
  41. //读取ADC结果
  42. uint ADC_Read(uchar ch)
  43. {
  44.         ADC_CONTR = ch;                          //启动AD转换
  45.         _nop_();
  46.         _nop_();
  47.         while (!(ADC_CONTR & 0x20));                //查询ADC完成标志
  48.         ADC_CONTR &= ~0x20;                         //清完成标志
  49.         return ADC_RES << 8 | ADC_RESL;         //返回12位ADC结果
  50. }
  51. void Timer0_Init(void)                //10毫秒@11.0592MHz
  52. {
  53.         AUXR &= 0x7F;                        //定时器时钟12T模式
  54.         TMOD &= 0xF0;                        //设置定时器模式
  55.         TL0 = 0x00;                                //设置定时初始值
  56.         TH0 = 0xDC;                                //设置定时初始值
  57.         TF0 = 0;                                //清除TF0标志
  58.         TR0 = 1;                                //定时器0开始计时
  59.         ET0 = 1;                                //使能定时器0中断
  60.         EA  = 1;                          //使能总中断
  61. }
  62. void Read_Busy()           //忙检测函数,判断bit7是 0执行 1禁止
  63. {
  64.         unsigned char sta;      //
  65.         LCD1602_DB = 0xff;
  66.         LCD1602_RS = 0;
  67.         LCD1602_RW = 1;
  68.         do
  69.         {
  70.                 LCD1602_EN = 1;
  71.                 sta = LCD1602_DB;
  72.                 LCD1602_EN = 0;    //使能
  73.         }while(sta & 0x80);
  74. }
  75. void Lcd1602_Write_Cmd(unsigned char cmd)     //写命令
  76. {
  77.         Read_Busy();//忙检测函数,判断bit7是 0执行 1禁止
  78.         LCD1602_RS = 0;//RS数据命令选择RS=1数据 RS=0命令
  79.         LCD1602_RW = 0;//读写选择 RW=1读取 RW=0写
  80.         LCD1602_EN = 1;//使能预备
  81.         LCD1602_DB = cmd;//送命令
  82.         NOP20();
  83.         LCD1602_EN = 0; //下降沿使能
  84. }
  85. void Lcd1602_Write_Data(unsigned char dat)   //写数据
  86. {
  87.         Read_Busy();//忙检测函数,判断bit7是 0执行 1禁止
  88.         LCD1602_RS = 1;//RS数据命令选择RS=1数据 RS=0命令
  89.         LCD1602_RW = 0;//读写选择 RW=1读取 RW=0写
  90.         LCD1602_EN = 1;//使能预备
  91.         LCD1602_DB = dat;//送数据
  92.         NOP20();
  93.         LCD1602_EN = 0; //下降沿使能
  94. }
  95. void InitLcd1602()              //1602初始化 共5组初始化寄存器
  96. {
  97.         LCD1602_RS = 0;
  98.         LCD1602_RW = 0;
  99.         LCD1602_EN = 0;
  100.         Lcd1602_Write_Cmd(0x38);    //打开,5*8,8位数据   00111000
  101.         Lcd1602_Write_Cmd(0x0c);    //00001100后三位表示 开显示 不显光标 光标不闪烁
  102.         Lcd1602_Write_Cmd(0x06);    //00000110   //写一个字符后地址指针加一
  103.         Lcd1602_Write_Cmd(0x01);    //清屏
  104. }
  105. void main()
  106. {
  107.         uchar i;
  108.         P0M0 = 0x00;
  109.         P0M1 = 0x00;
  110.         P1M0 = 0x00;
  111.         P1M1 = 0x80;       //设置P1.7为高阻 ADC口
  112.         P2M0 = 0x00;
  113.         P2M1 = 0x00;
  114.         P3M0 = 0x00;
  115.         P3M1 = 0x00;
  116.         P4M0 = 0x00;
  117.         P4M1 = 0x00;
  118.         P5M0 = 0x00;
  119.         P5M1 = 0x00;
  120.         Delay_ms(100);//等待系统稳定
  121.         BGV = (int idata *)0xef;//内部1.19V参考信号源值
  122.         ADC_Init();//初始化ADC
  123.         Timer0_Init();//初始化定时器
  124.         InitLcd1602();//初始化1602
  125.         while (1)
  126.         {
  127.                 if(flag)
  128.                 {
  129.                         flag=0;
  130.                         ADC_Read(0xcf);//丢掉两次检测
  131.                         ADC_Read(0xcf);
  132.                         res=ADC_Read(0xcf);   //读取第15通道ADC结果
  133.                         VCC = (int)(4096L * *BGV / res);//计算电源电压
  134.                         ADC_Read(0xc7);//丢掉两次检测
  135.                         ADC_Read(0xc7);
  136.                         VADC=ADC_Read(0xc7);   //读取第7通道ADC结果
  137.                         Vin=VCC*(ulong)VADC/4096;//计算输入电压
  138.                         dis_buf[4]=VCC/1000%10+'0';//千位
  139.                         dis_buf[6]=VCC/100%10+'0';//百位
  140.                         dis_buf[7]=VCC/10%10+'0';//十位
  141.                         dis_buf[8]=VCC%10+'0';//个位
  142.                         dis_buf[14]=Vin/1000%10+'0';//千位
  143.                         dis_buf[16]=Vin/100%10+'0';//百位
  144.                         dis_buf[17]=Vin/10%10+'0';//十位
  145.                         dis_buf[18]=Vin%10+'0';//个位
  146.                         Lcd1602_Write_Cmd(0x80);//第一行
  147.                         for(i=0;i<10;i++)
  148.                                 Lcd1602_Write_Data(dis_buf[i]);
  149.                         Lcd1602_Write_Cmd(0x80+0x40);//第二行
  150.                         for(i=0;i<10;i++)
  151.                                 Lcd1602_Write_Data(dis_buf[i+10]);
  152.                 }
  153.         }
  154. }
  155. //
  156. void Timer0_Isr(void) interrupt 1
  157. {
  158.         flag=1;
  159. }
ID:143767 发表于 2024-3-9 10:11 | 只看该作者
应该是AD转换的问题
ID:1108299 发表于 2024-3-9 16:40 | 只看该作者
测不了,只显示VCC=0.000V VIN=0.000V。读数无变化
ID:712493 发表于 2024-3-9 16:57 | 只看该作者
lcd1602 字符显示数字  不是要加30?
ID:213173 发表于 2024-3-9 17:06 | 只看该作者
这只是示例程序,要根据你自己的实际电路修改端口定义。
