C51单片机通过I2C对EEPROM进行页读取的问题求助
查看数: 5543 | 评论数: 7 | 收藏 0
发布时间: 2018-11-13 07:58
我在尝试移植教材上的程序时,发现在页读取EEPROM时,第9位应答位假如直接置1或置0,就可以顺利读取,但由形参传递1或0给应答位时,就只能读到一串0,这是什么原因?
ID:111634 发表于 2018-11-14 08:23
实例49  读写AT24C02
ID:424091 发表于 2018-11-13 22:11
ahshmj 发表于 2018-11-13 15:53
怎么用图形贴出来,而不用文本格式呢?别人想试一试程序还要照图抄一遍?
大佬求帮忙看看
ID:424091 发表于 2018-11-13 17:39
----------------------------------------------------------------主函数
#include <reg52.h>
#define u8 unsigned char
#define u16 unsigned int
extern void Int_Lcd();
extern void Lcd_Show(u8 x,u8 y,u8 *set);
extern void EE_Read(u8 *buf,u8 addr,u8 len);
extern void EE_Write(u8 *buf,u8 addr,u8 len);
void Str_Convert(u8 *str,u8 *src,u8 len);
        u8 buf[5]={5,2,8,6,1};
        u8 str[20];
        Int_Lcd();
//        EE_Write(buf,0x00,sizeof(buf));              //EEPROM写入
        EE_Read(buf,0x00,sizeof(buf));          //EEPROM读取
        Str_Convert(str,buf,sizeof(buf));       //字符串转化函数
        Lcd_Show(0,0,str);                      //1cd1602显示
        while(1);
        u8 tem;
        while(len--)
                tem=*src>>4;
                if(tem<=9)
                        *str++=tem+'0';
                        *str++=tem-10+'a';
                tem=*src&0x0f;
                if(tem<=9)
                        *str++=tem+'0';
                        *str++=tem-10+'a';
                *str++=' ';
                src++;
----------------------------------------------------------------LCD1602
#include <reg52.h>
#define LCD_DB P0
sbit LCD_RS=P2^6;
sbit LCD_RW=P2^5;
sbit LCD_E=P2^7;
void LCD_Wait_Ready()
        u8 sta;
        LCD_DB=0xff;
        LCD_RS=0;
        LCD_RW=1;
        do
                LCD_E=1;
                sta=LCD_DB;
                LCD_E=0;
        while(sta & 0x80);
void LCD_Write_Cmd(u8 cmd)
        LCD_Wait_Ready();
        LCD_RS=0;
        LCD_RW=0;
        LCD_DB=cmd;
        LCD_E=1;
        LCD_E=0;
void LCD_Write_Dat(u8 dat)
        LCD_Wait_Ready();
        LCD_RS=1;
        LCD_RW=0;
        LCD_DB=dat;
        LCD_E=1;
        LCD_E=0;
void Lcd_Set_Cursor(u8 x,u8 y)
        u8 addr;
        if(y==0)
                addr=0x00+x;
                addr=0x40+x;
        LCD_Write_Cmd(addr | 0x80);
void Lcd_Show(u8 x,u8 y,u8 *str)
        Lcd_Set_Cursor(x,y);
        while(*str!='\0')
                LCD_Write_Dat(*str++);
void Int_Lcd()
        LCD_Write_Cmd(0x38);
        LCD_Write_Cmd(0x0c);
        LCD_Write_Cmd(0x06);
        LCD_Write_Cmd(0x01);
----------------------------------------------------------------I2C
#include <reg52.h>
#include <intrins.h>
sbit SCL=P2^1;
sbit SDA=P2^0;
sbit LED1=P0^0;
sbit LED2=P0^1;
void Dealy()
        u8 i;
        for(i=0;i<10;i++)
                _nop_();
void I2C_Start()
        SDA=1;
        SCL=1;
        Dealy();
        SDA=0;
        Dealy();
        SCL=0;
        Dealy();
void I2C_Stop()
        SCL=0;
        SDA=0;
        Dealy();
        SCL=1;
        Dealy();
        SDA=1;
        Dealy();
bit I2C_Write(u8 dat)         //I2C写入
        bit ack;
        u8 mask;
        for(mask=0x80;mask>0;mask>>=1)
                if((mask & dat)==0)
                        SDA=0;
                        SDA=1;
                Dealy();
                SCL=1;
                Dealy();
                SCL=0;
                Dealy();
        SDA=1;
        Dealy();
        SCL=1;
        ack=SDA;
        Dealy();
        SCL=0;
        Dealy();
        return (~ack);
u8 I2C_Read(bit ack)         //I2C读取
        u8 dat,i;
        SDA=1;
        Dealy();             //延时10us
        for(i=0;i<8;i++)
                SCL=1;
                Dealy();
                dat<<=1;
                dat |= SDA;
                Dealy();
                SCL=0;
                Dealy();
        SDA=ack;     //SDA由形参ack控制
        Dealy();
        SCL=1;
        Dealy();
        SCL=0;
        Dealy();
        return dat;
u8 I2C_ReadACK()
        u8 dat,i;
        SDA=1;
        Dealy();         //延时10us
        for(i=0;i<8;i++)
                SCL=1;
                Dealy();
                dat<<=1;
                dat |= SDA;
                Dealy();
                SCL=0;
                Dealy();
        SDA=0;      //SDA直接置0
        Dealy();
        SCL=1;
        Dealy();
        SCL=0;
        Dealy();
        return dat;
u8 I2C_ReadNAK()
        u8 dat,i;
        SDA=1;
        Dealy();
        for(i=0;i<8;i++)
                SCL=1;
                Dealy();
                dat<<=1;
                dat |= SDA;
                Dealy();
                SCL=0;
                Dealy();
        SDA=1;       //SDA直接置1
        Dealy();
        SCL=1;
        Dealy();
        SCL=0;
        Dealy();
        return dat;
----------------------------------------------------------------EEPROM
#include <reg52.h>
extern void I2C_Start();
extern void I2C_Stop();
extern bit I2C_Write(u8 dat);
extern bit I2C_Read(bit ack);
extern u8 I2C_ReadACK();
extern u8 I2C_ReadNAK();
void EE_Read(u8 *buf,u8 addr,u8 len)       //EEPROM读取,len读取长度
        do
                I2C_Start();
                if(I2C_Write(0x50<<1))
                        break;
                I2C_Stop();
        while(1);
        I2C_Write(addr);            //写入读取的起始地址
        I2C_Start();
        I2C_Write((0x50<<1)|0x01);
        while(len>1)
                *buf++=I2C_Read(0);       //应答位置0
//                *buf++=I2C_ReadACK();
                len--;
        *buf=I2C_Read(1);           //应答位置1
//        *buf=I2C_ReadNAK();
        I2C_Stop();
void EE_Write(u8 *buf,u8 addr,u8 len)       //EEPROM写入
        while(len>0)
                do
                        I2C_Start();
                                break;
                        I2C_Stop();
                while(1);
                I2C_Write(addr);
                while(len>0)
                        I2C_Write(*buf++);
                        len--;
                        addr++;
                        if((addr&0x07)==0)
                                break;
                I2C_Stop();
额,好吧,我把程序列出来
ID:424091 发表于 2018-11-13 12:16
浮念 发表于 2018-11-13 11:02
你可以在论坛里面搜集一下,有很多现成的程序可以参考学习。要善用论坛的搜索功能。
程序上我没有太大的问题,这部分程序我也是移植后再自己重新编写了的,主要就是想不明白为啥直接置位可以,用形参置位就出问题了,形参置位和直接置位有啥区别吗?
