按一下按键数码管显示0到F的单片机程序 求帮助
查看数: 3572 | 评论数: 4 | 收藏 0
发布时间: 2018-12-5 20:49
#include<reg51.h> sbit k1=P1^1; unsigned int code shumaguan[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,      0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; void delay (unsigned ...
ID:442293 发表于 2018-12-8 18:14
Eureka!Eureka! 发表于 2018-12-8 17:23
动态显示
ID:442260 发表于 2018-12-8 17:23
舟舟 发表于 2018-12-5 20:52
怎么按一下让数字显示1再按一下显示2这样到F
  1. #include<reg51.h>
  2. sbit k1=P1^1;
  3. unsigned char P0;
  4. unsigned int code shumaguan[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  5.      0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  6. void delay(unsigned int times) //延迟1ms
  7. {
  8.         unsigned int i,j;
  9.         for(i=0;i<times;i++)
  10.         {for(j=0;j<124;j++);}
  11. }
  12. void main()
  13. {
  14.        unsigned char i;
  15.        while(1)
  16. {
  17.        if(k1==1)
  18.        {
  19.           while(k1);//k1仍在按下时间内空操作
  20.           P0=shumaguan[i];//按键松开瞬间执行端口赋值
ID:438858 发表于 2018-12-8 14:07
#include<reg52.h>
sbit led=P1^0;
sbit key=P3^0;
sbit sw=P3^6;
void Delay10ms();
        unsigned char temp=0xf0;
                if(sw==0)
                        Delay10ms();
                        if(sw==0)
                                temp++;
                                P2=temp;
                                while(!sw);         //等待按键释放
void Delay10ms()                //@11.0592MHz
        unsigned char i, j;
        i = 108;
        j = 145;
        do
                while (--j);
        } while (--i);
