Proteus仿真液晶显示花屏?
查看数: 1804 | 评论数: 4 | 收藏 0
发布时间: 2024-3-20 18:11
液晶显示不理想,但编译是通过了的。也不知道哪里出错了。附源代码 #include<reg52.h> #include<intrins.h> #include <math.h> //Keil library #include <stdio.h> //Keil library # ...
ID:1107719 发表于 2024-3-21 13:06
unsigned char code time[][16]={
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//"0",
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//"1",
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//"2",
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//"3",
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//"4",
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//"5",
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//"6",
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//"7",
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//"8",
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//"9",
0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//"V",10
0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//"S",11
0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//":",12
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//".",13
0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//"T"14
0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//"N"15
0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//"D"16
0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//"R"17
0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//"H"18
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"空格"19
void Display_ASCII(uchar screen,uchar page,uchar column,uchar a[][16],uchar h)
        uchar i;
        SelectScreen(screen);
        Set_page(page);
        Set_column(column*8);
        for(i=0;i<8;i++) //显示字符上半部分:8*8
                write_LCD_data(*(a[h]+i));
        Set_page(page+1); //显示字符下半部分:8*8
        for(i=0;i<8;i++)
        write_LCD_data
        (*(a[h]+i+8));
                Display_ASCII(1,2,5,time,A);
                Display_ASCII(1,2,6,time,B);
                Display_ASCII(1,2,7,time,C);//bifen
                Display_ASCII(2,2,1,time,12);
                Display_ASCII(2,2,3,time,D);
                Display_ASCII(2,2,4,time,E);
                Display_ASCII(2,2,5,time,F);
下面的比分显示不出来。是哪里有问题???
ID:1107719 发表于 2024-3-21 09:59
现在是只显示场次和比赛双方,不显示比分了(比赛双方是我调用错了数组导致字不对)
ID:102963 发表于 2024-3-20 22:00
液晶控制口D1网络和数据口的D1网络重了,改下它试试。
