Bluetooth+Si4730+PT2313+TPA3116+Oled 128*64 30W*2多功能功放
查看数: 25431 | 评论数: 79 | 收藏 7
发布时间: 2022-9-6 11:19
Bluetooth5.0+Si4730+PT2313+TPA3116D2+Oled 128*64 +5Keys+编码旋转调节 30W*2多功能功放:*目前软件已经做到V3.0,硬件也改版到V3.0,业余玩下趣味多多 功能: 1,蓝牙功能(杰里等淘宝蓝牙音频模组Bluetooth5.0 ...
ID:401500 发表于 2026-4-1 15:32
麻烦楼主发一份资料学习学习,谢谢。331417493@qq.com
ID:67223 发表于 2025-9-19 08:32
烦请楼主发一份资料学习学习,谢谢。ahyanc@163.com
ID:113936 发表于 2024-9-14 19:03
楼主给我一份吧,谢谢! 1424376352@qq.com
ID:1116552 发表于 2024-8-29 15:36
楼主你好!发一份给我,谢谢。787158391@qq.com.
ID:1128503 发表于 2024-7-8 19:57
2186721554@qq,com拜托楼主发我一份,谢谢谢谢
ID:1112147 发表于 2024-7-1 21:19
请发给我一份 谢谢。3403709449@qq.com
ID:813010 发表于 2024-3-19 09:01
烦请楼主也发一份给我学习学习。1927511197@QQ.COM。谢谢!
ID:1109705 发表于 2024-3-18 13:44
高手啊,学习下,都是手工焊接的吗?
ID:870445 发表于 2024-2-29 09:34
feeling1791 发表于 2022-9-19 14:40
有,告知邮箱发送给你
请发给我一份 谢谢,  xlxhtz2468@sina.com
ID:651494 发表于 2024-2-22 10:54
南山车主 发表于 2024-2-22 00:59
楼主能否共享下si4730驱动程序
//Copright (c) 2021,FFT_Combo
//All rights reserved.
//名称: radio.h
//说明: si4730 gpio定义,函数声明
//作者: feeling1791
//日期: 2020-12-20
//版本: ver3.1
#ifndef __RADIO_H
#define __RADIO_H
#include "stm32f10x.h"
#include "sys.h"
//-----------------radio端口定义----------------
#define TU_SDA_OUT()  GPIOA->CRL&=0XFF0FFFFF;GPIOA->CRL|=3<<20;   //输出PA5
#define TU_SDA_IN()   GPIOA->CRL&=0XFF0FFFFF;GPIOA->CRL|=8<<20;   //输入PA5
#define TU_SCL_OUT()  GPIOA->CRL&=0XF0FFFFFF;GPIOA->CRL|=3<<24;   //输出PA6
#define TU_SCL_IN()   GPIOA->CRL&=0XF0FFFFFF;GPIOA->CRL|=8<<24;   //输入PA6
#define TU_SDA_H PAout(5) = 1
#define TU_SDA_L PAout(5) = 0
#define TU_SCL_H PAout(6) = 1
#define TU_SCL_L PAout(6) = 0
#define TU_SDA_read PAin(5)
#define TU_SCL_read PAin(6)
#define TU_RST_H GPIOA->BSRR = GPIO_Pin_7
#define TU_RST_L GPIOA->BRR  = GPIO_Pin_7
#define TU_EN_H GPIOA->BSRR = GPIO_Pin_1
#define TU_EN_L GPIOA->BRR  = GPIO_Pin_1
#define TU_POWER_OFF() GPIOA->BSRR  = GPIO_Pin_1  //HIGH RX_HARD_MUTE
#define TU_POWER_ON()  GPIOA->BRR   = GPIO_Pin_1  //LOW
typedef and function claim
typedef enum OPERA_MODE {
    READ = 1,
    WRITE = 2
} T_OPERA_MODE;
typedef enum ERROR_OP {
    OK = 1,
    I2C_ERROR = 2,
    LOOP_EXP_ERROR = 3,
    G_ERROR = 4
} T_ERROR_OP;
typedef enum POWER_UP_TYPE {
    FM_RECEIVER = 1,
    AM_RECEIVER = 2
} T_POWER_UP_TYPE;
typedef enum SEEK_MODE {
    SEEKDOWN_HALT = 1,
    SEEKDOWN_WRAP = 2,
    SEEKUP_HALT = 3,
    SEEKUP_WRAP = 4
} T_SEEK_MODE;
typedef enum RX_ANTENNA_SELECT {
    EXTERNAL_ANTENNA = 1,
    INTERNAL_ANTENNA = 2
} T_RX_ANTENNA_SELECT;
//低灵敏度 FM_SNR 5   FM_RSSI 30                        //电台识别率高,但是搜台少
//中灵敏度 FM_SNR 3   FM_RSSI 15                        //电台识别率中,但是搜台一般
//高灵敏度 FM_SNR 2   FM_RSSI 8                         //电台识别率地,但是搜台多
#define FM_SNR_LOCAL 0x0005                                                           //FM SNR 5dB
#define FM_RSSI_LOCAL 0x0000F                                            //FM RSSI 15dBuV
#define FM_SNR_REMOTE 0x0002                                                    //FM SNR 2dB
#define FM_RSSI_REMOTE 0x0008                                            //FM RSSI 8dBuV
//#define FM_SNR_LOCAL 0x0005                                                            //FM SNR 5dB
//#define FM_RSSI_LOCAL 0x00019                                            //FM RSSI 25dBuV
//#define FM_SNR_REMOTE 0x0003                                                    //FM SNR 3dB
//#define FM_RSSI_REMOTE 0x000a                                            //FM RSSI 10dBuV
#define MW_SNR_LOCAL        0x0005                                                //MW SNR normal=5dB
#define MW_RSSI_LOCAL 0x0019                                                //MW_RSSI normal=25dBuV
#define MW_SNR_REMOTE        0x0003                                                //MW SNR normal=3dB
#define MW_RSSI_REMOTE 0x000a                                                //MW_RSSI normal=10dBuV
//#define SW_SNR_LOCAL        0x0005                                                //SW_SNR normal=5dB
//#define SW_RSSI_LOCAL 0x0014                                                //SW_RSSI normal=20dBuV
//#define SW_SNR_REMOTE        0x0002                                                //SW_SNR normal=2dB
//#define SW_RSSI_REMOTE 0x0008                                                //SW_RSSI normal=8dBuV
#define FM_Deemphasis        0x0001                                         //去加重设置 50us
#define FM_BLEND_STEREO                0x001e                                        //FM_BLEND_STEREO_THRESHOLD 20 dBuV RSSI高于设定阈值时开启立体声模式
#define FM_BLEND_MONO                        0x001e                                        //FM_BLEND_MONO_THRESHOLD 20 dBuV        RSSI低于于设定阈值时开启混音模式
//#define FM_BLEND_STEREO                0x0000                                        //FM_BLEND_STEREO_THRESHOLD 强制开启立体声模式
//#define FM_BLEND_MONO                        0x0000                                        //FM_BLEND_MONO_THRESHOLD 强制开启混音模式
#define FM_bandwidth                                0x000a                                        //bandwidth 100KHz
#define FM_BAND_TOP_VALUE                                 0x2a26                                  //107.9MHz
#define FM_BAND_BOTTOM_VALUE                 0x222E                                         //87.5MHz
//#define FM_BAND_BOTTOM_VALUE                 0x1db0                                         //76MHz
#define FM_BAND_BOTTOM_XY_VALUE 0x1900                                         //64MHz
#define FM_AutoScan_Step_VALUE        0x000a                                        //亚洲FM步进100K
#define FM_ManualScan_Step_VALUE        0x000a                                        //手动搜台步进10
#define AM_Deemphasis                 0x0001                                         //去加重设置 50us
#define AM_bandwidth                        0x0003                                        //bandwidth 2KHz
#define SW_BAND_TOP_VALUE                                0x59d8                                  //23000KHz
//#define SW_BAND_BOTTOM 0x08fc        //2300KHz
#define SW_BAND_BOTTOM_VALUE                 0x06af                                         //1711KHz 1711KHz -1800KHz 导航和定位信号        1800KHz-2000KHz 160米业务无线电        2000KHz-2300KHz 海事通讯
#define SW_AutoScan_Step_VALUE        0x0005                                        //亚洲SW步进5K
#define SW_ManualScan_Step_VALUE        0x0005                                        //手动搜台步进10
#define MW_BAND_TOP_VALUE                                 0x06b9                                  //1721KHz
#define MW_BAND_BOTTOM_VALUE                 0x020a                                         //522KHz
#define MW_AutoScan_Step_VALUE        0x0009                                        //亚洲MW步进9K
#define MW_ManualScan_Step_VALUE        0x0009                                        //手动搜台步进9
#define DefaultVOL 55                                //开机默认音量
#define MidVOL 50                                                //中等音量
#define MaxVOL 63                                                //最大音量
#define FMDefaultFREQ 10080        //开机默认频率
#define MWDefaultFREQ 792                //开机默认频率
//#define SWDefaultFREQ 6110        //开机默认频率
// General Commands
#define STCINT          0x01
#define ASQINT          0x02
#define RDSINT          0x04
#define RSQINT          0x08
#define ERR             0x40
#define CTS             0x80
// POWER_UP
#define POWER_UP                        0x01
#define POWER_UP_IN_FUNC_FMRX                 0xd0
#define POWER_UP_IN_FUNC_AMRX                 0x01
#define POWER_UP_IN_FUNC_FMTX                 0x02
#define POWER_UP_IN_FUNC_WBRX                 0x03
#define POWER_UP_IN_FUNC_QUERY                0x0F
#define POWER_UP_IN_PATCH                             0x20
#define POWER_UP_IN_GPO2OEN                   0x40
#define POWER_UP_IN_CTSIEN                            0x80
#define POWER_UP_IN_OPMODE_RX_ANALOG  0x05
#define POWER_UP_IN_OPMODE_TX_ANALOG  0x50
// GET_REV
#define GET_REV 0x10
// POWER_DOWN
#define POWER_DOWN 0x11
// SET_PROPERTY
#define SET_PROPERTY 0x12
// GET_PROPERTY
#define GET_PROPERTY 0x13
// GET_INT_STATUS
#define GET_INT_STATUS 0x14
// FM Receive Commands
// FM_TUNE_FREQ
#define FM_TUNE_FREQ 0x20
// FM_SEEK_START
#define FM_SEEK_START           0x21
#define FM_SEEK_START_IN_WRAP   0x04
#define FM_SEEK_START_IN_SEEKUP 0x08
// FM_TUNE_STATUS
#define FM_TUNE_STATUS           0x22
#define FM_TUNE_STATUS_IN_INTACK 0x01
#define FM_TUNE_STATUS_IN_CANCEL 0x02
#define FM_TUNE_STATUS_OUT_VALID 0x01
#define FM_TUNE_STATUS_OUT_AFCRL 0x02
#define FM_TUNE_STATUS_OUT_BTLF  0x80
// FM_RSQ_STATUS
#define FM_RSQ_STATUS              0x23
#define FM_RSQ_STATUS_IN_INTACK    0x01
#define FM_RSQ_STATUS_OUT_RSSILINT 0x01
#define FM_RSQ_STATUS_OUT_RSSIHINT 0x02
#define FM_RSQ_STATUS_OUT_ASNRLINT 0x04
#define FM_RSQ_STATUS_OUT_ASNRHINT 0x08
#define FM_RSQ_STATUS_OUT_BLENDINT 0x80
#define FM_RSQ_STATUS_OUT_VALID    0x01
#define FM_RSQ_STATUS_OUT_AFCRL    0x02
#define FM_RSQ_STATUS_OUT_SMUTE    0x08
#define FM_RSQ_STATUS_OUT_PILOT    0x80
#define FM_RSQ_STATUS_OUT_STBLEND  0x7F
// FM_RDS_STATUS
#define FM_RDS_STATUS               0x24
#define FM_RDS_STATUS_IN_INTACK     0x01
#define FM_RDS_STATUS_IN_MTFIFO     0x02
#define FM_RDS_STATUS_OUT_RECV      0x01
#define FM_RDS_STATUS_OUT_SYNCLOST  0x02
#define FM_RDS_STATUS_OUT_SYNCFOUND 0x04
#define FM_RDS_STATUS_OUT_SYNC      0x01
#define FM_RDS_STATUS_OUT_GRPLOST   0x04
#define FM_RDS_STATUS_OUT_BLED      0x03
#define FM_RDS_STATUS_OUT_BLEC      0x0C
#define FM_RDS_STATUS_OUT_BLEB      0x30
#define FM_RDS_STATUS_OUT_BLEA      0xC0
#define FM_RDS_STATUS_OUT_BLED_SHFT 0
#define FM_RDS_STATUS_OUT_BLEC_SHFT 2
#define FM_RDS_STATUS_OUT_BLEB_SHFT 4
#define FM_RDS_STATUS_OUT_BLEA_SHFT 6
// AM Receive Commands
// AM_TUNE_FREQ
#define AM_TUNE_FREQ 0x40
// AM_SEEK_START
#define AM_SEEK_START           0x41
#define AM_SEEK_START_IN_WRAP   0x04
#define AM_SEEK_START_IN_SEEKUP 0x08
// AM_TUNE_STATUS
#define AM_TUNE_STATUS           0x42
#define AM_TUNE_STATUS_IN_INTACK 0x01
#define AM_TUNE_STATUS_IN_CANCEL 0x02
#define AM_TUNE_STATUS_OUT_VALID 0x01
#define AM_TUNE_STATUS_OUT_AFCRL 0x02
#define AM_TUNE_STATUS_OUT_BTLF  0x80
// AM_RSQ_STATUS
#define AM_RSQ_STATUS              0x23
#define AM_RSQ_STATUS_IN_INTACK    0x01
#define AM_RSQ_STATUS_OUT_RSSILINT 0x01
#define AM_RSQ_STATUS_OUT_RSSIHINT 0x02
#define AM_RSQ_STATUS_OUT_ASNRLINT 0x04
#define AM_RSQ_STATUS_OUT_ASNRHINT 0x08
#define AM_RSQ_STATUS_OUT_VALID    0x01
#define AM_RSQ_STATUS_OUT_AFCRL    0x02
#define AM_RSQ_STATUS_OUT_SMUTE    0x08
// FM Transmit Commands
// TX_TUNE_FREQ
#define TX_TUNE_FREQ 0x30
// TX_TUNE_POWER
#define TX_TUNE_POWER 0x31
// TX_TUNE_MEASURE
#define TX_TUNE_MEASURE 0x32
// TX_TUNE_STATUS
#define TX_TUNE_STATUS           0x33
#define TX_TUNE_STATUS_IN_INTACK 0x01
// TX_ASQ_STATUS
#define TX_ASQ_STATUS             0x34
#define TX_ASQ_STATUS_IN_INTACK   0x01
#define TX_ASQ_STATUS_OUT_IALL    0x01
#define TX_ASQ_STATUS_OUT_IALH    0x02
#define TX_ASQ_STATUS_OUT_OVERMOD 0x04
// TX_RDS_BUFF
#define TX_RDS_BUFF           0x35
#define TX_RDS_BUFF_IN_INTACK 0x01
#define TX_RDS_BUFF_IN_MTBUFF 0x02
#define TX_RDS_BUFF_IN_LDBUFF 0x04
#define TX_RDS_BUFF_IN_FIFO   0x80
// TX_RDS_PS
#define TX_RDS_PS 0x36
// WB Receive Commands
// WB_TUNE_FREQ
#define WB_TUNE_FREQ 0x50
// WB_TUNE_STATUS
#define WB_TUNE_STATUS           0x52
#define WB_TUNE_STATUS_IN_INTACK 0x01
#define WB_TUNE_STATUS_OUT_VALID 0x01
#define WB_TUNE_STATUS_OUT_AFCRL 0x02
// WB_RSQ_STATUS
#define WB_RSQ_STATUS              0x53
#define WB_RSQ_STATUS_IN_INTACK    0x01
#define WB_RSQ_STATUS_OUT_RSSILINT 0x01
#define WB_RSQ_STATUS_OUT_RSSIHINT 0x02
#define WB_RSQ_STATUS_OUT_ASNRLINT 0x04
#define WB_RSQ_STATUS_OUT_ASNRHINT 0x08
#define WB_RSQ_STATUS_OUT_VALID    0x01
#define WB_RSQ_STATUS_OUT_AFCRL    0x02
// WB_ASQ_STATUS
#define WB_ASQ_STATUS                                        0x55
#define WB_ASQ_STATUS_IN_INTACK                        0x01
#define WB_ASQ_STATUS_OUT_ALERTONINT        0x01
#define WB_ASQ_STATUS_OUT_ALERTOFFINT        0x02
#define WB_ASQ_STATUS_OUT_ALERT                        0x01
//****************************Properties******************************/
// General Properties
// GPO_IEN
#define GPO_IEN                                0x0001
#define GPO_IEN_STCIEN_MASK 0x0001
#define GPO_IEN_ASQIEN_MASK 0x0002
#define GPO_IEN_RDSIEN_MASK 0x0004
#define GPO_IEN_RSQIEN_MASK 0x0008
#define GPO_IEN_ERRIEN_MASK 0x0040
#define GPO_IEN_CTSIEN_MASK 0x0080
#define GPO_IEN_STCREP_MASK 0x0100
#define GPO_IEN_ASQREP_MASK 0x0200
#define GPO_IEN_RDSREP_MASK 0x0400
#define GPO_IEN_RSQREP_MASK 0x0800
#define GPO_IEN_STCIEN_SHFT 0
#define GPO_IEN_ASQIEN_SHFT 1
#define GPO_IEN_RDSIEN_SHFT 2
#define GPO_IEN_RSQIEN_SHFT 3
#define GPO_IEN_ERRIEN_SHFT 6
#define GPO_IEN_CTSIEN_SHFT 7
#define GPO_IEN_STCREP_SHFT 8
#define GPO_IEN_ASQREP_SHFT 9
#define GPO_IEN_RDSREP_SHFT 10
#define GPO_IEN_RSQREP_SHFT 11
// DIGITAL_INPUT_FORMAT
#define DIGITAL_INPUT_FORMAT            0x0101
#define DIGITAL_INPUT_FORMAT_ISIZE_MASK 0x0003
#define DIGITAL_INPUT_FORMAT_IMONO_MASK 0x0004
#define DIGITAL_INPUT_FORMAT_IMODE_MASK 0x0078
#define DIGITAL_INPUT_FORMAT_IFALL_MASK 0x0080
#define DIGITAL_INPUT_FORMAT_ISIZE_SHFT 0
#define DIGITAL_INPUT_FORMAT_IMONO_SHFT 2
#define DIGITAL_INPUT_FORMAT_IMODE_SHFT 3
#define DIGITAL_INPUT_FORMAT_IFALL_SHFT 7
// DIGITAL_INPUT_SAMPLE_RATE
#define DIGITAL_INPUT_SAMPLE_RATE 0x0103
// DIGITAL_OUTPUT_FORMAT
#define DIGITAL_OUTPUT_FORMAT            0x0102
#define DIGITAL_OUTPUT_FORMAT_OSIZE_MASK 0x0003
#define DIGITAL_OUTPUT_FORMAT_OMONO_MASK 0x0004
#define DIGITAL_OUTPUT_FORMAT_OMODE_MASK 0x0078
#define DIGITAL_OUTPUT_FORMAT_OFALL_MASK 0x0080
#define DIGITAL_OUTPUT_FORMAT_OSIZE_SHFT 0
#define DIGITAL_OUTPUT_FORMAT_OMONO_SHFT 2
#define DIGITAL_OUTPUT_FORMAT_OMODE_SHFT 3
#define DIGITAL_OUTPUT_FORMAT_OFALL_SHFT 7
// DIGITAL_OUTPUT_SAMPLE_RATE
#define DIGITAL_OUTPUT_SAMPLE_RATE 0x0104
// REFCLK_FREQ
#define REFCLK_FREQ 0x0201
// REFCLK_PRESCALE
#define REFCLK_PRESCALE      0x0202
#define REFCLK_PRESCALE_MASK 0x0FFF
#define REFCLK_PRESCALE_SHFT 0
// FM Receive Properties
// FM_DEEMPHASIS
#define FM_DEEMPHASIS      0x1100
#define FM_DEEMPHASIS_MASK 0x0003
#define FM_DEEMPHASIS_SHFT 0
// FM_BLEND_STEREO_THRESHOLD
#define FM_BLEND_STEREO_THRESHOLD      0x1105
#define FM_BLEND_STEREO_THRESHOLD_MASK 0x007F
#define FM_BLEND_STEREO_THRESHOLD_SHFT 0
// FM_BLEND_MONO_THRESHOLD
#define FM_BLEND_MONO_THRESHOLD      0x1106
#define FM_BLEND_MONO_THRESHOLD_MASK 0x007F
#define FM_BLEND_MONO_THRESHOLD_SHFT 0
// FM_MAX_TUNE_ERROR
#define FM_MAX_TUNE_ERROR      0x1108
#define FM_MAX_TUNE_ERROR_MASK 0x007F
#define FM_MAX_TUNE_ERROR_SHFT 0
// FM_RSQ_INT_SOURCE
#define FM_RSQ_INT_SOURCE               0x1200
#define FM_RSQ_INT_SOURCE_RSSILIEN_MASK 0x0001
#define FM_RSQ_INT_SOURCE_RSSIHIEN_MASK 0x0002
#define FM_RSQ_INT_SOURCE_ASNRLIEN_MASK 0x0004
#define FM_RSQ_INT_SOURCE_ASNRHIEN_MASK 0x0008
#define FM_RSQ_INT_SOURCE_BLENDIEN_MASK 0x0080
#define FM_RSQ_INT_SOURCE_RSSILIEN_SHFT 0
#define FM_RSQ_INT_SOURCE_RSSIHIEN_SHFT 1
#define FM_RSQ_INT_SOURCE_ASNRLIEN_SHFT 2
#define FM_RSQ_INT_SOURCE_ASNRHIEN_SHFT 3
#define FM_RSQ_INT_SOURCE_BLENDIEN_SHFT 7
// FM_RSQ_SNR_HI_THRESHOLD
#define FM_RSQ_SNR_HI_THRESHOLD      0x1201
#define FM_RSQ_SNR_HI_THRESHOLD_MASK 0x007F
#define FM_RSQ_SNR_HI_THRESHOLD_SHFT 0
// FM_RSQ_SNR_LO_THRESHOLD
#define FM_RSQ_SNR_LO_THRESHOLD      0x1202
#define FM_RSQ_SNR_LO_THRESHOLD_MASK 0x007F
#define FM_RSQ_SNR_LO_THRESHOLD_SHFT 0
// FM_RSQ_RSSI_HI_THRESHOLD
#define FM_RSQ_RSSI_HI_THRESHOLD      0x1203
#define FM_RSQ_RSSI_HI_THRESHOLD_MASK 0x007F
#define FM_RSQ_RSSI_HI_THRESHOLD_SHFT 0
// FM_RSQ_RSSI_LO_THRESHOLD
#define FM_RSQ_RSSI_LO_THRESHOLD      0x1204
#define FM_RSQ_RSSI_LO_THRESHOLD_MASK 0x007F
#define FM_RSQ_RSSI_LO_THRESHOLD_SHFT 0
// FM_RSQ_BLEND_THRESHOLD
#define FM_RSQ_BLEND_THRESHOLD            0x1207
#define FM_RSQ_BLEND_THRESHOLD_BLEND_MASK 0x007F
#define FM_RSQ_BLEND_THRESHOLD_PILOT_MASK 0x0080
#define FM_RSQ_BLEND_THRESHOLD_BLEND_SHFT 0
#define FM_RSQ_BLEND_THRESHOLD_PILOT_SHFT 7
// FM_SOFT_MUTE_RATE
#define FM_SOFT_MUTE_RATE      0x1300
#define FM_SOFT_MUTE_RATE_MASK 0x00FF
#define FM_SOFT_MUTE_RATE_SHFT 0
// FM_SOFT_MUTE_MAX_ATTENUATION
#define FM_SOFT_MUTE_MAX_ATTENUATION      0x1302
#define FM_SOFT_MUTE_MAX_ATTENUATION_MASK 0x001F
#define FM_SOFT_MUTE_MAX_ATTENUATION_SHFT 0
// FM_SOFT_MUTE_SNR_THRESHOLD
#define FM_SOFT_MUTE_SNR_THRESHOLD      0x1303
#define FM_SOFT_MUTE_SNR_THRESHOLD_MASK 0x000F
#define FM_SOFT_MUTE_SNR_THRESHOLD_SHFT 0
// FM_SEEK_BAND_BOTTOM
#define FM_SEEK_BAND_BOTTOM 0x1400
// FM_SEEK_BAND_TOP
#define FM_SEEK_BAND_TOP 0x1401
// FM_SEEK_FREQ_SPACING
#define FM_SEEK_FREQ_SPACING      0x1402
#define FM_SEEK_FREQ_SPACING_MASK 0x001F
#define FM_SEEK_FREQ_SPACING_SHFT 0
// FM_SEEK_TUNE_SNR_THRESHOLD
#define FM_SEEK_TUNE_SNR_THRESHOLD      0x1403
#define FM_SEEK_TUNE_SNR_THRESHOLD_MASK 0x007F
#define FM_SEEK_TUNE_SNR_THRESHOLD_SHFT 0
// FM_SEEK_TUNE_RSSI_THRESHOLD
#define FM_SEEK_TUNE_RSSI_THRESHOLD      0x1404
#define FM_SEEK_TUNE_RSSI_THRESHOLD_MASK 0x007F
#define FM_SEEK_TUNE_RSSI_THRESHOLD_SHFT 0
// FM_RDS_INTERRUPT_SOURCE
#define FM_RDS_INTERRUPT_SOURCE                0x1500
#define FM_RDS_INTERRUPT_SOURCE_RECV_MASK      0x0001
#define FM_RDS_INTERRUPT_SOURCE_SYNCLOST_MASK  0x0002
#define FM_RDS_INTERRUPT_SOURCE_SYNCFOUND_MASK 0x0004
#define FM_RDS_INTERRUPT_SOURCE_RECV_SHFT      0
#define FM_RDS_INTERRUPT_SOURCE_SYNCLOST_SHFT  1
#define FM_RDS_INTERRUPT_SOURCE_SYNCFOUND_SHFT 2
// FM_RDS_INTERRUPT_FIFO_COUNT
#define FM_RDS_INTERRUPT_FIFO_COUNT      0x1501
#define FM_RDS_INTERRUPT_FIFO_COUNT_MASK 0x00FF
#define FM_RDS_INTERRUPT_FIFO_COUNT_SHFT 0
// FM_RDS_CONFIG
#define FM_RDS_CONFIG             0x1502
#define FM_RDS_CONFIG_RDSEN_MASK  0x0001
#define FM_RDS_CONFIG_BLETHD_MASK 0x0300
#define FM_RDS_CONFIG_BLETHC_MASK 0x0C00
#define FM_RDS_CONFIG_BLETHB_MASK 0x3000
#define FM_RDS_CONFIG_BLETHA_MASK 0xC000
#define FM_RDS_CONFIG_RDSEN_SHFT  0
#define FM_RDS_CONFIG_BLETHD_SHFT 8
#define FM_RDS_CONFIG_BLETHC_SHFT 10
#define FM_RDS_CONFIG_BLETHB_SHFT 12
#define FM_RDS_CONFIG_BLETHA_SHFT 14
// FM Transmit Properties
// TX_COMPONENT_ENABLE
#define TX_COMPONENT_ENABLE            0x2100
#define TX_COMPONENT_ENABLE_PILOT_MASK 0x0001
#define TX_COMPONENT_ENABLE_LMR_MASK   0x0002
#define TX_COMPONENT_ENABLE_RDS_MASK   0x0004
#define TX_COMPONENT_ENABLE_PILOT_SHFT 0
#define TX_COMPONENT_ENABLE_LMR_SHFT   1
#define TX_COMPONENT_ENABLE_RDS_SHFT   2
// TX_AUDIO_DEVIATION
#define TX_AUDIO_DEVIATION 0x2101
// TX_PILOT_DEVIATION
#define TX_PILOT_DEVIATION 0x2102
// TX_RDS_DEVIATION
#define TX_RDS_DEVIATION 0x2103
// TX_LINE_INPUT_LEVEL
#define TX_LINE_INPUT_LEVEL              0x2104
#define TX_LINE_INPUT_LEVEL_LILEVEL_MASK 0x03FF
#define TX_LINE_INPUT_LEVEL_LIATTEN_MASK 0x3000
#define TX_LINE_INPUT_LEVEL_LILEVEL_SHFT 0
#define TX_LINE_INPUT_LEVEL_LIATTEN_SHFT 12
// TX_LINE_INPUT_MUTE
#define TX_LINE_INPUT_MUTE             0x2105
#define TX_LINE_INPUT_MUTE_RIMUTE_MASK 0x0001
#define TX_LINE_INPUT_MUTE_LIMUTE_MASK 0x0002
#define TX_LINE_INPUT_MUTE_RIMUTE_SHFT 0
#define TX_LINE_INPUT_MUTE_LIMUTE_SHFT 1
// TX_PREEMPHASIS
#define TX_PREEMPHASIS     0x2106
#define TX_PREMPHASIS_MASK 0x0003
#define TX_PREMPHASIS_SHFT 0
// TX_PILOT_FREQUENCY
#define TX_PILOT_FREQUENCY 0x2107
// TX_ACOMP_ENABLE
#define TX_ACOMP_ENABLE              0x2200
#define TX_ACOMP_ENABLE_ACEN_MASK    0x0001
#define TX_ACOMP_ENABLE_LIMITEN_MASK 0x0002
#define TX_ACOMP_ENABLE_ACEN_SHFT    0
#define TX_ACOMP_ENABLE_LIMITEN_SHFT 1
// TX_ACOMP_THRESHOLD
#define TX_ACOMP_THRESHOLD 0x2201
// TX_ACOMP_ATTACK_TIME
#define TX_ACOMP_ATTACK_TIME      0x2202
#define TX_ACOMP_ATTACK_TIME_MASK 0x000F
#define TX_ACOMP_ATTACK_TIME_SHFT 0
// TX_ACOMP_RELEASE_TIME
#define TX_ACOMP_RELEASE_TIME      0x2203
#define TX_ACOMP_RELEASE_TIME_MASK 0x0007
#define TX_ACOMP_RELEASE_TIME_SHFT 0
// TX_ACOMP_GAIN
#define TX_ACOMP_GAIN      0x2204
#define TX_ACOMP_GAIN_MASK 0x003F
#define TX_ACOMP_GAIN_SHFT 0
// TX_LIMITER_RELEASE_TIME
#define TX_LIMITER_RELEASE_TIME 0x2205
// TX_ASQ_INT_SELECT
#define TX_ASQ_INT_SELECT                 0x2300
#define TX_ASQ_INT_SELECT_IALLIEN_MASK    0x0001
#define TX_ASQ_INT_SELECT_IALHIEN_MASK    0x0002
#define TX_ASQ_INT_SELECT_OVERMODIEN_MASK 0x0004
#define TX_ASQ_INT_SELECT_IALLIEN_SHFT    0
#define TX_ASQ_INT_SELECT_IALHIEN_SHFT    1
#define TX_ASQ_INT_SELECT_OVERMODIEN_SHFT 2
// TX_ASQ_LEVEL_LOW
#define TX_ASQ_LEVEL_LOW      0x2301
#define TX_ASQ_LEVEL_LOW_MASK 0x00FF
#define TX_ASQ_LEVEL_LOW_SHFT 0
// TX_ASQ_DURATION_LOW
#define TX_ASQ_DURATION_LOW 0x2302
// TX_ASQ_LEVEL_HIGH
#define TX_ASQ_LEVEL_HIGH      0x2303
#define TX_ASQ_LEVEL_HIGH_MASK 0x00FF
#define TX_ASQ_LEVEL_HIGH_SHFT 0
#define TX_ASQ_DURATION_HIGH 0x2304
// TX_RDS_INT_SOURCE
#define TX_RDS_INT_SOURCE               0x2C00
#define TX_RDS_INT_SOURCE_FIFOMT_MASK   0x0001
#define TX_RDS_INT_SOURCE_CBUFWRAP_MASK 0x0002
#define TX_RDS_INT_SOURCE_FIFOXMIT_MASK 0x0004
#define TX_RDS_INT_SOURCE_CBUFXMIT_MASK 0x0008
#define TX_RDS_INT_SOURCE_PSXMIT_MASK   0x0010
#define TX_RDS_INT_SOURCE_FIFOMT_SHFT   0
#define TX_RDS_INT_SOURCE_CBUFWRAP_SHFT 1
#define TX_RDS_INT_SOURCE_FIFOXMIT_SHFT 2
#define TX_RDS_INT_SOURCE_CBUFXMIT_SHFT 3
#define TX_RDS_INT_SOURCE_PSXMIT_SHFT   4
// TX_RDS_PI
#define TX_RDS_PI 0x2C01
// TX_RDS_PS_MIX
#define TX_RDS_PS_MIX      0x2C02
#define TX_RDS_PS_MIX_MASK 0x0007
#define TX_RDS_PS_MIX_SHFT 0
// TX_RDS_PS_MISC
#define TX_RDS_PS_MISC             0x2C03
#define TX_RDS_PS_MISC_RDSMS_MASK  0x0008
#define TX_RDS_PS_MISC_RDSTA_MASK  0x0010
#define TX_RDS_PS_MISC_RDSPTY_MASK 0x03E0
#define TX_RDS_PS_MISC_RDSTP_MASK  0x0400
#define TX_RDS_PS_MISC_FORCEB_MASK 0x0800
#define TX_RDS_PS_MISC_RDSD0_MASK  0x1000
#define TX_RDS_PS_MISC_RDSD1_MASK  0x2000
#define TX_RDS_PS_MISC_RDSD2_MASK  0x4000
#define TX_RDS_PS_MISC_RDSD3_MASK  0x8000
#define TX_RDS_PS_MISC_RDSMS_SHFT  3
#define TX_RDS_PS_MISC_RDSTA_SHFT  4
#define TX_RDS_PS_MISC_RDSPTY_SHFT 5
#define TX_RDS_PS_MISC_RDSTP_SHFT  10
#define TX_RDS_PS_MISC_FORCEB_SHFT 11
#define TX_RDS_PS_MISC_RDSD0_SHFT  12
#define TX_RDS_PS_MISC_RDSD1_SHFT  13
#define TX_RDS_PS_MISC_RDSD2_SHFT  14
#define TX_RDS_PS_MISC_RDSD3_SHFT  15
// TX_RDS_PS_REPEAT_COUNT
#define TX_RDS_PS_REPEAT_COUNT      0x2C04
#define TX_RDS_PS_REPEAT_COUNT_MASK 0x00FF
#define TX_RDS_PS_REPEAT_COUNT_SHFT 0
// TX_RDS_PS_MESSAGE_COUNT
#define TX_RDS_PS_MESSAGE_COUNT      0x2C05
#define TX_RDS_PS_MESSAGE_COUNT_MASK 0x000F
#define TX_RDS_PS_MESSAGE_COUNT_SHFT 0
// TX_RDS_PS_AF
#define TX_RDS_PS_AF 0x2C06
// TX_RDS_FIFO_SIZE
#define TX_RDS_FIFO_SIZE      0x2C07
#define TX_RDS_FIFO_SIZE_MASK 0x00FF
#define TX_RDS_FIFO_SIZE_SHFT 0
// AM Receive Properties
// AM_DEEMPHASIS
#define AM_DEEMPHASIS      0x3100
#define AM_DEEMPHASIS_MASK 0x0001
#define AM_DEEMPHASIS_SHFT 0
// AM_CHANNEL_FILTER
#define AM_CHANNEL_FILTER      0x3102
#define AM_CHANNEL_FILTER_MASK 0x0007
#define AM_CHANNEL_FILTER_SHFT 0
// AM_RSQ_INT_SOURCE
#define AM_RSQ_INTERRUPTS                                        0x3200                //Si473x
//#define AM_RSQ_INT_SOURCE               0x3200
#define AM_RSQ_INT_SOURCE_RSSILIEN_MASK 0x0001
#define AM_RSQ_INT_SOURCE_RSSIHIEN_MASK 0x0002
#define AM_RSQ_INT_SOURCE_ASNRLIEN_MASK 0x0004
#define AM_RSQ_INT_SOURCE_ASNRHIEN_MASK 0x0008
#define AM_RSQ_INT_SOURCE_RSSILIEN_SHFT 0
#define AM_RSQ_INT_SOURCE_RSSIHIEN_SHFT 1
#define AM_RSQ_INT_SOURCE_ASNRLIEN_SHFT 2
#define AM_RSQ_INT_SOURCE_ASNRHIEN_SHFT 3
// AM_RSQ_SNR_HI_THRESHOLD
#define AM_RSQ_SNR_HI_THRESHOLD      0x3201
#define AM_RSQ_SNR_HI_THRESHOLD_MASK 0x007F
#define AM_RSQ_SNR_HI_THRESHOLD_SHFT 0
// AM_RSQ_SNR_LO_THRESHOLD
#define AM_RSQ_SNR_LO_THRESHOLD      0x3202
#define AM_RSQ_SNR_LO_THRESHOLD_MASK 0x007F
#define AM_RSQ_SNR_LO_THRESHOLD_SHFT 0
// AM_RSQ_RSSI_HI_THRESHOLD
#define AM_RSQ_RSSI_HI_THRESHOLD      0x3203
#define AM_RSQ_RSSI_HI_THRESHOLD_MASK 0x007F
#define AM_RSQ_RSSI_HI_THRESHOLD_SHFT 0
// AM_RSQ_RSSI_LO_THRESHOLD
#define AM_RSQ_RSSI_LO_THRESHOLD      0x3204
#define AM_RSQ_RSSI_LO_THRESHOLD_MASK 0x007F
#define AM_RSQ_RSSI_LO_THRESHOLD_SHFT 0
// AM_SOFT_MUTE_RATE
#define AM_SOFT_MUTE_RATE 0x3300
// AM_SOFT_MUTE_SLOPE
#define AM_SOFT_MUTE_SLOPE 0x3301
#define AM_SOFT_MUTE_SLOPE_MASK 0x000F
#define AM_SOFT_MUTE_SLOPE_SHFT 0
// AM_SOFT_MUTE_MAX_ATTENUATION
#define AM_SOFT_MUTE_MAX_ATTENUATION 0x3302
#define AM_SOFT_MUTE_MAX_ATTENUATION_MASK 0x003F
#define AM_SOFT_MUTE_MAX_ATTENUATION_SHFT 0
// AM_SOFT_MUTE_SNR_THRESHOLD
#define AM_SOFT_MUTE_SNR_THRESHOLD 0x3303
#define AM_SOFT_MUTE_SNR_THRESHOLD_MASK 0x003F
#define AM_SOFT_MUTE_SNR_THRESHOLD_SHFT 0
// AM_SEEK_BAND_BOTTOM
#define AM_SEEK_BAND_BOTTOM 0x3400
// AM_SEEK_BAND_TOP
#define AM_SEEK_BAND_TOP 0x3401
// AM_SEEK_FREQ_SPACING
#define AM_SEEK_FREQ_SPACING      0x3402
#define AM_SEEK_FREQ_SPACING_MASK 0x000F
#define AM_SEEK_FREQ_SPACING_SHFT 0
// AM_SEEK_TUNE_SNR_THRESHOLD
//#define AM_SEEK_TUNE_SNR_THRESHOLD      0x3403                //Si474x
#define AM_SEEK_SNR_THRESHOLD                              0x3403                //Si473x
#define AM_SEEK_TUNE_SNR_THRESHOLD_MASK 0x003F
#define AM_SEEK_TUNE_SNR_THRESHOLD_SHFT 0
// AM_SEEK_TUNE_RSSI_THRESHOLD
//#define AM_SEEK_TUNE_RSSI_THRESHOLD      0x3404                //Si474x
#define AM_SEEK_RSSI_THRESHOLD      0x3404                //Si473x
#define AM_SEEK_TUNE_RSSI_THRESHOLD_MASK 0x003F
#define AM_SEEK_TUNE_RSSI_THRESHOLD_SHFT 0
// General Receive Properties
// RX_VOLUME
#define RX_VOLUME      0x4000
#define RX_VOLUME_MASK 0x003F
#define RX_VOLUME_SHFT 0
// RX_HARD_MUTE
#define RX_HARD_MUTE 0x4001
#define RX_HARD_MUTE_RMUTE_MASK 0x0001
#define RX_HARD_MUTE_LMUTE_MASK 0x0002
#define RX_HARD_MUTE_RMUTE_SHFT 0
#define RX_HARD_MUTE_LMUTE_SHFT 1
// Bit Definitions for Properties
// DIGITAL_MODE - used for input or output
#define DIGITAL_MODE_I2S    0x0
#define DIGITAL_MODE_LEFT   0x6
#define DIGITAL_MODE_MSB1ST 0xC
#define DIGITAL_MODE_MSB2ND 0x8
// DIGITAL_SIZE - used for input or output
#define DIGITAL_SIZE_16 0x0
#define DIGITAL_SIZE_20 0x1
#define DIGITAL_SIZE_24 0x2
#define DIGITAL_SIZE_8  0x3
// FM_DEEMPH
#define FM_DEEMPH_75US 0x2
#define FM_DEEMPH_50US 0x1
// FM_RDS_BLETH - used for all block error thresholds
#define FM_RDS_BLETH_NO_ERRORS     0x0
#define FM_RDS_BLETH_1OR2_ERRORS   0x1
#define FM_RDS_BLETH_3TO5_ERRORS   0x2
#define FM_RDS_BLETH_UNCORRECTABLE 0x3
// TX_LINE_INPUT_LEVEL_LIATTEN
#define TX_LINE_INPUT_LEVEL_LIATTEN_396kOhm 0x0000
#define TX_LINE_INPUT_LEVEL_LIATTEN_100kOhm 0x1000
#define TX_LINE_INPUT_LEVEL_LIATTEN_74kOhm  0x2000
#define TX_LINE_INPUT_LEVEL_LIATTEN_60kOhm  0x3000
// TX_DEEMPHASIS
#define TX_PREEMPHASIS_75US     0x0
#define TX_PREEMPHASIS_50US     0x1
#define TX_PREEMPHASIS_DISABLED 0x2
#define TX_ACOMP_ATTACK_TIME_0_5MS 0x0
#define TX_ACOMP_ATTACK_TIME_1_0MS 0x1
#define TX_ACOMP_ATTACK_TIME_1_5MS 0x2
#define TX_ACOMP_ATTACK_TIME_2_0MS 0x3
#define TX_ACOMP_ATTACK_TIME_2_5MS 0x4
#define TX_ACOMP_ATTACK_TIME_3_0MS 0x5
#define TX_ACOMP_ATTACK_TIME_3_5MS 0x6
#define TX_ACOMP_ATTACK_TIME_4_0MS 0x7
#define TX_ACOMP_ATTACK_TIME_4_5MS 0x8
#define TX_ACOMP_ATTACK_TIME_5_0MS 0x9
#define TX_ACOMP_RELEASE_TIME_100MS  0x0
#define TX_ACOMP_RELEASE_TIME_200MS  0x1
#define TX_ACOMP_RELEASE_TIME_350MS  0x2
#define TX_ACOMP_RELEASE_TIME_525MS  0x3
#define TX_ACOMP_RELEASE_TIME_1000MS 0x4
// TX_RDS_PS_MIX
#define TX_RDS_PS_MIX_FIFO_EMPTY 0x0
#define TX_RDS_PS_MIX_12_5_PCT   0x1
#define TX_RDS_PS_MIX_25_PCT     0x2
#define TX_RDS_PS_MIX_50_PCT     0x3
#define TX_RDS_PS_MIX_75_PCT     0x4
#define TX_RDS_PS_MIX_87_5_PCT   0x5
#define TX_RDS_PS_MIX_100_PCT    0x6
// TX_RDS_PS_MISC_PTY
#define TX_RDS_PS_MISC_PTY_NONE     0
#define TX_RDS_PS_MISC_PTY_NEWS     1
#define TX_RDS_PS_MISC_PTY_INFO     2
#define TX_RDS_PS_MISC_PTY_SPORTS   3
#define TX_RDS_PS_MISC_PTY_TALK     4
#define TX_RDS_PS_MISC_PTY_ROCK     5
#define TX_RDS_PS_MISC_PTY_CLROCK   6
#define TX_RDS_PS_MISC_PTY_ADHITS   7
#define TX_RDS_PS_MISC_PTY_SOFTROCK 8
#define TX_RDS_PS_MISC_PTY_TOP40    9
#define TX_RDS_PS_MISC_PTY_COUNTRY  10
#define TX_RDS_PS_MISC_PTY_OLDIES   11
#define TX_RDS_PS_MISC_PTY_SOFT     12
#define TX_RDS_PS_MISC_PTY_NOST     13
#define TX_RDS_PS_MISC_PTY_JAZZ     14
#define TX_RDS_PS_MISC_PTY_CLASS    15
#define TX_RDS_PS_MISC_PTY_RHYBLUES 16
#define TX_RDS_PS_MISC_PTY_SOFTRB   17
#define TX_RDS_PS_MISC_PTY_FGNLANG  18
#define TX_RDS_PS_MISC_PTY_RMUSIC   19
#define TX_RDS_PS_MISC_PTY_RTALK    20
#define TX_RDS_PS_MISC_PTY_PERS     21
#define TX_RDS_PS_MISC_PTY_PUBLIC   22
#define TX_RDS_PS_MISC_PTY_COLLEGE  23
#define TX_RDS_PS_MISC_PTY_UN24     24
#define TX_RDS_PS_MISC_PTY_UN25     25
#define TX_RDS_PS_MISC_PTY_UN26     26
#define TX_RDS_PS_MISC_PTY_UN27     27
#define TX_RDS_PS_MISC_PTY_UN28     28
#define TX_RDS_PS_MISC_PTY_WTHR     29
#define TX_RDS_PS_MISC_PTY_EMERTEST 30
#define TX_RDS_PS_MISC_PTY_ALERT    31
// AM_CHANNEL_FILTER_BW
#define AM_CHANNEL_FILTER_BW_6KHZ 0
#define AM_CHANNEL_FILTER_BW_4KHZ 1
#define AM_CHANNEL_FILTER_BW_3KHZ 2
#define AM_CHANNEL_FILTER_BW_2KHZ 3
// WB Receive Properties
// WB_MAX_TUNE_ERROR
#define WB_MAX_TUNE_ERROR      0x5108
// WB_VALID_SNR_THRESHOLD
#define WB_VALID_SNR_THRESHOLD      0x5403
#define WB_VALID_SNR_THRESHOLD_MASK 0x007F
#define WB_VALID_SNR_THRESHOLD_SHFT 0
// WB_VALID_RSSI_THRESHOLD
#define WB_VALID_RSSI_THRESHOLD      0x5404
#define WB_VALID_RSSI_THRESHOLD_MASK 0x007F
#define WB_VALID_RSSI_THRESHOLD_SHFT 0
#define FM_BAND                1
#define AM_BAND                2
#define IO2W_SENB0_ADDRESS 0x22
#define IO2W_SENB1_ADDRESS 0xC6
#define  SENB  0
#define DEMO_DELAY 5000
#define RDS_DELAY  30000
// Defines
#define IO3W    0
#define IO2W    1
#define MIN_FM_FREQ         8750
#define MAX_FM_FREQ         10800
#define FM_STEP         10
#define MIN_AM_FREQ         522
#define MAX_AM_FREQ         1620
#define AM_STEP         9
extern void TU_Init(void);
extern  T_ERROR_OP Si47XX_Power_Up(T_POWER_UP_TYPE power_up_type);
extern T_ERROR_OP Si47XX_Wait_STC(void);
extern void si47xx_set_property(unsigned int propNumber, unsigned int propValue);
extern void Si47XX_SetDSPPropertys(unsigned char IN_RxSensitivity);
extern void Si47XX_Power_OFF(void);
extern void ResetSi47XX_2w(void);
extern unsigned char OperationSi47XX_2w(T_OPERA_MODE operation, unsigned char *data1, unsigned char numBytes);
extern unsigned char si47xx_get_vol(void);
extern void si47xx_set_vol(unsigned char vol);
extern void si47xx_mute(unsigned char muteStaus);
extern T_ERROR_OP Si47XX_Set_FM_Frequency(unsigned short channel_freq);
extern unsigned int si47xx_command_TUNE_STATUS_Freq(unsigned char band);
extern unsigned char  si47xx_command_FM_SEEK_START_DOWN(void);
extern unsigned char  si47xx_command_FM_SEEK_START_UP(void);
#endif
//名称: radio.c
//说明: si4730驱动
//作者: feeling1791 (Wechat)
//日期: 2020-12-20
//版本: ver3.1
#include "radio.h"
#include "delay.h"
#include "display.h"
void TU_Init(void)
     GPIO_InitTypeDef  GPIO_InitStructure;
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5| GPIO_Pin_6;
            GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
     GPIO_Init(GPIOA, &GPIO_InitStructure);
     //GPIO_SetBits(GPIOA,GPIO_Pin_5);        //sda
            //GPIO_SetBits(GPIOA,GPIO_Pin_6);        //scl
     GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7 | GPIO_Pin_1 ;
     //GPIO_SetBits(GPIOA,GPIO_Pin_7);        //rst
            TU_POWER_OFF();//Tuner power control,Hight--->OFF,Low---> ON
// 设备上电,IC软开机
            unsigned short loop_counter = 0;
            unsigned char Si47XX_reg_data[32];
            unsigned char error_ind = 0;
            unsigned char Si47XX_power_up[] = {0x01,0xd0,0x05};
            ResetSi47XX_2w();
                   delay_ms(250);        //if use internal crystal, need wait 500ms, Si47XX_power_up[1] = 0x(5x)
            switch(power_up_type)
                       case FM_RECEIVER:
                                                Si47XX_power_up[1] = 0xd0;   //使用时钟晶振,32.768khz ,FM模式
                                                Si47XX_power_up[2] = 0x05;  ////模拟L/R输出
                                                break;
         case AM_RECEIVER:
        Si47XX_power_up[1] = 0xd1;
        break;
            //send CMD
            error_ind = OperationSi47XX_2w(WRITE, &(Si47XX_power_up[0]), 3);
            if(error_ind)
                             return I2C_ERROR;
            //wait CTS = 1
                                        do
        error_ind = OperationSi47XX_2w(READ, &(Si47XX_reg_data[0]), 1);
        if(error_ind)
        return I2C_ERROR;
        loop_counter++;
                                         while(((Si47XX_reg_data[0]) != 0x80) && (loop_counter < 0xff));  //loop_counter limit should guarantee at least 300us
                                         if(loop_counter >= 0xff)
                                                    return LOOP_EXP_ERROR;
                                         return OK;
Si47XX_Wait_STC(): wait STC = 1 (then clear it-removed)
            unsigned short loop_counter = 0, loop_counter_1 = 0;
            unsigned char Si47XX_get_int_status[] = {0x14};
                                        do
                                                    //send CMD
        error_ind = OperationSi47XX_2w(WRITE, &(Si47XX_get_int_status[0]), 1);
                                                           if(error_ind)
        return I2C_ERROR;
                                                           /* wait CTS = 1 and then wait STCINT = 1 */
        do
        if(error_ind)
        return I2C_ERROR;
        loop_counter_1++;
        while(((Si47XX_reg_data[0]&0x80) == 0) && (loop_counter_1 < 0xff));  //loop_counter limit should guarantee at least 300us
                                                           if(loop_counter_1 >= 0xff)
                                                    loop_counter_1 = 0;
                                                           /* wait CTS end */
                                                           if(error_ind)
        return I2C_ERROR;
                                                           loop_counter++;
                                        while(((Si47XX_reg_data[0]&0x01) == 0) && (loop_counter < 0xffff));  //loop_counter(0xffff) limit should guarantee at least: for FM,worst case = 60ms*((108-87.5)/0.1+1)= 12s to wait STC = 1
        //        for AM,worst case = 80ms*((1710-520)/9+1)= 11s to wait STC = 1
                                        if(loop_counter == 0xffff)
            return OK;
// 设置属性值(属性格式0x0000)
     unsigned char cmd[8]={0x00,0xd0,0x00,0x00,0x00,0x00,0x00,0x00};
           cmd[0] = SET_PROPERTY;
           // Initialize the reserved section to 0
     cmd[1] = 0;
           // Put the property number in the third and fourth bytes.
     cmd[2] = (unsigned char)(propNumber >> 8);
           cmd[3] = (unsigned char)(propNumber & 0x00FF);
           // Put the property value in the fifth and sixth bytes.
     cmd[4] = (unsigned char)(propValue >> 8);
     cmd[5] = (unsigned char)(propValue & 0x00FF);
     // Invoke the command
           OperationSi47XX_2w(WRITE,&cmd[0],6);
// 设备参数初始化(设置属性)
                   //设定中断   STCIEN
                   si47xx_set_property(GPO_IEN,0x00c9);
                   delay_ms(10);
                   //设定参考时钟 32768K
                   si47xx_set_property(REFCLK_FREQ,0x8000);
                   delay_ms(10);
                   //设定参考时钟分频 1分频
                   si47xx_set_property(REFCLK_PRESCALE,0x0001);
                   delay_ms(10);
                   //设定音量0~63
                   si47xx_set_property(RX_VOLUME,63);
                   delay_ms(10);
                   //设定左右声道静音
                   si47xx_set_property(RX_HARD_MUTE,0x0000);
                   delay_ms(10);
//FM调频属性设置
     //设定去加重50us 0x0001
     si47xx_set_property(FM_DEEMPHASIS,FM_Deemphasis);
     delay_ms(10);
     //设定FM_BLEND_STEREO_THRESHOLD 30 dBuV RSSI高于设定阈值时开启立体声模式
     si47xx_set_property(FM_BLEND_STEREO_THRESHOLD,FM_BLEND_STEREO);
     //设定FM_BLEND_STEREO_THRESHOLD 强制立体声 设置为0
     //si47xx_set_property(FM_BLEND_STEREO_THRESHOLD,0x0000);
     delay_ms(10);
     //设定FM_BLEND_MONO_THRESHOLD 30 dBuV        RSSI低于于设定阈值时开启混音模式
     si47xx_set_property(FM_BLEND_MONO_THRESHOLD,FM_BLEND_MONO);
     //设定FM_BLEND_MONO_THRESHOLD  强制立体声 设置为0
     //si47xx_set_property(FM_BLEND_MONO_THRESHOLD,0x0000);
     delay_ms(10);
     //设定FM_MAX_TUNE_ERROR        40 kHz
     si47xx_set_property(FM_MAX_TUNE_ERROR,0x0028);
     delay_ms(10);
     //设定FM_RSQ_INT_SOURCE Enable blend,Audio SNR high,Audio SNR low,RSSI high and RSSI low interrupts.
     si47xx_set_property(FM_RSQ_INT_SOURCE,0x008f);
     delay_ms(10);
     //设定FM_RSQ_SNR_HI_THRESHOLD        30dB
     si47xx_set_property(FM_RSQ_SNR_HI_THRESHOLD,0x001e);
     delay_ms(10);
     //设定FM_RSQ_SNR_LO_THRESHOLD        6dB
     si47xx_set_property(FM_RSQ_SNR_LO_THRESHOLD,0x0006);
     delay_ms(10);
     //设定FM_RSQ_RSSI_HI_THRESHOLD        50dBuV
     si47xx_set_property(FM_RSQ_RSSI_HI_THRESHOLD,0x0032);
     delay_ms(10);
     //设定FM_RSQ_RSSI_LO_THRESHOLD        24dBuV
     si47xx_set_property(FM_RSQ_RSSI_LO_THRESHOLD,0x0018);
     delay_ms(10);
     //设定FM_RSQ_BLEND_THRESHOLD        50%
     si47xx_set_property(FM_RSQ_BLEND_THRESHOLD,0x0032);
     delay_ms(10);
     //设定FM_SOFT_MUTE_MAX_ATTENUATION        10dB
     si47xx_set_property(FM_SOFT_MUTE_MAX_ATTENUATION,0x000a);
     delay_ms(10);
     //设定FM_SOFT_MUTE_SNR_THRESHOLD        6dB
     si47xx_set_property(FM_SOFT_MUTE_SNR_THRESHOLD,0x0006);
     delay_ms(10);
     //设定FM_SEEK_BAND_BOTTOM        8750(87.5M) 0x21fc
     si47xx_set_property(FM_SEEK_BAND_BOTTOM,FM_BAND_BOTTOM_VALUE);
     delay_ms(10);
     //设定FM_SEEK_BAND_TOP        10790 (107.9) 0x2a26
     si47xx_set_property(FM_SEEK_BAND_TOP,FM_BAND_TOP_VALUE);
     delay_ms(10);
     //设定FM_SEEK_FREQ_SPACING 100k 0x000a    100 kHz Spacing
     si47xx_set_property(FM_SEEK_FREQ_SPACING,FM_bandwidth);
     delay_ms(10);
     if(IN_RxSensitivity==0)
         //设定FM_SEEK_TUNE_SNR_THRESHOLD 2dBuV 0x0002
               si47xx_set_property(FM_SEEK_TUNE_SNR_THRESHOLD,FM_SNR_LOCAL);
               delay_ms(10);
               //设定FM_SEEK_TUNE_RSSI_THRESHOLD 8dBuV 0x0008
               si47xx_set_property(FM_SEEK_TUNE_RSSI_THRESHOLD,FM_RSSI_LOCAL);
               delay_ms(10);
               si47xx_set_property(FM_SEEK_TUNE_SNR_THRESHOLD,FM_SNR_REMOTE);
               delay_ms(10);
               si47xx_set_property(FM_SEEK_TUNE_RSSI_THRESHOLD,FM_RSSI_REMOTE);
               delay_ms(10);
//AM调频属性设置
     //设定AM_CHANNEL_FILTER (4kHz 0x0001)(6kHz 0x0000)(3kHz 0x0002)(2kHz 0x0003)
     si47xx_set_property(AM_CHANNEL_FILTER,0x0001);
     delay_ms(10);
     //设定AM_DEEMPHASIS 50us 0x0001
     si47xx_set_property(AM_DEEMPHASIS,AM_Deemphasis);
     delay_ms(10);
     //设定AM_RSQ_INTERRUPTS All interrupts are disabled by default 0x0000
     si47xx_set_property(AM_RSQ_INTERRUPTS,0x0000);
     delay_ms(10);
     //设定AM_RSQ_SNR_LO_THRESHOLD    10 dB 0x000a
     si47xx_set_property(AM_RSQ_SNR_LO_THRESHOLD,0x000a);
     delay_ms(10);
     //设定AM_RSQ_SNR_HI_THRESHOLD   10 dB 0x000a
     si47xx_set_property(AM_RSQ_SNR_HI_THRESHOLD,0x000a);
     delay_ms(10);
     //设定AM_RSQ_RSSI_HI_THRESHOLD   30 dB 0x001e
     si47xx_set_property(AM_RSQ_RSSI_HI_THRESHOLD,0x001e);
     delay_ms(10);
     //设定AM_RSQ_RSSI_LO_THRESHOLD   10 dB 0x000a
     si47xx_set_property(AM_RSQ_RSSI_LO_THRESHOLD,0x000a);
     delay_ms(10);
     //设定AM_SOFT_MUTE_RATE   278dB/s 0x0040
     si47xx_set_property(AM_SOFT_MUTE_RATE,0x0040);
     delay_ms(10);
     //设定AM_SOFT_MUTE_MAX_ATTENUATION   10dB 0x000a
     si47xx_set_property(AM_SOFT_MUTE_MAX_ATTENUATION,0x000a);
     delay_ms(10);
     //设定AM_SOFT_MUTE_SNR_THRESHOLD   9dB 0x0009
     si47xx_set_property(AM_SOFT_MUTE_SNR_THRESHOLD,0x0009);
     delay_ms(10);
     delay_ms(10);
     //设定AM_SEEK_BAND_BOTTOM   0x020a 522KHz
     si47xx_set_property(AM_SEEK_BAND_BOTTOM,MW_BAND_BOTTOM_VALUE);
     delay_ms(10);
     //设定AM_SEEK_BAND_TOP   0x06ae 1710KHz
     si47xx_set_property(AM_SEEK_BAND_TOP,MW_BAND_TOP_VALUE);
     delay_ms(10);
     //设定AM_SEEK_FREQ_SPACING   0x000a 10kHz
     si47xx_set_property(AM_SEEK_FREQ_SPACING,0x0009);
     delay_ms(10);
               //设定AM_SEEK_SNR_THRESHOLD   0x0002 2dB
               si47xx_set_property(AM_SEEK_SNR_THRESHOLD,MW_SNR_LOCAL);
               delay_ms(10);
               //设定AM_SEEK_RSSI_THRESHOLD   0x000f 15dBuV
               si47xx_set_property(AM_SEEK_RSSI_THRESHOLD,MW_RSSI_LOCAL);
               delay_ms(10);
               si47xx_set_property(AM_SEEK_SNR_THRESHOLD,MW_SNR_REMOTE);
               delay_ms(10);
               si47xx_set_property(AM_SEEK_RSSI_THRESHOLD,MW_RSSI_REMOTE);
               delay_ms(10);
// 设备关机
     unsigned char write_buf[1]={0x00};
            write_buf[0]=POWER_DOWN;
            OperationSi47XX_2w(WRITE,&write_buf[0],1);
            delay_us(300);
//获取属性值(高8位,低8位分别获取)
void si47xx_get_property(unsigned int propNumber, unsigned char *valueH,unsigned char *valueL)
     unsigned char cmd[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
            cmd[0] = GET_PROPERTY;
            //Initialize the reserved section to 0
     cmd[1] = 0;
            //Put the property number in the third and fourth bytes.
     //Invoke the command
            OperationSi47XX_2w(WRITE,&cmd[0],4);
     delay_ms(300);
            OperationSi47XX_2w(READ,&cmd[0],4);
            *valueH  = cmd[2];
            *valueL  = cmd[3];
            //Freq=((u16)rsp[2] << 8) | (u16)rsp[3];
//获取音量值
            unsigned char valueH = 0;
            unsigned char valueL = 0;
            unsigned char vol;
            si47xx_get_property(RX_VOLUME, &valueH, &valueL);
            delay_ms(10);
            vol=((u16)valueH << 8) | (u16)valueL;
            return vol;
//设定音量值
            if(vol <= 63)
                        si47xx_set_property(RX_VOLUME,vol);
                        delay_ms(10);
//MUTE AUDIO
     if(muteStaus)
                         si47xx_set_property(RX_HARD_MUTE,0x0003);     //mute on
                         delay_ms(10);
                        si47xx_set_property(RX_HARD_MUTE,0x0000);    //unmute
                        delay_ms(10);
Si47XX_Set_Property_FM_SNR_Threshold()
Default is 3dB
T_ERROR_OP Si47XX_Set_Property_FM_SNR_Threshold(void)
            unsigned char Si47XX_set_property[] = {0x12,0x00,0x14,0x03,0x00,0x02};        //SNR threshold = 0x0002 = 2dB
            //send CMD
            error_ind = OperationSi47XX_2w(WRITE, &(Si47XX_set_property[0]), 6);
            if(error_ind)
                       return I2C_ERROR;
            //wait CTS = 1
            do
                       if(error_ind)
                                  return I2C_ERROR;
                       loop_counter++;
            return OK;
Si47XX_Set_Property_FM_RSSI_Threshold()
Default is 20dBuV
T_ERROR_OP Si47XX_Set_Property_FM_RSSI_Threshold(void)
                                        unsigned char Si47XX_set_property[] = {0x12,0x00,0x14,0x04,0x00,0x08};        //RSSI threshold = 0x0008 = 8dBuV
            //send CMD
            if(error_ind)
                       return I2C_ERROR;
            //wait CTS = 1
                                        do
                                                    if(error_ind)
                                                               return I2C_ERROR;
                                                    loop_counter++;
            return OK;
static Si47XX_FM_Tune_Freq()
static T_ERROR_OP Si47XX_FM_Tune_Freq(unsigned short channel_freq)
                                        unsigned char Si47XX_tune_freq[] = {0x20,0x00,0x00,0x00,0x00};        //0x27F6=10230KHz
            Si47XX_tune_freq[2] = (channel_freq&0xff00) >> 8;
            Si47XX_tune_freq[3] = (channel_freq&0x00ff);
            //send CMD
            error_ind = OperationSi47XX_2w(WRITE, &(Si47XX_tune_freq[0]), 5);
            if(error_ind)
                       return I2C_ERROR;
            //wait CTS = 1
                                        do
        if(error_ind)
        return I2C_ERROR;
        loop_counter++;
            return OK;
Si47XX_Set_FM_Frequency()
            if(Si47XX_FM_Tune_Freq(channel_freq) != OK) return G_ERROR;
            if(Si47XX_Wait_STC() != OK) return G_ERROR;
            return OK;
// 设备复位
     TU_SDA_OUT();
            TU_SCL_OUT();
     TU_SDA_L;
                   TU_RST_L;
     TU_SCL_H;
     delay_ms(500);
            TU_RST_H;
            delay_ms(10);
     TU_SDA_H;
            delay_ms(10);
// IIC 读写函数 例如 OperationSi47XX_2w(WRITE,&write_buf[0],3); OperationSi47XX_2w(READ,&cmd[0],4);
     unsigned char controlWord,j;
            unsigned char error = 0;
            char i;
            //Start: make sure here SCK = 1,SDA = 1(output).
     TU_SCL_H;
                   TU_SDA_H;
            delay_us(3);
     TU_SDA_L;
            delay_us(3);
            TU_SCL_L;
            delay_us(3);
            //Write control data: make sure here: SCL = 0; SDA = 0
            //controlWord = radio_address | (operation & 0x01);
            //sens = 0 device address = 0010001x r/w b
            //sens = 1 device address = 1100011x r/w b
            if(operation == READ)
                               controlWord = 0xc7;      //IIC器件读地址0xc7
                               controlWord = 0xc6;      //IIC器件写地址0xc6
            for(i = 8; i > 0; i--)       //Write 1 byte
          if((controlWord >> (i-1)) & 0x01)
                                          TU_SDA_H;
                                                               TU_SDA_L;
                                             delay_us(3);
                                             TU_SCL_H;
          delay_us(3);
                                      TU_SCL_L;
          delay_us(3);
     //Check ACK for control word
                   TU_SDA_IN();
                   delay_us(3);
                   TU_SCL_H;
                   delay_us(3);
            if((TU_SDA_read) != 0)
                                                    error = 1;
                        goto Stop_2W;
     TU_SCL_L;
            delay_us(3);
     //WRITE or READ data
            for(j = 0; j < numBytes; j++, data1++)
          if(operation == WRITE)
                                                         TU_SDA_OUT();
               TU_SDA_IN();
                 for(i = 8; i > 0; i--)    //write or read 1 byte
        if( (*data1 >> (i-1)) & 0x01 )
        TU_SDA_H;
        TU_SDA_L;
        delay_us(3);
        TU_SCL_H;
        delay_us(3);
                                   *data1 = (*data1 << 1) | (TU_SDA_read); //READ_SDIO;
                             TU_SCL_L;
                                                  delay_us(3);
          //CHECK ACK or SEND ACK=0,最后一个bit 的ACK必须发送
                                                         TU_SDA_IN();
                                                         TU_SDA_OUT();
               if(j == (numBytes - 1))
                    TU_SDA_H;
                           TU_SDA_L;
          delay_us(3);
          TU_SCL_H;
          delay_us(3);
        error = 1;
                                  goto Stop_2W;
          TU_SCL_L;
          delay_us(3);
     //STOP: make sure here: SCL= 0
     Stop_2W:
                 TU_SDA_OUT();
          TU_SDA_L;
          delay_us(3);
          TU_SCL_H;
          delay_us(3);
          TU_SDA_H;
          delay_us(3);
          return(error);   //no return data
            unsigned char RES_buf[1]={0x00};
            unsigned char cmd[2]={0x00,0x00};
            cmd[0]=FM_SEEK_START;
            cmd[1]=0x0c;
            OperationSi47XX_2w(WRITE,&cmd[0],2);
            delay_ms(150);
            do{
                          OperationSi47XX_2w(READ,&RES_buf[0],1);
                          delay_us(300);
                          loop_counter++;
            while((((RES_buf[0])&0x80) == 0) && (loop_counter < 0xff));
                        return ERROR;
                       return OK;
//自动首台-向上 FM_SEEK_START
            cmd[1]=0x04;
     OperationSi47XX_2w(WRITE, &cmd[0],2);
            delay_ms(150);
            do{
                          delay_us(300);
                          loop_counter++;
                        return ERROR;
                        return OK;
void si47xx_command_FM_TUNE_STATUS(unsigned char *res)
            cmd[0]=FM_TUNE_STATUS;
            cmd[1]=0x03;                //aborts a seek currently in progress;clears the seek/tune complete interrupt status indicator 0x01 不然搜台错误。
            delay_us(300);
            OperationSi47XX_2w(READ,&res[0],8);
void si47xx_command_GET_INT_STATUS(unsigned char *res)
            cmd[0]=GET_INT_STATUS;
            //cmd[1]=0x01;                //clears the seek/tune complete interrupt status indicator 0x01 不然搜台错误。
            OperationSi47XX_2w(WRITE,&cmd[0],1);
            delay_us(300);
            OperationSi47XX_2w(READ,&res[0],1);
     unsigned int  Freq;
            unsigned char rsp[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
                   unsigned char Res[1]={0x00};
            //Reply Status. Clear-to-send high. STCINT = 1
            si47xx_command_GET_INT_STATUS(&Res[0]);
            delay_ms(10);
            if(band==1)
                        si47xx_command_FM_TUNE_STATUS(&rsp[0]);
                        if(rsp[0]==0x88)
                                        return Freq;
                                    return 0;
            return Freq;
ID:1101380 发表于 2024-2-22 00:59
楼主能否共享下si4730驱动程序,谢谢
ID:635039 发表于 2024-1-16 23:16
楼主帮忙发一份给我学习学习,万分感谢
ID:997432 发表于 2023-11-9 22:54
请楼主发一份给我,整一套来听听。254370820@qq.com.
ID:1094544 发表于 2023-10-17 16:27
feeling1791 发表于 2022-11-11 16:03
邮件已发,请及时收取,163有期限
可以也给我发一份吗?谢谢!
38793307@qq.com
ID:311400 发表于 2023-10-12 16:23
烦请楼主也发一份给我学习学习。459299729@qq.com。谢谢!
ID:933601 发表于 2023-10-3 08:13
烦请楼主也发一份给我学习学习,l.htlht@163.com 谢谢
ID:813932 发表于 2023-9-18 07:16
这个功放方案很好用,学习下。
ID:1069806 发表于 2023-9-13 14:21
烦请楼主也发一份给我学习学习。123754086@qq.com。谢谢!
ID:1034178 发表于 2023-9-8 13:10
sunping360 发表于 2022-10-18 07:04
你好,楼主好久都不来51黑了,你能把文件发一份给我?123866032@qq.com 谢谢
ID:846237 发表于 2023-9-8 11:01
太复杂了!不适合我这种初级DIY  玩玩蓝牙+3116就够了
ID:91689 发表于 2023-9-5 01:25
楼主帮忙发一份给我学习学习,万分感谢328572368@qq.com
ID:313468 发表于 2023-8-1 10:34
楼主可以发一份文件给我嘛,学习学习 3317386064@qq.com
ID:1063423 发表于 2023-7-27 00:26
佩服楼主技术,能否发一份资料。正在学习单片机万分感谢123866032@qq.com
ID:111463 发表于 2023-7-10 16:24
花了不少功夫,不知相关程序设计思路?
ID:127035 发表于 2023-7-8 21:58
GUOJF2020 发表于 2022-12-5 12:45
主控板和按键板都有,就是蓝牙版本有点低。建荣的蓝牙主控。
楼主你好!发一份给我,谢谢。1942157728@qq.com.
ID:907827 发表于 2023-6-4 14:40
楼主帮忙发一份给我学习学习,万分感谢   865037326@qq.com
ID:1065409 发表于 2023-6-3 20:51
请楼主发一份给我听听,谢谢。1184327224@qq.com
ID:1065409 发表于 2023-6-2 22:55
请楼主发一份给我,整一套来听听。1184327224@qq.com
ID:828114 发表于 2023-4-28 16:08
麻烦楼主发一份资料学习学习,万分感谢,2416611411@qq.com
ID:102189 发表于 2023-4-20 11:52
楼主帮忙发一份给我学习学习,万分感谢8964569652@qq.com
ID:293079 发表于 2023-3-29 11:27
楼主帮忙发一份给我学习学习,万分感谢 417341723@qq.com
ID:627633 发表于 2023-3-24 13:58
有没有软件?能发一份给我学一下吗?
ID:627633 发表于 2023-3-24 11:49
谢谢分亨。。。麻烦发674373430@qq.com
ID:627633 发表于 2023-3-24 10:19
有没软件?能发一份给我学习一下吗?674373430@qq.com
ID:742085 发表于 2023-3-21 11:17
谢谢分亨。。。麻烦发3293889013@qq.com
ID:933601 发表于 2023-2-28 20:31
楼主厉害!,超喜欢这个频谱显示,麻烦给份资料学习!!谢谢!
ID:1051585 发表于 2022-12-10 23:55
烦请楼主发一份资料学习学习,谢谢。
是不是广场舞音箱的量产品?带外接输入,蓝牙输入,带USB/CARD读取,功放不错,显示弱了点
ID:959743 发表于 2022-12-6 13:48
楼主厉害!,超喜欢这个频谱显示,麻烦给份资料学习!!谢谢。892734852@qq.com
ID:827391 发表于 2022-12-5 13:05
楼主帮忙发一份给我学习学习,万分感谢   479361682@qq.com
