电机控制专用国产32位单片机MM32SPIN360C规格书下载
查看数: 4651 | 评论数: 3 | 收藏 1
发布时间: 2020-11-30 15:13
灵动微电子是本土领先的通用32位MCU产品及解决方案供应商,提供MM32 MCU基于Arm Cortex-M系列内核200多个型号,MM32 MCU被广泛应用于工业、电机、家电、消费玩具、手机平板配件、医疗、交通出行、显示及交互等领域。 ...
ID:228452 发表于 2022-9-18 20:57
Motor-DK (MM32SPIN360C)
Input voltage range: 12V - 28V
Use 60V / 40A N-MOS tube x 6
Use built-in GBW 6MHz high-speed op amp x 3
MCU uses 5V power supply
Support with/without Hall, square wave/sine wave drive
Support 1 / 2 Shunt R three-phase current sampling
BEMF voltage feedback using ADC sampling
Support DC Bus voltage, total current measurement
Use MCU built-in comparator as overcurrent protection
With potentiometer speed regulation, LED and other functions
ID:228452 发表于 2022-9-18 20:46
Is there a code, the code to control the motor? "
https://gitee.com/seekfree/MM32SPIN360C_BLDC_Project
ID:462629 发表于 2021-3-12 10:16
有代码吗,控制电机的代码?
