关于51单片机四位数码管滚动显示0~9的程序问题
查看数: 2610 | 评论数: 4 | 收藏 0
发布时间: 2022-3-30 20:51
请教一下,为什么我在实物板子上能运行到了Protues仿真里却无法正常运行啊? 代码如下: #include <REGX52.H> unsigned char N[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; void Delay(uns ...
ID:1013716 发表于 2022-4-1 23:24
数码管是不显示 还是显示错误 建议静态测试一下 看你这程序是共阳管 P0=0xc0;P3=0xff;试试看.
ID:860248 发表于 2022-3-31 22:25
由於我用的是普中幵发板, 所以有少许修改, 並將显示做到無缝连续显示, 不会显 6789後马上变為0123
#include <REG52.H>
sbit LSA = P1^0;
sbit LSB = P1^1;
sbit LSC = P1^2;
unsigned char SMG[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xc0,0xf9,0xa4,0xb0};
void Delay(unsigned int xms)
    unsigned char i, j;
    while(xms--)
        i = 2;
        j = 239;
        do
            while (--j);
        } while (--i);
void led (unsigned char Location,Number)
    switch(Location)
        case 1: LSA = 0; LSB = 0; LSC = 0; break;
        case 2: LSA = 1; LSB = 0; LSC = 0; break;
        case 3: LSA = 0; LSB = 1; LSC = 0; break;
        case 4: LSA = 1; LSB = 1; LSC = 0; break;
    P0=~SMG[Number];
    Delay(1);
    P0=0x00;
    unsigned int i,j;
      i=0;
        for(i=0;i<10;i++)
            for(j=0;j<100;j++)
                        led(1,i+0);
                             led(2,i+1);
                        led(3,i+2);
                               led(4,i+3);
ID:123289 发表于 2022-3-31 08:45
P3_X是位,不是字节,用0、1;不要用FFH.
另外:走单步学会自己调试。
ID:161164 发表于 2022-3-30 23:40
P0有没有加上拉电阻?
